**THE AMD DRIVERS THREAD**
Status
Not open for further replies.
25 Jun 2011
Aberdeen
I've created this thread for a number of reasons:
1. Keep driver updates in one place
2. Help others out with driver issues
3. Post up known fixes for certain games/driver revisions.
Also seen a fair few 'don't use AMD the drivers are crud' comments lately based on drivers used two years ago (I know, I know). If this is true we will see it materialise in this thread, also solutions when possible.
Don't forget to report any issues directly to AMD (will put a link in when I get home).
Please please please do not turn this into one long pointless argument about who has the better drivers, any baiting comments I will request to have deleted.
If posting solutions please mention if you're using any 3rd party applications such as radeonpro.
Open to suggestion on any improvements, if anyone wants to start an nvidia alternative to this thread please do, it could help us isolate game engine issues rather then driver issues.
Drivers:
We're working on the CrossFire frame pacing driver for the June/July timeframe. It has a metering mechanism that will ensure consistent delivery of frame intervals, at the expense of some small input lag, via a rolling analytical algorithm.
In the interim, vsync and/or DFC can reduce or virtually eliminate multi-GPU frame pacing issues.
We take this issue very seriously, and have considerable resources allocated to addressing it fully and properly.
Latest WHQL:
13.4 WHQL - http://www2.ati.com/drivers/13-4_vista_win7_win8_64_dd_ccc_whql.exe
Latest BETA:
13.8 BETA 2 - http://www2.ati.com/drivers/beta/amd_catalyst_13.8_beta2.exe
13.8 BETA - http://www2.ati.com/drivers/beta/amd_catalyst_13.8_beta.exe
OpenGL 4.3 Beta Driver - http://www2.ati.com/drivers/beta/AMD_Catalyst_Win8.1_Release_Preview_V2-13.15.100.1.exe
Latest CAP:
13.5 CAP 1 - http://www2.ati.com/drivers/hotfix/catalyst_application_profiles/AMD_Catalyst_13.5_CAP1.05212013.exe
13.4 CAP 1 - http://www2.ati.com/drivers/hotfix/catalyst_application_profiles/AMD_Catalyst_13.4_CAP1.exe
IF YOU HAVE A DRIVER ISSUE REPORT IT!!
If a driver contains newer built-in profiles than the installed CAP, the installed CAP will be ignored for those entries. The driver will fall back to the CAP in absence of a built-in driver profile. The latest CAP is always suggested.
PGI's performance recommendation: 13.8 BETA, frame pace drivers, highly recommended for multiple card users
PGI's stability recommendation: 13.4 WHQL with 13.4 CAP1 & 13.5 CAP 1
So to round up, current issues with 13.5 Beta 8:
NONE AS OF YET!
Radeon PRO - Preview - http://download.radeonpro.info/RadeonPro_Preview.exe
Radeon Profile Tool, or RadeonPro for short, is a free, user friendly utility designed to unleash the power of AMD™ Radeon™ video graphics cards. RadeonPro applies user defined profiles upon game start, just define once the desired 3D settings for each game and have all those settings applied every time you play, automatically!
Radeon Pro Profile Packs!!
Simply use the backup/restore function in RadeonPRO to add these profiles to RP.
Package 1:
Notes:
Driver Installation Methods:
Installing a new driver version.
Enter Control panel and and uninstall current driver now Restart
Download and install Driver Fusion (OR amd_cleanup_util_1.2.1.0) and scan AMD Display and remove all and restart again
Screen should now be in Standard VGA mode "massive icons"
Install new driver and restart once more.
Use ONLY on Windows 7
**Not always required, may solve issues upon installing new drivers over the old**
Overclocking
MSI Afterburner v2.3.1 - latest official - http://download1.msi.com/files/downloads/uti_exe/vga/MSIAfterburnerSetup231.zip
MSI Afterburner v3.0.0 BETA 10 - Latest BETA - http://www.guru3d.com/files_details/msi_afterburner_beta_download.html
How to overclock with MSI Afterburner - http://forums.overclockers.co.uk/showthread.php?t=18431335
Sapphire TRIXX v4.6.0 - Latest Official - http://www.sapphiretech.com/archive/drivers/TRIXX_installer_634959254654310003.exe
Sapphire TRIXX v4.4.0b - Modded revision see below before use - https://dl.dropboxusercontent.com/u/43853114/Sapphire Trixx 4.4.0b-MOD.zip
**Not for amateur use, gives voltage limits of 1.38v on core and 1.8v on memory. Do not use 'reset' to reset clocks to default, manually adjust sliders back to stock, failure to do so will result in a crash**
ASUS GPU Tweak v2.3.7.3 - latest official - http://dlcdnet.asus.com/pub/ASUS/vga/app/GPUTweak_2_3_7_3.zip
Gigabyte OC Guru v1.36 - latest official - http://download.gigabyte.eu/FileList/Utility/vga_utility_oc_guru_2.exe
HIS iTurbo v1.3.1 - latest official - http://www.hisdigital.com/iturbo/download/iTurbo_v1.3.1.exe
Powercolor PowerUP tuner v0.2.1 - latest official - http://www.powercolor.com/download_file.asp?url=/uploadfile/PowerupTuner/2013116012404.zip
Helpful threads!!
Graphics Card Warranty's - Let's see how good they really are *Look*
How to overclock a 7850 past 1050mhz?
AMD - How To Overclock The Official Way Using Afterburner + Step By Step Overclocking Guide + Complete Driver Sweep
AMD Eyefinity FAQ
OP
25 Jun 2011
Aberdeen
KNOWN FIXES
FIFA 2013:
Fix lag issue when using in-game Vsync - shankly1985
The Fix
Download RadeonPro and create a profile, set Vsync to always on and also tick box lock frame rate to monitor's refresh rate.
In-game settings disable Vsync and set to lock at 60FPS.
Fix stutter using multiple cards - pgi947
Create a profile for fifa13.exe in CCC's profile manager (over-ride current settings) and set crossfire to disable. Will now run noticeably smoother on a single card
Far Cry 3
**This game has engine issues so do not expect perfection**
Create a profile in RadeonPro with the following settings:
Tweaks
Vsync Always on and disabled ingame
Triple buffering - on
Lock frame rate up to monitors refresh rate - on
Disable Aero
Force Process high priority
Advanced settings
Texture filtering Quality - High
Mipmap Quality - High
Alternatively try running the game in DX9 rather than DX11
Metro: Last Light
*FIXED in latest game patch* - Flickering issue, is a problem for both AMD and Nvidia users. Metro developers have recognised it is an engine problem and are working on an in-game patch.
Please check PCGW for any other game fixes!! - http://pcgamingwiki.com/wiki/Home
OP
25 Jun 2011
Aberdeen
No harm in starting a thread on new drivers, I'll just update the op as they arrive, make it easier for someone to tell which is the latest and/or best to date, as we all know some newer betas can have flaws older drivers don't :)
So if anyone has any solutions to getting certain games working better please post them. I'll also link to the pcgames wiki someone on reddit started, it's a database to game fixes ;)
3 Feb 2012
Peterborough
AMD drivers so bad they get their own thread :D
Seriously though, looking forward to trying out the new memory management drivers. Although I don't have anything to compare directly side by side anymore they're now feeling as smooth as my 680s did. Will be nice to see if I can perceive any difference.
OP
25 Jun 2011
Aberdeen
I will sort out the op with links to everything once I get home ;)
Hopefully the end result will help people recommend cards based on fact and not hearsay.
"I play games x y & z, what brand do I want" can then be pointed here and hopefully an nvidia counterpart and work from that :)
25 Nov 2011
The KOP
Great Idea
I'll start first Game Fix.......
FIFA 13
The Fix
Now enjoy smooth gameplay
:D
Caporegime
12 Jul 2007
United Kingdom
Great Idea
FIFA 13
The Fix
:D
That's a handy fix as when i last played that it had some stutter.
Any driver apart from the latest officials will crash Football Manager 2013 for me.
In the officials, I can't play in 3D mode.
Help meh!
:p
LOL! Please uninstall football manager and leave the forum immediately. :p
Caporegime
12 Jul 2007
United Kingdom
Mr Pgi tips i have a request to make. Remove the 12.11 caps link in your second post as all amd drivers (even 13.1 WHQL) include the latest caps file already and the caps files included is newer than 12.11.
Status
