***The OcUK ComputeMark Leaderboard***
Caporegime
17 Mar 2012
ARC-L1, Stanton System
This is a measurement of your GPU's Compute Performance.
Instructions:
Extract the files into a folder, Right Click on the 'ComputeMark' file and run as Admin, don't change any settings, simply click on 'Run Benchmark'
Once its done Click on 'Publish Score'
It will upload it to a server with a Screenshot so be sure you don't have anything on the Desktop you don't want published.
Once your score is published in the browser; click on the image thumbnail, that will open the image, copy the URL from the image and post it here as your results, along with your GPU and CPU details.
*It may come up with an error in the upload, ignore*
For 'Out of the box' comparisons we have a stock clock results table here http://forums.overclockers.co.uk/showpost.php?p=26225041&postcount=2
This is to compare the performance between different brands of GPU without any user overclocking, for this please add the make, model, standard clock speeds and the tag *GPU Comparison* to your results page.
If you can't remember your factory clocks just hit reset on MSI AB and it will set the clocks to whatever the BIOS is set at.
(One GPU Standard Mode only.)
Extra Info-
I would prefer The uploaded URL Method, but it seems that does not work for everyone, if it does not work i will accept a Screenshot of the Application Windows with the results printed in it.
For CrossFire 'Full Screen' must be enabled for it to work.
For Multi GPU setting must be '1080P - extreme'
It should look like this
R9 290 @ 1100/1400
Phenom II X6 @ 4.1Ghz
Score 8021
http://www.computemark.com/computemark-scores/28124915194.jpg
Use as many GPU's as you like.
Program is available here; http://www.computemark.com/cm.php?show=download
Scoreboard - One GPU - Standard
1, Nickolp1974 - 780Ti @ 1400/2000 - Score 12711 - Link
2, Darket - 780Ti @ 1369/2000 - Score 12252 - Link
4, MrZippo - 780TI @ 1149/1960 - Score 12226 - Link
5, whyscotty - GTXTitan @ 1345/1877 - Score 11836 - Link
6, Gregster - GTXTitan @ 1381/1877 - Score 11780 - Link
7, jh30uk - 780Ti @ 1300/2000 - Score 11366 - Link
8, iTek - 780 @ 1280/6992 - Score 10042 - Link
9, pgi947 - 780 @ 1280/6800 - Score 9962 - Link
10, peahead - 780 @ 1215/1677 - Score 9712 - Link
11, Ian Evey - 780 @ 1110/6250 - Score 9093 - Link
12, wazza300 - 7970 @ 1280/1840 - Score 8667 - Link
13, damov3 - 290P @ 1130/1375 - Score 8422 - Link
14, Humbug - 290P @ 1165/1300 - Score 8357 - Link
15, LtMatt - 290P @ ?????????? - Score 8239 - Link
16, shankly1985 - 290P @ @1100/1250 - Score 8112 Link
17, Mr Krugga - 7970 @ 1225/1700 - Score 8081 - Link
18, breadturbo - 290X @ 1000/1250 - Score 7943 - Link
19, MyBrains - 7950 @ 1225/1650 - Score 7630 - Link
20, arc@css - 7970 @ 1175/1765 - Score 7568 - Link
21, PapaLazaru - 270X @ 1180/5600 - Score 5248 - Link
22, wazza300 - 7850 @ 1260/1520 - Score 4778 - Link
23, vsg28 - 7970m @ 400/1000 - Score 4047 - Link
24, iTek - 5870 @ Stock - Score 3138 - Link
Scoreboard - One GPU - 1080P
1, damov3 - 290 @ 1163/1375 Score - 4530 - Link
2,
breadturbo - 290X @ 1000/1250 - Score 4409 - Link
3, MyBrains - 7950 @ 1225/1650 - Score 4151 - Link
- 1080P - Extreme
1, MyBrains - 7950 @ 1225/1650 - Score 1238 - Link
Scoreboard - Two GPU
- 1080P
1, RavenLunatic - 295x2 @ 1018/1250 Score 3771 - Link
2,
shankly1985 - 290P @ 977/1250 - Score 3521 - Link
3, Bobie8 - 280X @ 1070/6400 - Score 3142 - Link
4, IceShock - 7950 @ 1150/1450 - Score 3129 - Link
- 1080P - Extreme
1,
RavenLunatic - 295x2 @ 1018/1250 Score 871 - Link
2, Bobie8 - 290X @ 1070/6400 - Score 846 - Link
3,
IceShock - 7950 @ 1150/1450 - Score 846 - Link
Scoreboard - Four GPU -
1080P - Extreme
Caporegime
OP
17 Mar 2012
Man of Honour
21 May 2012
Dalek flagship
12 Jan 2014
This is weird, the benchmark didn't even stress my laptop GPU to go past 50% usage. It should be about 6000 or so score based on the scores in here but it is way lower than that.
Anyway:-
Score:3948
I7 3630QM at 2.4/3.6 GHz
AMD 7970m at max clocks of 400/1000 (should be 850/1200)
Caporegime
12 Jul 2007
United Kingdom
Humbug can you do sections for each resolution? Like 1080P etc? Crossfire works on this providing you select full screen as well. Otherwise it won't work.
ALso some other settings worth messing with, complex, extreme etc. Maybe an extreme section as well? :D
25 Nov 2011
The KOP
No options are they, looks like this is a single card solution benchmark tool. We only really have the preset/resolution options to adjust.
Shame
Select full screen :D
i7 2600k @4.4
My score Crossfire 290 @977/1250 1080p
http://www.computemark.com/computemark-scores/28142648963.jpg
