LuxMark 2.0 Bench Thread
Caporegime
12 Jul 2007
United Kingdom
LuxMark 2.0
LuxMark is a OpenCL benchmark tool. The idea for the program was conceived in 2009 by Jean-Francois 'Jromang' Romang. It was intended as a promotional tool for LuxRender (to quote original Jromang's words: "LuxRender propaganda with OpenCL"). The idea was quite simple, wrap SLG inside an easy to use graphical user interface and use it as a benchmark for OpenCL. After Anandtech adoption of SLG as OpenCL benchmark, the code was finally written by David 'Dade' Bucciarelli.
After a year from the release, LuxMark v1.0 has been widely used as OpenCL benchmark by AnandTech, Tom's Hardware, Vr-zone and other sites. AMD has used LuxMark as one of the 5 GPU computing benchmarks to present the new HD7970.
LuxMark v2.0 includes SLG2 as rendering engine with Metropolis Light Transport, Multiple Importance Sampling, Image reconstruction done on the GPU, support for multiple OpenCL platforms (i.e. Nvidia users can use Intel or AMD CPU device) and many more new features. The new features rise the complexity of the benchmark of nearly one order of magnitude and it should be able to put some serious stress on the new generation of GPUs
LuxMark 2.0 Features
Open source
100% OpenCL
Cross platform (Linux, MacOS, Windows, etc.)
Complex/real world code used as GPU computing benchmark
Support for OpenCL GPUs-only, OpenCL CPUs+GPUs, OpenCL CPUs-only benchmarking
Support for Interactive mode
Easy to run
Multiple scenes usable as benchmarks
Totally new rendering engine based on SLG2 with Metropolis Light Transport, Multiple Importance Sampling, Image reconstruction done on the GPU, ecc;
Multi-platform OpenCL support;
2 new benchmark scenes, for a total of 3 benchmarks with a raising complexity (~200,000, ~500,000, ~2,000,000 triangles);
Run the benchmark only on the OpenCL devices you selected on the device panel;
Added the possibility to submit the scored result to a centralised result database: http://www.luxrender.net/luxmark;
Download
http://www.luxrender.net/release/luxmark/luxmark-win64-v2.0.zip
Instructions
Download the file above and extract the contents to a new folder. Open up Luxmark and the benchmark will start at stock (medium) settings. You can select Pause from the edit menu to stop the bench so you can pick your desired settings. Once happy select the scene you want, then go to Mode and select 'Open CL Gpus only' and the bench will start.
When the bench is over please state what setting you used (LuxBall, Sala Medium or Room Complex) gpu clocks, driver used and post a screenshot of the bench result like this one below.
Benchmark Scenes
LuxBall HDR Simple Benchmark
Sala Medium Benchmark
Room Complex Benchmark
Caporegime
OP
12 Jul 2007
United Kingdom
1 GPU.
  1. Score 27127 GPU 290X @1270/1625, Kaapstad Link 14.4 Beta
  2. Score 26693 GPU 290X @1300/1625, Avenged7Fold Link 14.4 WHQL
  3. Score 25778 GPU 290P @1225/1400, Dempsey22 Link 14.12 WHQL
  4. Score 25697 GPU 290X @1200/1500, tommybhoy Link 14.4 Beta
  5. Score 25152 GPU 290X @1175/1625, the1gooner Link 14.4 WHQL
  6. Score 23872 GPU 290P @1270/1625, Uncle Petey Link 14.4 WHQL
  7. Score 22759 GPU 290P @1200/1500, Humbug Link 14.6 Beta
  8. Score 22749 GPU nvTitan @1381/1877, Gregster Link 337.5 Beta
  9. Score 21893 GPU nvTitan @1254/1877, Whyscotty Link 337.5 Beta
  10. Score 21654 GPU 290P @1130/1375, damov3 Link 14.4 WHQL
  11. Score 20884 GPU 290P @975/1250, LtMatt Link 14.4 Beta
  12. Score 19021 GPU 7970 @1270/1850, Uncle Petey Link 14.4 WHQL
  13. Score 18524 GPU 7970 @1280/1840, wazza300 Link 14.4 Beta
  14. Score 18113 GPU 7970 @1145/1400, snips86x Link 14.4 Beta
  15. Score 11289 GPU 7850 @1200/1500, MadMatty Link 14.4 WHQL
  16. Score 8135 GPU 6950 @850/1300, Mike306 Link 13.1 Beta
  17. Score 7372 GPU 7770 @1300/1250, LtMatt Link 14.4 Beta
2 GPUs.
  1. Score 51603 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  2. Score 51266 GPU 290P @1270/1620, tayto_0 Link 14.6 Beta
  3. Score 50293 GPU 290P @1275/1625, LtMatt Link 14.6 Beta
  4. Score 45659 GPU 780TI @1300/1800, MjFrosty Link 337.5 Beta
  5. Score 43773 GPU 290P @1270/1625, Uncle Petey Link 14.4 WHQL
  6. Score 41578 GPU 290P @975/1250, LtMatt Link 14.4 Beta
  7. Score 41346 GPU 290P @977/1250, Shankly Link 14.4 Beta
  8. Score 40354 GPU nvTitan @1150/1700, Geeman1979 Link 337.5 Beta
  9. Score 39057 GPU 7970 @1270/1850, Uncle Petey Link 14.4 WHQL
  10. Score 38162 GPU 7970 @1250/1800, Uncle Petey Link 14.4 WHQL
  11. Score 35505 GPU 280X @1050/1500, thebennyboy Link 14.9 WHQL
  12. Score 33809 GPU nvTitan @1032/1502, Whyscotty Link 337.5 Beta
  13. Score 30773 GPU 7950 @1160/1500, GoogalyMoogaly Link 14.4 WHQL
  14. Score 26941 GPU D700 @850/1370, N19h7m4r3 Link 14.4 WHQL
  15. Score 18557 GPU 260X @1320/1800, LtMatt Link 14.7 RC3
3 GPUs
  1. Score 76844 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  2. Score 63203 GPU 290P @1270/1625, Uncle Petey Link 14.4 WHQL
  3. Score 60581 GPU 290P @975/1250, LtMatt Link 14.7 Beta
4 GPUs
  1. Score 155063 GPU TitanX @1501/2002, Kaapstad Link 353.30
  2. Score 117891 GPU 980 @1502/2102, Kaapstad Link 347.09
  3. Score 100889 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  4. Score 78992 GPU nvTitan @994/1789, Kaapstad Link 337.5 Beta
Caporegime
OP
12 Jul 2007
United Kingdom
1 GPU.
  1. Score 3714 GPU 290X @1270/1625, Kaapstad Link 14.4 Beta
  2. Score 3688 GPU 290X @1300/1625, Avenged7Fold Link 14.4 WHQL
  3. Score 3583 GPU 290X @1175/1625, the1gooner Link 13.12 WHQL
  4. Score 3514 GPU 290X @1200/1500, tommybhoy Link 14.4 Beta
  5. Score 3291 GPU 290P @1270/1625, Uncle Petey Link 14.4 WHQL
  6. Score 3133 GPU 290P @1200/1500, Humbug Link 14.6 Beta
  7. Score 2965 GPU 290P @1130/1375, damov3 Link 14.4 WHQL
  8. Score 2904 GPU 290X @1000/125, Thot Link 14.2 Beta
  9. Score 2836 GPU 290P @1100/1400, Humbug Link 14.4 WHQL
  10. Score 2719 GPU 7970 @1270/1850, Uncle Petey Link 14.4 WHQL
  11. Score 2708 GPU 290P @975/1250, LtMatt Link 14.4 Beta
  12. Score 2692 GPU 7970 @1280/1840, wazza300 Link 14.3 Beta
  13. Score 1486 GPU 7850 @1200/1500, MadMatty Link 14.4 WHQL
  14. Score 1021 GPU 7770 @1300/1250, LtMatt Link 14.4 Beta
  15. Score 804 GPU 6950 @850/1300, Mike306 Link 13.1 Beta
  16. Score 614 GPU 570 @873/1951, siriq111 Link 347.52 WHQL
2 GPUs.
  1. Score 7211 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  2. Score 6871 GPU 290P @1270/1620, tayto_0 Link 14.6 Beta
  3. Score 6735 GPU 290P @1275/1625, LtMatt Link 14.6 Beta
  4. Score 6049 GPU 780TI @1300/1800, MjFrosty Link 337.5 Beta
  5. Score 5857 GPU 290P @1270/1625, Uncle Petey Link 14.4 Beta
  6. Score 5564 GPU 7970 @1270/1850, Uncle Petey Link 14.4 WHQL
  7. Score 5397 GPU 290P @975/1250, LtMatt Link 14.4 Beta
  8. Score 5216 GPU 290P @977/1250, Shankly Link 14.4 Beta
  9. Score 4906 GPU 280X @1050/1500, thebennyboy Link 14.9 WHQL
  10. Score 4492 GPU 7950 @1160/1500, GoogalyMoogaly Link 14.4 WHQL
  11. Score 4432 GPU nvTitan @1032/1502, Whyscotty Link 337.5 Beta
  12. Score 3781 GPU D700 @850/1370, N19h7m4r3 Link 14.4 WHQL
  13. Score 2686 GPU 260X @1320/1800, LtMatt Link 14.7 RC3
3 GPUs.
  1. Score 10781 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  2. Score 8422 GPU 290P @1270/1625, Uncle Petey Link 14.4 Beta
  3. Score 7919 GPU 290P @975/1250, LtMatt Link 14.7 Beta
4 GPUs.
  1. Score 19018 GPU TitanX @1501/2002, Kaapstad Link 353.30
  2. Score 15544 GPU 980 @1502/2102, Kaapstad Link 347.09
  3. Score 14183 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  4. Score 10433 GPU nvTitan @994/1789, Kaapstad Link 337.5 Beta
Caporegime
OP
12 Jul 2007
United Kingdom
1 GPU.
  1. Score 1845 GPU 290X @1270/1625, Kaapstad Link 14.4 Beta
  2. Score 1810 GPU 290X @1300/1625, Avenged7Fold Link 14.4 WHQL
  3. Score 1743 GPU 290X @1200/1500, tommybhoy Link 14.4 Beta
  4. Score 1714 GPU 290X @1175/1625, the1gooner Link 13.12 WHQL
  5. Score 1711 GPU 290P @1270/1625, Uncle Petey Link 14.4 Beta
  6. Score 1625 GPU 290P @1200/1500, Humbug Link 14.6 Beta
  7. Score 1538 GPU 290P @1130/1375, damov3 Link 14.4 WHQL
  8. Score 1476 GPU 290P @1100/1400, Humbug Link 14.4 WHQL
  9. Score 1450 GPU 7970 @1280/1840, wazza300 Link 14.3 Beta
  10. Score 1399 GPU 7970 @1270/1850, Uncle Petey Link 14.4 WHQL
  11. Score 1387 GPU 290P @975/1250, LtMatt Link 14.4 Beta
  12. Score 804 GPU 7850 @1200/1500, MadMatty Link 14.4 WHQL
  13. Score 551 GPU 7770 @1300/1250, LtMatt Link 14.4 Beta
  14. Score 373 GPU 6950 @850/1300, Mike306 Link 13.1 Beta
2 GPUs.
  1. Score 3568 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  2. Score 3434 GPU 290P @1270/1620, tayto_0 Link 14.6 Beta
  3. Score 3357 GPU 290P @1275/1625, LtMatt Link 14.6 Beta
  4. Score 3071 GPU 780TI @1300/1800, MjFrosty Link 337.5 Beta
  5. Score 3055 GPU 290P @1270/1625, Uncle Petey Link 14.4 Beta
  6. Score 2857 GPU 7970 @1270/1850, Uncle Petey Link 14.4 WHQL
  7. Score 2760 GPU 290P @975/1250, LtMatt Link 14.4 Beta
  8. Score 2748 GPU 290P @977/1250, Shankly Link 14.4 Beta
  9. Score 2705 GPU nvTitan @1254/1877, Whyscotty Link 337.5 Beta
  10. Score 2502 GPU 280X @1050/1500, thebennyboy Link 14.9 WHQL
  11. Score 2376 GPU 7950 @1160/1500, GoogalyMoogaly Link 14.4 WHQL
  12. Score 2006 GPU D700 @850/1370, N19h7m4r3 Link 14.4 WHQL
  13. Score 1421 GPU 260X @1320/1800, LtMatt Link 14.7 RC3
3 GPUs.
  1. Score 5357 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  2. Score 4381 GPU 290P @1270/1625, Uncle Petey Link 14.4 Beta
  3. Score 4074 GPU 290P @975/1250, LtMatt Link 14.7 Beta
4 GPUs.
  1. Score 10214 GPU TitanX @1501/2002, Kaapstad Link 353.30
  2. Score 8720 GPU 980 @1502/2102, Kaapstad Link 347.09
  3. Score 6964 GPU 290X @1250/1625, Kaapstad Link 14.4 Beta
  4. Score 5154 GPU nvTitan @994/1789, Kaapstad Link 337.5 Beta
Caporegime
OP
12 Jul 2007
United Kingdom
Room Complex - 290 Crossfire @975/1250 14.4 WHQL
Seems like Complex is good for fishing out an unstable gpu clock. I had a driver display reset running this that's never come up before in all my time of gaming on these undervolted settings.
