Arion Benchmark - Test your Hardware
Caporegime
24 Sep 2008
Essex innit!
I thought I would join in with the influx of benchmarks with RandomControls Arion benchmark utility. This tests your computers ability at Cuda rendering and outputs the data to a nice simple image. The test takes a couple of minutes and is very painless :)
Download from here {Click me}
If you can't download from there, fill in the form and register to download from here {Click me}
Simple rules.
Double click Arionbench_64.exe - Post the full size image and list your GPU and CPU clocks. Done.
It will look like this when it is done.
A bit of fun and nothing serious and we all love a bench when we can't be bothered to game :)
One GPU
1. 2711.47 - GTX 780Ti - MrZippo
2. 2690.73 - GTX Titan - Gregster
3. 2680.05 - GTX Titan - Whyscotty
4. 2404.41 - GTX 780Ti - DarrenM343
5. 2232.49 - GTX 780 - Ian Evey
6. 2228.35 - GTX 780 - MoodyB
7. 1286.34 - GTX 670 - Sighn
8. 1138.99 - GTX 670 - Bru
9. 1135.82 - GTX 670 - SkeeterUK
Two GPUs
1. 5387.25 - GTX 780Tis - MJFrosty
2. 5251.37 - GTX Titans - Geeman1979
3. 4905.49 - GTX Titans - Whyscotty
4. 4357.68 - GTX 780Tis - Radeon123
5. 4174.84 - GTX 780s - AncientMariner
6. 4130.81 - GTX Titans - Drangueos
7. 3947.99 - GTX Titans - Gregster
8. 2426.58 - GTX 670s - OldPhart
Three GPUs
1. 7473.66 - GTX 780Tis - MJFrosty
Four GPUs
1. 9067.00 - GTX Titans - Kaapstad
CPU Run
1. 914.87 - 4930K - Kaapstad
2. 811.12 - 3970X - Drangueos
3. 641.39 - 2700K - LtMatt
4. 636.44 - 3770K - Wazza300
Caporegime
12 Jul 2007
United Kingdom
I don't think this works on AMD. I'm at a dos screen and it says rendering this may take a few minutes, aside from that nothing is happening apart from a few dots appearing on the screen. I selected the 64 bit version.
Caporegime
12 Jul 2007
United Kingdom
I tell a lie, it eventually worked. Figured out why it took so bleeding long, it did it all on my cpu. My gpu's never got out of 2D clock mode. :D
Here's my score. :cool:
24 Oct 2005
North East
Thats the bench working Ltmatt, it does it in dos then after the :::: it outputs a pic it auto opened infranview for me with it.
Here is mine.
i5 3570k at 4.5ghz
670 : 1150 boost speed
8gb ddr3
win 7 64bit.
Caporegime
OP
24 Sep 2008
Essex innit!
