**Middle Earth :Shadow of Mordor Bench Thread**
Caporegime
24 Sep 2008
Essex innit!
This game is pretty and has an in-game benchmark :D Why not have a benchmark thread for it then I thought, so here we are. No bickering please and keep it on topic.
Setting to be maxed with ultra set as per the images and add the high res DLC by following this guide.
'steam://install/311670
Paste that in your browser. Install will fail.
Right click the game, go to properties, and DLC tab. It'll be there, check it and let it download.'
And here is the bench video from that run with the settings to be used.
Caporegime
OP
24 Sep 2008
Essex innit!
1080P single card results
1. 168.82 - Pulse88 - 290X
2. 131.86 - Africanos23 - TitanX
3. 111.67 - Uncle Petey - 290
4. 100.92 - Kaapstad - 980
5. 95.00 - Robzere31 - 290
6. 82.70 - Wazza300 - 7970
1440P single card Results
1. 82.36 - Moogleys - 290
2. 76.58 - Rankftw - 980
3. 70.64 - Kaapstad - 980
4. 70.20 - Silent_Scone - 980
5. 63.53 - Moogleys - 980
6. 60.53 - ShogunXShinobi - 970
7. 56.64 - Gregster - Tltan
8. 52.62 - Alex 123 Fra - 780
1080P results 2 GPUs
1. 179.82 - Bloodkill - 290
2. 163.07 - Uncle Petey - 290
3. 160.91 - AMDmatt - 290X
4. 150.18 - techen - 295X2
5. 94.43 - markeR - 7950
6. 78.53 - Savgebeast - 295X2
1080P results 3 GPUs
1. 203.75 - AMDmatt - 290X
1080P results 4 GPUs
1. 206.73 - AMDmatt - 290X
1440P results 2 GPUs
1. 95.54 - RobZere31 - 970
2. 90.47 - Alex 123 Fra - 780
3. 82.36 - Techen - 295X2
1440P results 3 GPUs
1. 111.37 - Silent_Scone - 980
2. 71.92 - Gregster - Tltan
1600P results 2 GPUs
1. 97.21 - Layte - Titan Black
2160P results 1 GPU
1. 54.21 - Africanos23 - TitanX
2. 36.49 - Kaapstad - 980
2160P results 4 GPUs
1. 145.29 - Kaapstad - 290X
Caporegime
OP
24 Sep 2008
Essex innit!
For those that have SLI, run nvinspector and add the F.E.A.R 3 profile to the sli bits and add the game.exe to the profile to get SLI running.
Also, I installed the HD pack and it didn't appear to add anything to performance hits or VRAM usage.
Caporegime
OP
24 Sep 2008
Essex innit!
Ohhh and just to add, I ran it at 200% (which is 5K?) and that used 5.7GB of VRAM. I wouldn't be surprised if there is some caching going on (as seen by Rankftw's results).
8 Jul 2011
Rosyth, Scotland
Made a video showing vram use at 1440p on a 980, all settings Ultra and motion blur off. I use GSYNC so the changing fps doesn't bother me. Did a couple of runs and they were both within 1 fps of each other.
Caporegime
30 Jul 2013
Be aware they if you selected Ultra before installing the Ultra textures then your game is more than likely still showing the 'high' textures.
I think you have to install textures, reload the game and cycle through them again.
