We’ve all heard the word ‘12VHPWR’ being thrown about – but what actually is it?
Today, we’re taking a closer look at the 12VHPWR power connectors, highlighting the benefits of this cable, and why you need one in your gaming PC.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/12VHPWR-featuredimg-1024x1024.png)
12VHPWR
12VHPWR is a type of 12+4-pin power connector, used with the brand-new ATX 3.0 power supplies.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Corsair-PCIe-12VHPWR-300x224.jpg)
A 12VHPWR connector has been designed utilising premium quality materials to deliver up to 600W of power, all from one singular cable. The combination of 12- and 4-pins will supply plenty of power to your GPU, with improved efficiency.
Why Do I Need a 12VHPWR cable?
These cables have been built specifically for the latest power-hungry PCIe 5.0 adapters, NVIDIA RTX 40 Series GPUs, and ATX 3.0 PSUs.
These deliver more power in a smaller area, thus not taking up as much PCB space in comparison to traditional 6- and 8-pin PCIe connectors. Any space-saving trick is a must-have for these hefty graphics cards!
What’s more, combined with an ATX 3.0 PSU, your gaming PC will be able to effectively handle any unexpected GPU power strikes, along with boasting improved efficiency and power consumption.
Has 12VHPWR Already Been Replaced?
12V-2×6 is set to replace 12VHPWR, boasting improvements to power delivery. If you want to learn more about 12V-2×6 cables, check out our blog post.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/12V-2X6-Explained-300x300.jpg)
Compatible 12VHPWR Power Supplies:
These compatible ATX 3.0 PSUs, will all come with a 12VHPWR connector included.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Corsair-RM1200-278x300.png)
Corsair RM1200x ATX 3.0 80 Plus Gold Power Supply:
- ATX 3.0
- 1200W power capacity
- 80 Plus Gold rating
- Modular form factor
Phanteks AMP GH 750W ATX 3.0 80 Plus Gold Modular Power Supply:
- ATX 3.0
- 750W power capacity
- Modular
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Phanteks-AMP-254x300.png)
![Kolink REGULATOR PSU Series 1000W](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-series-1000w-300x300.jpg)
Kolink Regulator 1200W 80 Plus Gold Modular Power Supply:
- ATX 3.0
If you want more details on ATX 3.0 power supplies, our dedicated blog article has all the information you need.
![ATX 3.0 Blog](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/2210-atx-3.0-PSUs-blog-300x300.jpg)
Compatible Adapter Cables
However, if you don’t have an ATX 3.0 PSU, you will need a secondary 12VHPWR adapter cable in order to truly utilise all your new hardware. Luckily, it’s usually included with your shiny new GPU. If it’s not, here are a few recommendations.
Corsair PCIe 5.0 12VHPWR PSU Power Cable:
- 12VHPWR adapter
- Rated for 600W
- PCIe 5.0
CableMod Pro ModMesh 12VHPWR Cable Extension Kit:
- Includes a 24-pin ATX extension, 8-pin EPS extension, 4+4 pin EPS extension, 16-pin to 3 x 8-pin PCIe extension, 8- and 4-pin hybrid cable combs, and a cable shroud
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Cablemod-12VHPWR-300x300.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/bequiet-12VHPWR-298x300.jpg)
be quiet! 12VHPWR PCIe Adapter Cable:
- 12VHPWR adapter
- PCIe 5.0
- Rated for 600W
Learn More About Power Supplies
Have You Upgraded to 12VHPWR?
If you’ve upgraded to the RTX 40 Series, ATX 3.0 PSU, and 12VHPWR connectors, be sure to leave your thoughts and any building tips and tricks you have in the comment section below!
If you can not afford a top RTX card
try to learn and know all this.
Because one day you might be able to.
#goals
Hi, I though 4000s where PCIe 4.0 not 5.0 as listed above?
Thanks for flagging – that has been updated now 🙂
