Last year, we had a look at 22 accessories all PC gamers will want. Well, it’s one year later so we’re taking things to the next level, with a fresh batch of 23 incredible PC gaming accessories. Whether you need to go big for streaming or need something new to show your setup off on socials, we’ve got plenty here at Overclockers UK for you in 2023.
![23 gaming pc accessories for 2023 blog feature image](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/23-pc-gaming-accessories.png)
A Gaming Chair That’s More Than Meets the Eye
It’s been a good year for Transformers fans, and these gaming chairs will make it even better! This trio of thrones from Nitro Concepts lets you show your Cybertronian pride in style. Pick from designs inspired by the heroic Autobots, the villainous Decepticons, or legendary hero and commander Optimus Prime.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/04/nitro-concepts-x1000-gaming-chair-transformers-autobot-edition-front-300x300.png)
Nitro Concepts X1000 Gaming Chair – Transformers Autobots Edition
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/04/nitro-concepts-x1000-gaming-chair-transformers-optimus-prime-edition-front-300x300.png)
Optimus Prime Edition
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/04/nitro-concepts-x1000-gaming-chair-transformers-decepticons-edition-back-front-300x300.png)
Nitro Concepts X1000 Gaming Chair – Transformers Decepticons Edition
Wakanda Forever!
Speaking of thrones, here we have one fit for a king! The noblechairs HERO Gaming Chair Marvel’s Black Panther Edition lets you sit as proudly as T’Challa himself. But that’s not all! There’s a matching Memory Foam Pillow Set that all true Black Panther fans will want to glow up their gaming chair.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/HERO-Black-Panther-Gallery-Picture_01-2000x2000-064a3d6-300x300.png)
noblechairs HERO Game Chair Marvel’s Black Panther Edition
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/noblechairs-pillow-set-black-panther-300x300.png)
noblechairs Memory Foam Pillow Set Marvel’s Black Panther Edition
Are You Sitting Comfortably?
But those aren’t the only noblechairs products we’ve picked out from the Disney vault! Following all the incredible Marvel and Star Wars gaming chairs that have been produced recently, matching pillow sets are now available! Whether you have a complimentary seat already or just want to add one of your favourite characters to your existing throne, these pillow sets add plenty of comfort and style.
![noblechairs Memory Foam Pillow Set Iron Man Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/noblechairs-pillow-set-iron-man-with-box-300x300.png)
![noblechairs Pillow Set Spider-Man Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/noblechairs-pillow-set-spider-man-with-box-300x300.png)
noblechairs Memory Foam Pillow Set Spider-Man Edition
![noblechairs Memory Foam Pillow Set Darth Vader Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/noblechairs-memory-foam-pillow-set-darth-vader-edition-300x300.png)
![noblechairs Memory Foam Pillow Set Stormtrooper Edition - White](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/noblechairs-memory-foam-pillow-set-stormtrooper-edition-300x300.png)
![noblechairs Memory Foam Pillow Set Boba Fett Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/noblechairs-memory-foam-pillow-set-boba-fett-edition-300x300.png)
Stream On You Crazy Diamond
When the Streamplify brand launched last year, it already had plenty of amazing accessories to support aspiring and veteran streamers alike. Now there are even more amazing products in this range to amplify your stream!
First up is the Streamplify HUB DECK 5 USB Hub. This five-port hub features power charging and some dazzling RGB lighting plus LED indicators once each port. There are four USB 3.0 ports and one USB 2.0A port, along with seven swappable keycaps to denote the function of each. With all that and a cable clip, keeping your streaming setup organised will be a breeze! Not enough ports for you? Then go bigger with the HUB CTRL 7 USB Hub!
![Streamplify HUB DECK 5](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/streamplify-hub-deck-5-angled-300x300.png)
Streamplify HUB DECK 5 RGB USB Hub with Power Charging
![Streamplify HUB CTRL 7 USB Hub](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/streamplify-hub-ctrl-7-3-300x300.png)
Streamplify HUB CTRL 7 USB Hub with RGB LEDs and 2.0A Charging
Do your production values need a lift? Streamplify has plenty for that. The MOUNT ARM is equipped with a cold shoe mount rail compatible with cameras, microphones, lights, and more! Position it however you need with its 360° rotating swivel and 210° adjustment angle to get the perfect shot. There are also new ACOUSTIC PANEL packs to help you keep background noise down and the new GLOW LIGHT 14 for brightening things up with indirect lighting.
![Streamplify MOUNT ARM Mount Rail](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/streamplify-mount-arm-300x300.png)
![Streamplify ACOUSTIC Panels](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/streamplify-acoustic-panel-300x300.png)
Streamplify ACOUSTIC PANELS
![Streamplify GLOW LIGHT 14 Ring Light](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/streamplify-glow-light-14-300x300.png)
Light It Up!
Another year, another amazing selection of gaming keyboards from Ducky! The One 3 Aura is simply gorgeous and gives us heart eyes in real life. Taking the Quack Mechanics philosophy these gaming keyboards are known for and applying it to a model that is primed for maximum RGB, the end results are stupendous. There are four sizes available, with enough colour and switch variants on top of that to fill up an edition of this list in a decade’s time. But to keep our picks to 23, we’ll just look at the size options of FS (100%), TKL (80%), SF (65%), and Mini (60%).
![Ducky One3 Aura Mechanical Gaming Keyboard Black UK Layout](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/ducky-one-3-aura-baby-kangaroo-keyboard-removebg-preview.png)
Ducky One3 Aura Mechanical Gaming Keyboard FS (100%)
![Ducky One 3 Aura Gaming Keyboard](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/ducky-one-3-aura-black-sf-angled-removebg-preview-300x300.png)
Ducky One3 Aura Mechanical Gaming Keyboard SF (65%)
![Ducky One 3 Aura TKL 80% Mechanical Gaming Keyboard Black Cherry Red Switch UK Layout](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/ducky-one-3-aura-tkl-keyboard-removebg-preview-300x300.png)
Ducky One3 Aura Mechanical Gaming Keyboard TKL (80%)
![Ducky One 3 Aura Gaming Keyboard](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/ducky-one-3-aura-black-mini-angled-removebg-preview-300x300.png)
Ducky One3 Aura Mechanical Gaming Keyboard Mini (60%)
Ready, Aim… Click!
Finally, we turn our attention to your gaming setup’s most trusted tool – the gaming mouse! If you like a splash of colour on that setup, then Glorious has a mouse or three for you. Straight from the Glorious Forge, the Model O Pro Wireless comes in three vibrant, eye-catching colours options; Red Fox, Blue Lynx, and Golden Panda. Whichever one is best suited to you will bring with it understated style and unparalleled performance.
![Glorious Model O Pro Gaming Mice](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/glorious-model-o-pro-lifestyle-300x300.jpg)
Finally, a gaming mouse that has a little buzz around it. The Endgame Gear XM2we has been doing the rounds with reviewers and getting a lot of praise. It’s easy to see why! Wireless, ultra-lightweight, dry grip coating, and up to 19,000 adjustable DPI – this gaming mouse really has it all.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/230523-Endgame-Gear-XM2we-Eshot-Banner.jpg)
Looking for More Inspo?
We have more accessory round-ups to help you craft the perfect gaming set-up!
2022
![22 Awesome PC Gaming Accessories You Will Want For 2022](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/22-accessories-square-300x300.png)
2024
![24 Awesome PC Gaming Accessories You Will Want For 2024](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/24-accessories-square-300x300.png)
What Are Your Must-Haves?
With so many awesome gaming accessories to be found in 2023, we would love to hear about what your go-to’s are! Have we missed out on any favourites? Let us know in the comments below.
