Are you looking to utilise the latest gen of tech to level up your performance? That’s where AMD 3D V-Cache comes in! This powerful cutting-edge technology revolutionises stacked cache design to deliver maximum performance, enhanced efficiency, and ultra-fast speeds. The perfect trio to power your favourite AAA games and content creation.
Have we got your attention? Keep reading for more details on 3D V-Cache and why you want it for gaming.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/3D-V-Cache-1024x1024.png)
What is AMD 3D V-Cache?
3D V-Cache is AMD’s powerful vertical stacked cache technology. It has been designed to allow compatible X3D processors to access even more cached memory to deliver ultra-fast fetch rates and increased cache capacity. Everything you need to unlock maximum performance and efficiency in your favourite AAA games and creative workloads. All with reduced latency and minimal load times. What more do you need?
How Does AMD 3D V-Cache Improve Your Gaming?
3D V-Cache promises to give your gaming a notable boost. Your gameplay won’t be plagued by slow loading times or latency. Instead, you can take advantage of fast fetch rates, increased cache memory, and optimised efficiency. All of which ensures lightning quick speeds and near-zero latency. This means you can turn your attention to defeating that deadly boss or securing your win.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/4K-Gaming-Blank-Overclockers-UK-Blog-Feature-Image-Bottom-Text-Blog-1600x900Light-TextTwitter--1024x576.jpg)
AMD 3D V-Cache Processors
There are three X3D processors in the AMD Ryzen 7000 Series. We’ve summarised the key specs of each in the table below.
Cores | Threads | Base speed | Boost speed | Cache | TDP | Socket | CPU Architecture | |
Ryzen 7 7800X3D | 8 | 16 | 4.2GHz | 5.0GHz | 104MB | 120W | AM5 | Zen 4 |
Ryzen 7 7900X3D | 12 | 24 | 4.4GHz | 5.6GHz | 140MB | 120W | AM5 | Zen 4 |
Ryzen 7 7950X3D | 16 | 32 | 4.2GHz | 5.7GHz | 144 | 120W | AM5 | Zen 4 |
Ryzen 7 7800X3D
The Ryzen 7 7800X3D is the perfect choice for those who want to achieve peak gaming performance. Powerful Zen 4 architecture along with a blend of 8 cores and 16 threads work seamlessly together to deliver ultra-fast speeds and optimised efficiency. Plus, with up to 104MB cache, unlock exceptionally quick load times with no latency disrupting your gameplay.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/AMD-Ryzen77800X3D-286x300.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/7900X3D-300x283.png)
Ryzen 7 7900X3D
Next up is the Ryzen 7 7900X3D. Optimised for AAA gaming and content creation, this processor harnesses 12 cores and 24 threads to achieve boosted speeds of up to 5.6GHz. What’s more, equipped with 140MB and support for AMD EXPO, enjoy enhanced efficiency and quick in-game load times.
Ryzen 7 7950X3D
Lastly, there is the Ryzen 7 7950X3D, the flagship model, primed for high-performance gaming and streaming. Thanks to 144MB along with 16 cores and 32 threads, capable of reaching up to 5.7GHz, this processor can handle demanding workflows at blisteringly fast speeds.
![AMD Ryzen 9 7950X3D Sixteen Core 5.70GHz (Socket AM5) Processor - Retail](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/AMD-Ryzen9-7950X3D-300x300.jpg)
In addition to this, there are two X3D models in the Ryzen 5000 Series.
Ryzen 7 5700X3D | 8 | 16 | 3.0GHz | 4.1GHz | 100MB | 105W | AM4 | Zen 3 |
Ryzen 7 5800X3D | 8 | 16 | 3.40GHz | 4.50GH | 100MB | 105W | AM4 | Zen 3 |
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Ryzen-5700X3D-CPU-300x271.png)
Ryzen 7 5700X3D
The Ryzen 7 5700X3D is perfect for enthusiasts looking for their next upgrade. Equipped with up to 100MB, enjoy quick in-game speeds and near-zero latency. Plus, the combination of 8 cores and 16 threads work perfectly together to deliver superior performance in gaming and streaming alike.
Ryzen 7 5800X3D
Crafted for phenomenal gaming and streaming is the Ryzen 7 5800X3D. Utilise Zen 3 architecture along with 100MB cache to achieve lightning fast speeds in all your single- and multi-threaded workloads.
Keepin’ It Cool
Maximum performance requires plenty of high-quality cooling to match. That’s why it’s vital you pair your X3D processor with a compatible AM4 or AM5 AiO.
These all in one coolers come equipped with enough thermal power to keep temperatures to a minimum, with both 240mm and 360mm options available. What’s more, you don’t have to compromise on aesthetics with models boasting integrated RGB lighting and even customisable LCD displays.
Gigabyte AORUS Waterforce II 360mm ARGB AiO CPU Cooler
- AiO CPU cooler
- 360mm radiator
- 3 x 120mm ARGB fans
- Compatible with AM5 socket
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Gigaybte-AORUS-AiO-300x258.png)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/06/Galahad-II-280-LCD-300x300.jpg)
Lian Li Galahad II LCD 240mm ARGB AiO CPU Cooler
- AiO CPU cooler
- 240mm radiator
- 2 x 140mm ARGB fans
Don’t Want to Build Your Own PC?
Is the idea of building your own PC too daunting? Don’t worry, you can still harness AMD 3D V-Cache with one of our high-quality gaming PCs. We’ve got plenty of systems boasting one of these incredible processors to level up your gaming and content creation.
Check out our top picks below.
Refract Gaming Ultraviolet Pre-Built PC
- Pre built gaming PC
- Designed for 4K enthusiast gaming and content creation
- Includes AMD Ryzen 9 7950X3D CPU and NVIDIA RTX 4090
- 32GB DDR5 RAM
- 2 x 1TB M.2 SSD
![Refract Gaming Ultraviolet 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-ultraviolet-hero-300x300.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/OcUKGaming-ZirconiumIce-286x300.jpg)
OcUK Gaming Zirconium Ice Configurable PC
- Configurable gaming PC
- Customisable base hardware specification
- As standard includes AMD Ryzen 7800X3D and Sapphire Radeon RX 7800 XT GPU
- 32GB DDR5 RAM
- Optional secondary SSD
OcUK Gaming Scimitar Configurable PC
- Adjustable base hardware specification to suit your favourite games, gameplay style, and more
- As standard includes AMD Ryzen 7 7800X3D CPU and NVIDIA RTX 4080 Super
- 32GB DDR5 AM
- Option to add secondary SSD
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/OcUKGaming-Scimitar-274x300.png)
Have You Utilised 3D V-Cache?
Have you utilised 3D V-Cache? How has this feature levelled up your performance? Let us know in the comments.
*Prices correct at time of writing and PC specs are subject to change.
