The big day is finally here – it’s 8Pack Day 2024! To celebrate this year, we’re showcasing 8Pack’s incredible advancements in the world of PC hardware.
Catch Up With 8Pack
If you want to catch up with all things 8Pack, be sure to check out the Overclockers UK blog for more!
Cutting-Edge 8Pack Tech
There are numerous elite-tier 8Pack PCs, each one boasting incredible cutting-edge tech and outstanding aesthetic advancements, from custom water-cooling loops to tailor-made and even wall-mounted cases.
We’ve picked out a few of our favourite 8Pack PCs that we think deserve a shoutout below.
8Pack Frame R8i
The 8Pack Frame R8i features the revolutionary open-air wall-mounted Mini-ITX case. Designed by Creative Solutions for Gamers, this incredible case mounts directly on your wall, freeing up extra space on your desk for your peripherals and accessories. All the powerful hardware is mounted onto a metal backplate and showcased through the tempered glass panel, complete with iconic 8Pack branding printed on the glass.
If the aesthetics of the 8Pack Frame R8i aren’t enough, this powerhouse PC has been optimised for high-performance gaming and content creation. Boasting an AMD Ryzen 7950X3D CPU, RTX 4090, and up to 64GB DDR5 RAM, each with a pre-configured overclock, this elite-tier PC certainly packs a punch.
8Pack ABS
Previously part of the Infin8 range, the 8Pack ABS has received a hefty update. Upholding its classic all black aesthetic, the ABS has been upgraded to feature plenty of the latest hardware and a custom hard-tubing water-cooling loop. Built harnessing bespoke premium hardware, this custom water-cooling expertly keeps temperatures to a minimum even under heavy loads.
The hard tubing has been engineered from matte black plastic and configured in clean straight lines to meet the stunning modern look of this PC. The coolant running through the thermal system is clear, expertly drawing heat away from vital components, whilst a combination of fans ensures a steady flow of natural air throughout the case.
8Pack Supernova MK3
The 8Pack Supernova MK3, previously showcased at Computex 2024, was also updated this year. This extreme powerhouse has been upgraded to reach a whole new level of performance, boasting a custom water-cooling loop, an AMD Ryzen Threadripper Pro 7995WX CPU, and seven RTX 4090 graphics cards!
The Supernova MK3 features the very best in graphical performance with seven (yes, seven!!!) RTX 4090 GPUs, each including a pre-configured overclock. Harness next-gen Ada Lovelace architecture to render your favourite games or creative workloads in stunning high resolution. Each GPU features up to 24GB GDDR6 to facilitate enhanced efficiency across all your demanding applications. Custom water blocks attached to each graphics card keep temperatures to a minimum, ensuring you continue to enjoy peak performance.
8Pack Asteroid MK2
Small yet mighty, the 8Pack Asteroid MK2 is the ultimate Mini-ITX powerhouse. Armed with an NVIDIA RTX 4090 and Intel i9-14900K CPU, featuring a pre-configured overclock and two profiles, this PC can handle any single- or multi-threaded workload you throw its way. The blend of twenty-four cores and thirty-two threads makes this CPU perfect for high-octane AAA gaming, content creation, and multitasking. With two pre-configured overclocking profiles, you can freely switch between the two, depending on your workload or individual preferences.
All of which is installed within a custom-made Mini-ITX chassis. Complete with sleek mirror-finished aluminium and carbon fibre interior panels, this case perfectly embodies the futuristic aesthetic. If this doesn’t suit your style, you can freely customise the 8Pack Asteroid to ensure it perfectly matches your vibe. This includes opting for carbon fibre, bead-blasted aluminium, acrylic, or even Cerakote painted aluminium.
8Pack Domin8 Workstation
Last, but certainly not least, is the 8Pack Domin8. This outstanding workstation has been fine-tuned to deliver the very best in performance. Packed with flagship-class hardware, including an Intel Xeon W9-3495X CPU and two NVIDIA RTX 4090 GPUs, this elite-tier PC can handle any demanding workload, from content creation and image rendering to video editing. 256GB of DDR5 RAM, arranged in an octo-channel configuration, ensures virtually zero loading times or input lag.
As a powerhouse workstation, the 8Pack Domin8 comes packed with plenty of premium-quality storage. Featuring a blend of SSDs and HDDs, there are a total of five storage drivers, totaling a hefty 48TB of storage! All this hardware has been installed within a Corsair 1000D Super Tower PC Case, which has been modified to further suit both the aesthetic and demands of this hardware. Our team of experts have added dual-PSU functionality, Cerakote painted panels, and hexagonal cutouts on the front panel to facilitate enhanced airflow, along with iconic 8Pack branding.
Can’t Get Enough of 8Pack?
Have you got heart eyes for 8Pack’s incredible range of elite-tier PCs? (We don’t blame you!) If so, you can browse the full selection of 8Pack PCs and workstations by clicking the button below.
How Will You Be Celebrating?
How will you be celebrating 8Pack Day 2024? Will you be treating yourself to a shiny new 8Pack PC? Let us know your plans in the comments.
*Prices correct at time of writing and PC specs are subject to change.
