The 8Pack Supernova is back with a brand-new aesthetic and the phenomenal hardware fitting of a Supernova MK3 update.
![8Pack Supernova MK3: Taking Performance to Cosmic New Heights](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/06/240521-8PACK-Supernova-MK3-Eshot-1-1024x1024.jpg)
The 8Pack Supernova has always packed a punch, but that has been taken to cosmic new heights with the MK3 update. We’re talking flagship AMD Threadripper CPU, 512GB RAM, and seven RTX 4090s! Oh, and it’s overclocked. This extreme PC is going to have more processing power than you’re going to know what to do with!
8Pack Supernova MK3 411
So, that absolutely wasn’t a typo before when I said seven graphics cards. The 8Pack Supernova MK3 is a beast.
First of all, this PC has an AMD Ryzen Threadripper Pro 7995WX CPU, boasting 96 cores, 192 threads, and a maximum stable overclock of 4.4GHz on all cores. If you’d like a moment to sit with those numbers, that’s cool. With this high-performance CPU, the 8Pack Supernova MK3 is primed for intensive workloads so you can work with greater efficiency and output.
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_cpu_cooling-1024x683.jpg)
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_memory-1024x683.jpg)
This is paired with Kingston 512GB 5600MHz DDR5 octo-channel RAM. Each channel has 64GB, exponentially increasing the bandwidth memory that the CPU has access to at any given time. Can you say “ultra-efficiency” five times fast?
Yes, now for that specification. The 8Pack Supernova MK3 is equipped with seven NVIDIA GeForce RTX 4090 GPUs. Not one, not two, but seven of them. Each overclocked to their maximum stable speed, these graphics cards provide the best in graphical and CUDA performance.
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_gpu_support-1024x683.jpg)
In addition to this powerhouse trifecta, the 8Pack Supernova sports a total of 24TB SSD storage, three PSUs, and a fully custom water-cooling system – but more on that last one shortly. Here is just a tasty overview of the 8Pack Supernova MK3’s specification:
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_panel_on-1024x1024.jpg)
Specifications |
AMD Ryzen Threadripper 7995WX CPU |
Kingston 512GB 5600MHz DDR5 octo-channel RAM |
7 x NVIDIA GeForce RTX 4090 GPUs |
2 x 4TB WD SN850X M.2 SSDs 3 x 8TB Samsung 860 QVO SSDs |
Custom water-cooling solution |
2 x ASUS ROG Thor 1600W 80 PLUS Platinum ATX PSUs 1 x Phanteks Revolt 850W 80 PLUS Platinum SFX PSU |
This £38,888 PC has 7 GPUs?! All about the 8PACK Supernova MK3
Custom Cooling
With all that high-power hardware, the 8Pack Supernova MK3 needs a cooling system that can keep up. Of course, it has exactly that. Fully custom with bespoke blocks and pumps, this water-cooling loop has been optimised to deliver efficient thermal performance.
It is a single loop but features two Nexalus pumps. This means the fluid pressure is harmonised throughout the system for consistent flow and optimised performance. The water blocks for both the CPU and GPU are made by Nexalus too, custom fit to each component to maximise compatibility and heat draw. For exhaust, there are three EK radiators, placed on the top, front, and bottom panels.
Naturally, it wouldn’t be an 8Pack PC without stunning, bespoke distro plates. The ones featured in the Supernova MK3 have custom machine billet aluminium bases and acrylic tops. With their sleek finish, they supply equal parts style and functionality to the PC.
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_ek_fan-1024x683.jpg)
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_bottom_distro-1024x683.jpg)
Shiny New Aesthetics
The MK3 brings with it a new aesthetic. Gone is the red and gold. Instead, the 8Pack Supernova MK3 sports a sleek, modern black and silver design. Now, I could keep telling you about how it looks, but I think it would be far more effective to just show you.
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_red_panel_on-1024x683.jpg)
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_brands-1024x683.jpg)
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_front_rad-1024x683.jpg)
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/Overclockers_8PACK_Supernova_distro-1024x683.jpg)
Introducing the 8Pack Supernova – The Ultimate Workstation
Bring This Power into Your Ecosystem
The 8Pack Supernova MK3 is available now from Overclockers UK. Taking a step away from the traditional 8Pack PCs, the Supernova MK3 doesn’t offer any upgrade options. But in all honesty, it’s already perfect 😍
8Pack Supernova MK3 Extreme PC
- AMD Ryzen Threadripper 7995WX CPU
- 7 x NVIDIA GeForce RTX 4090 GPUs
- 24TB storage and 512GB DDR5 RAM
- Incredible new aesthetics
- Three power supplies
![8Pack Supernova MK3](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/06/8pack_supernova_panel_hero-300x300.jpg)
PC specs are subject to change.
