Welcome to a new era of comfort. Introducing the noblechairs DAWN Series.
With a whole new outline and shape, advanced ergonomics, and lightweight construction, the noblechairs DAWN breaks the mould but still delivers the superior comfort we crave. Do you want to learn more about this impressive new line of gaming chairs? Well then, read on my friend!
noblechairs DAWN
The noblechairs DAWN is a brand-new gaming chair series, featuring a unique style, updated ergonomics, and a whole new set of premium build materials. Starting with its new shape, the noblechairs DAWN has taken a step away from the racer car seat style and opted for something more modern. The distinct panels are plush and padded, inviting you in for a comfortable experience that feels like it’s been custom fit to you. That’ll be the flexible polypropylene membrane, but more on that later. Right now, we’re here to admire the spicy new aesthetics.
Currently, there is one model in the noblechairs DAWN Series, the Black Edition.
noblechairs DAWN Gaming Chair Black Edition
- Ergonomic gaming chair
- Innovative flexible design
- Black Edition with high-tech vinyl leather
- Foldable armrests and integrated lumbar support
- Bold new style
Advanced Ergonomics
With a new design comes a fresh approach to ergonomic features. Don’t worry, the DAWN is still packed with all the superior comforts you could possibly want, they have merely been updated and adapted to suit the unique style.
Starting with the backrest, as well as its unique shape, it has a reinforced glass-fibre polyamide frame which provides incredible durability and flexibility. This is paired with the polypropylene membrane, the material which makes the backrest adapt to your form. As a result, you get custom support throughout your gaming session. Perfection.
On top of this, the backrest includes the adjustable lumbar support as seen on the HERO and LEGEND Series gaming chairs. Using the rotary knob on the side, the interior support can be configured to sit exactly where you need it.
A first for noblechairs, the DAWN has a height-adjustable seat base. You can manoeuvre it up or down, depending on your needs and desk set-up. Using this feature, you can ensure your feet are rest comfortably on the floor, which means there will be less pressure on your legs and better circulation. Win, win! What’s more, the seat base moves with the backrest thanks to a weight-activated synchro-lock mechanism. By moving in sync, you get better balanced comfort across your back and the lock enables you to recline down to the angle that suits you.
Finally, the DAWN has another new feature: foldable arm rests. Set in their upright position, these armrests provide a padded place to, well, rest your arms! If you need to save on a little save or tuck your chair snugly under your desk, then you can fold back the arm rests. What’s more, they adjust in height too, so they can be configured perfectly to your needs.
Premium Materials
Maintaining the high noblechairs standard, the DAWN Series is manufactured from premium materials by Italian automotive industry experts. The frame is a robust nylon, to maintain the lightweight construction while still providing great strength and durability. The base is also nylon, formed into a five-point shape to serve as a stable foundation. Each point features a 60mm caster made from nylon and polyurethane, ensuring they will seamlessly glide across both soft and hard flooring.
To provide plush comfort, the noblechairs DAWN is padded with dense cold-foam, chosen for its deform resistant properties. As a result, you can enjoy the same consistent comforts every time you sit in your throne. The chair is then upholstered in breathable material, which varies from model to model.
High-Tech Vinyl
Currently, there is one noblechairs DAWN Gaming Chairs in the line-up, upholstered in high-tech vinyl leather. This material has been specially treated to ensure it is highly breathable and comfortable with extended use.
Lightweight
Overall, the noblechairs DAWN has been designed to be lightweight, both in its materials and handling. This was purposeful to ensure all users can adjust and configure this chair with ease. While it does have an overall lighter mass, this gaming chair is still robust and strong. The Safety Class 3 gas lift is rated to support up to 110kg / 242lbs in weight.
A New DAWN
The noblechairs DAWN Series is now available to pre-order at Overclockers UK. Will you be experiencing this new era of comfort? Let us know in the comments below!
Stay Up to Date!
Keep your finger on the pulse for all things tech, by signing up to our Newsletter!
