![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/01/Kolink-Citadel-Glass-SE-Mob-1024x341.jpg)
Kolink returns with an update to their Citadel Mesh RGB. The Kolink Citadel Glass SE has an all-new tempered glass side panel, making for a more premium look. Indeed a pair of ARGB strips now bring illumination to the case out of the box. And a front USB 3.2 Type-C port has been added to the I/O panel to complement two USB 3.0 ports and an HD audio jack.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/01/CA05RKK_271955_750x750.jpg)
First and foremost however, RGB illumination is crucial to Kolink’s latest case. In addition to the lighting strips, there are three pre-installed ARGB LED PWM Fans. Also cycling through lighting configurations is a breeze thanks to a bundled controller.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/01/wrAgM98Q-1024x1024.jpeg)
One controller to illuminate them all
In fact Kolink also make available today the Inspire L1 ARGB Controller and the Inspire L2 RGB Controller. The L1 allows has been made for addressable RGB products, it is SATA powered, and is compatible with 5V 3-Pin ARGB devices. Meanwhile the L2, though also SATA powered, is made for 12V 4-Pin RGB devices. This means users can choose the controller best suited to their setup and enjoy total control of their build’s illumination.
