Joining the Infin8 line-up and carving a name for itself, we have the Infin8 Venomous. This gaming PC is packed with premium hardware, a mind-blowing aesthetic, and hyper-efficient thermal solution. Its stunning green and black style is going to cut a fine figure on your desk as you game, create, stream, and more. Get ready to have your socks knocked off.
![Infin8 Venomous](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/08/desktop-image-2208-infin8-venomous-1024x342.jpg.webp)
Stunning Aesthetics
Pairing black hardware with green lighting is a classic, yet striking look. It goes very nicely with the Nitro Concepts S300 Atomic Green Gaming Chair, too! The Infin8 Venomous goes one step further with its bold aesthetic, and I don’t mean the colour-matched CableMod braided cables and Acid Green EK Water Blocks coolant. I am on about the case. The HYTE Y60.
There’s been big buzz about this case and it is easy to see why. With the glass panelling seamlessly wrapping from the front to side, you get an uninterrupted view into the Infin8 Venomous interior. Panoramic. Instead of peering around the framework to feast your eyes on showstopping hardware, you can admire them in all their glory. Our design and tech team have done a marvellous job, from the vertical GPU to showpiece water blocks, this is a sleek build.
![Infin8 Venomous with Nitro Concepts S300 Atomic Green](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/infin8-venomous-aesthetics-1.jpg.webp)
![Infin8 Venomous](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/infin8-venomous-1.jpg.webp)
Colour-Matched Cooling
The Infin8 Venomous has a beautiful thermal solution, there is no doubt. What’s more, it is incredibly efficient and carefully designed to keep this gaming PC running at optimum temperature. A breeze when you have hardware from EK Water Blocks, Corsair, and Lian Li.
The flow is regulated by a D5 pump/reservoir combo, known for having efficient and reliable performance. The Acid Green coolant is fed through three water blocks via hard tubing. Both the CPU and GPU have dedicated water blocks, and the third one stands proudly at the front of the case. With a Corsair Hydro X Series 240mm radiator and six Lian Li UNI AL ARGB 120mm fans, heat is effectively vented from the system. On the whole, this system runs whisper quiet and looks good doing so.
![Infin8 Venomous CPU cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/infin8-venomous-cpu-cooler.jpg.webp)
![Infin8 Venomous interior](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/infin8-venomous-interior.png.webp)
High-End Hardware
Onto the tech specs. As expected with Infin8 gaming PCs, the Venomous is packed with premium, elite-tier hardware, designed to facilitate gaming at high resolutions, efficient content creation, and front-page-worthy streaming.
Its ASUS ROG Strix Z690-F Gaming WiFi Motherboard has support for DDR5, PCIe 5.0, and 12th gen Intel processors, creating an absolute beast of a foundation for this PC. Building on this, the Infin8 Venomous utilises an Intel Core i7-13700K CPU and NVIDIA GeForce RTX 4080 GPU. All your processing and gaming needs are in safe hands with this pair.
Alder Lake Intel processors feature a blend of performant and efficient cores, that expertly divide your PC workload up with the help of Windows 11’s Thread Director. As a result, you enjoy super streamlined computations. We all know how RTX 40 Series graphics cards are primed for gaming. Their Ada Lovelace architecture supports innovations such as real-time ray-tracing, AI DLSS, and game-ready drivers designed to enhance your experience. The RTX 4080 is no different.
![Infin8 Venomous interior](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/infin8-venomous-close.jpg.webp)
![Infin8 Venomous interior](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/infin8-venomous-angled.png.webp)
RAM, Storage, Power – You Need it All
Taking full advantage of the motherboard’s features, the Infin8 Venomous utilises DDR5 RAM. DDR5 has an updated channel structure, allowing for better access across the cache and therefore more efficient performance. Plus, it is blindingly fast too. This gaming PC has Corsair Vengeance Dual Channel RAM, either as 32GB at 5600MHz or 64GB at 5200MHz.
To grant you ample space for all your games, music, media files, creative projects, and so much more, the Infin8 Venomous has flexible storage options. As standard, it comes with a WD Black SN850 1TB NVMe SSD, with higher capacity models available to select. There are also optional secondary and tertiary storage slots for another NVMe SSD and a SATA SSD. The second NVMe slot offers a similar selection to the first drive, whereas the SATA models go all the way up to 8TB. If you maxed out capacity on each drive, you could enjoy 16TB of space. Perfect for storing all the back-ups of your streams.
Powering all this is a Seasonic Focus GX-850 Modular PSU. This supplies the Infin8 Venomous with 850W of power with 90% efficiency at half load. Thus, earning this power supply unit an 80 PLUS Gold rating. Plus, thanks to its modular design, only the necessary cables have been plugged in, keeping this showpiece PC tidy.
Make It Yours
Not content with providing a powerhouse PC, the Infin8 Venomous is also configurable. Here are all the changes you can make:
- Storage for days: Each NVMe storage option comes with six models of varying capacities and there is a selection of four SATA drives.
- Ramp up RAM: Choose between 32GB and 64GB of DDR5 RAM. Should you be using this PC for creative projects, the higher memory will help your workload-intensive programmes run smoother.
- Go Pro or go Home: The operating system for the Infin8 Venomous is Windows 11. Depending on your requirements, you can select either the Home or Pro edition.
- Cosmetic changes: Whilst the bold green and black aesthetic is impressive, if it’s not your thing then the coolant and cables can be modified according. Just in contact with our team ahead of purchasing on 01782 940193.
It should be noted that any changes to the Infin8 Venomous may affect price and lead time. Standard lead time for our prestige PCs is 20 working days. Obviously, during busy periods this will be affected, but our team will strive to meet these deadlines and keep you notified in the event of any changes.
What is the Infin8 Venomous Good For?
With its premium graphics card, high-capacity RAM, and top-tier CPU, there’s very little the Infin8 Venomous can’t handle.
![Stray artwork](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/Stray-Logo-2.jpg.webp)
For gaming, you can certainly enjoy your favourite games on max settings. Live your best feline life with Stray, taking in the beautiful details of the city and your robot friends. Tackle this year’s biggest soulslike game Elden Ring and go into every punishing battle with the highest resolutions. Anything for an advantage, right? Perhaps even step into the virtual reality with Hitman 3. The Infin8 Venomous is primed for all your gaming needs.
Taking this further, the Infin8 Venomous is a great machine to stream from. Not only will it look stunning on camera, but the selected hardware and additional options are far above what Twitch recommend for streaming. As a result, this gaming PC can handle the computation strain of live streaming as well as having what it takes to run your game. Paired with Streamplify hardware, streaming has never been easier. All you need to do is perfect your on-camera persona!
![Streamplify CAM lifestyle pic](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/07/streamplify-cam.png.webp)
![Vegas Pro Video Editing Software](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/vegas-pro-video-editing-software.jpg.webp)
When it comes to creative endeavours, the Infin8 Venomous is up to the task. Especially if you opt for the higher memory capacity. Whether you’re video editing or digitally rendering, this PC has the computational power to run creative software smoothly. Exclusively utilising SSD storage means loading times are reduced. Plus, the high-capacity options mean you can store creative projects for years to come!
Make Your Gaming Venomous
The Infin8 Venomous is available now to order at Overclockers UK. Will you be adding this gaming PC masterpiece to your set-up? What will you use it for? Drop a comment below and let us know!
Infin8 Venomous Gaming PC
- Configurable gaming PC inspired by 8Pack
- Housed in the HYTE Y60
- 13th gen Intel Core i7
- NVIDIA RTX 4080 GPU
- Stunning green and black aesthetic
![Infin8 Venomous](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/infin-venomous-main.png.webp)
Specs have been updated to reflect new hardware. 25/5/2023 All PC specs are subject to change.
