A legend in computer manufacturing, Alpenföhn have a new series of CPU coolers to bring effective and efficient performance to your gaming PC. Introducing the Alpenföhn Dolomit Series, featuring three CPU coolers packed with stunning features and tech to keep your PC at the optimum temperature.
![Alpengohn Dolomit Series CPU coolers](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/alpenfohn-dolomit-series-banner-1024x585.png.webp)
Meet the Line-Up
![Alpenföhn Dolomit 92mm CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/alpenfohn-dolomit-92mm-cpu-cooler-angled.jpg.webp)
First off, there is the Alpenföhn Dolomit 92mm which is perfect for SFF builds, where available space is a premium. This cooler measures 95mm x 152mm x 85mm and has a TDP of 160W. Armed with four 6mm heat pipes, heat is effectively drawn away from your CPU even during intense gameplay.
Secondly, there is the Alpenföhn Dolomit Advanced. This CPU cooler is a larger model with a 120mm fan, a 180W TDP, and integrated RGB lighting. Otherwise, it has a very similar make-up to the 92mm and is just as efficient with heat dissipation. Mid-tower cases with a tempered glass window will look great with this CPU cooler.
![Alpenföhn Dolomit Advanced CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/alpenfohn-dolomit-advanced-120mm-cpu-cooler-angled.jpg.webp)
![Alpenföhn Dolomit Premium CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/alpenfohn-dolomit-premium-120mm-cpu-cooler-angled.jpg.webp)
Finally, there is the Alpenföhn Dolomit Premium. This, too, is a 120mm model with RGB lighting and a 210W TDP. With more heat pipes, the Premium model is a great addition to any overclocked system, thanks to the enhanced thermal performance.
I’m a Fan
All three of these CPU coolers are equipped with the high-performance Wing Boost 3 fans – the 92mm version even won a bunch of awards. Thanks to their hydraulic bearing, they have great longevity whilst maintaining a static pressure of 2.19mm H2O. Entirely black, these fans bring outstanding performance to the Dolomit coolers. Plus, you can add an extra fan directly onto the cooler with the four clips provided, should you need an extra boost.
Keeping your Dolomit of choice firmly anchored, is the Rock Mount 3. Matching the black aesthetic, this blends neatly with your chosen aesthetic, in addition to securing your CPU cooler. All the necessary parts are included for peace of mind.
![Close up of the RGB lighting on the Alpenföhn Dolomit Premium CPU cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/Dolomi-Premium-12-1024x1024.jpg.webp)
German Engineering
A combination of choice materials and expert, German engineering, the Alpenföhn Dolomit Series have over ten years of experience behind them. Every aspect has been carefully curated to bring the absolute best thermal performance to your gaming PC.
![Alpenföhn Dolomit 92mm CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/alpenfohn-dolomit-92mm-cpu-cooler-side.jpg.webp)
The heat pipes have a large contact area with the highly conductive copper baseplate, facilitating extremely efficient drawing of heat away from your CPU. Further enhancing performance, the densely packed fins are manufactured from aluminium. Your gaming PC will have no trouble staying at optimum temperature with an Alpenföhn Dolomit CPU cooler.
Classic Aesthetic
The finishing touch to the Alpenföhn Dolomit Series is its classic black aesthetic. Perfect for a no-fuss build, the 92mm model will blend seamlessly into your gaming PC. The Advanced and Premium 120mm models, however, feature an aRGB ring on the cooler itself, adding a splash of colour to your cooling system. Interfacing via 3-pin aRGB headers, control the lighting from within your motherboard software and enjoy the dazzling show!
An Alpenföhn Dolomit For You
All three of these amazing CPU coolers are available right now, at Overclockers UK. Whether you are building in a small form factor or full-sized tower, we have the Alpenföhn Dolomit for you.
- Wing Boost 3 fan and Rock Mount 3
- 160W TDP
- Copper baseplate and aluminium fins
- 4 x heat pipes
- Capacity for second fan
![Alpenföhn Dolomit 92mm CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/alpenfohn-dolomit-92mm-cpu-cooler.jpg.webp)
![Alpenföhn Dolomit Advanced CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/alpenfohn-dolomit-advanced-120mm-cpu-cooler.jpg.webp)
- aRGB Wing Boost 3 fan and Rock Mount 3
- 180W TDP
- 4 x heat pipes
- 210W TDP
- 6 x heat pipes
![Alpenföhn Dolomit Premium CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/alpenfohn-dolomit-premium-120mm-cpu-cooler.jpg.webp)
