Looking to level up your gaming performance? Why not utilise NVIDIA’s ground-breaking AI-powered display technology, AI DLSS 3.0, to unlock stunning high-resolution visuals and buttery-smooth frame rates in all your favourite AAA games?
Here at Overclockers UK, we’ve compiled everything you need to know about DLSS 3.0 and why you need it to enhance your gaming performance.
What is AI DLSS 3.0?
AI DLSS 3.0, or Deep Learning Super Sampling, is the third generation of NVIDIA’s AI-powered display technology. It has been updated to combine DLSS Super Resolution, DLSS Frame Generation, and NVIDIA Reflex, to upscale all your images in hyper-realistic quality, along with notably boosting performance and responsiveness by up to four times.
By inserting additional in-game frames, that are backed up by integrated low latency technology, DLSS 3.0 delivers silky-smooth frame rates with virtually no latency, motion blur, or screen tearing.
In addition to this, games with vast heavy open worlds often require a lot of CPU power, so DLSS 3.0 also enables your GPU to render the game up to twice the frame rate of what your processor is capable of. For example, Microsoft Flight Simulator is known to be pretty demanding, especially due to its 1:1 recreation of the real world. However, even with the hefty requirements of MFS, DLSS 3.0 can still boost FPS by up to two times.
Why You Want AI DLSS 3.0 For Gaming?
AI DLSS 3.0 promises huge advantages for gamers looking to get the most out of their games. DLSS 3.0 allows you to play through your favourite titles with high-res visuals, smooth FPS, and ultra-fast responsiveness at up to 4K resolutions.
DLSS 3.0 Games
There are hundreds of DLSS 3.0 compatible games. This includes:
- Cyberpunk 2077
- Portal with RTX
- Marvel’s Spider-Man Remastered
- The Witcher 3: Wild Hunt
- Deliver Us Mars
If you want a closer look at how AI DLSS 3.0 looks in game, the video down below highlights just how good web-slinging and fighting crimes can look in Marvel’s Spider-Man Remastered.
Compatible AI DLSS 3.0 Graphics Cards
NVIDIA AI DLSS 3.0 is compatible with all the latest RTX 40 Series graphics cards. This includes:
- RTX 4090
- RTX 4080 Super
- RTX 4080
- RTX 4070 Ti Super
- RTX 4070 Ti
- RTX 4070 Super
- RTX 4070
- RTX 4060 Ti
- RTX 4060
You can read our dedicated guide all about the RTX 40 Series for all the information you need, including what you need to upgrade.
Why Not Upgrade to AI DLSS 3.0?
If you want to enhance your gaming with AI DLSS 3.0, we’ve included a few of our favourite compatible NVIDIA RTX 40 Series gaming PCs down below.
OcUK Gaming Khopesh Configurable PC
Equipped with all the latest gaming hardware, the OcUK Gaming Khopesh comes with everything you need for high-quality gaming and streaming, alike. This includes an AMD Ryzen 7 7700X, to deliver ultra-fast processing speeds, which is further enhanced by 32GB of DDR5 RAM. Wave goodbye to pesky slow loading times and input lag! What’s more, utilise the NVIDIA RTX 4070 Ti Super GPU to enjoy stunning photo-realistic visuals, along with immersive lighting and shadows. Plus, as an RTX 40 Series GPU, take advantage of NVIDIA’s suite of intelligent features, including DLSS 3.0 and Ray Tracing, to optimise your gaming experience.
The OcUK Gaming Khopesh is a configurable gaming PC, which means you can adjust the base hardware specification to suit your individual preferences. This includes customising the PC case, upgrading the processor, CPU cooler, and memory, along with opting for additional storage drives.
- Configurable gaming PC
- Includes AMD Ryzen 7 7700X and NVIDIA RTX 4070 Ti Super
- Up to 32GB DDR5 RAM
- Flexible storage options available
Infin8 Venomous Gaming PC
Inspired by legendary overclocker, 8Pack, the Infin8 Venomous is a beast of a powerhouse gaming PC. Completely water cooled, this high-end system comes equipped with all the hardware you need to enjoy ultra-fast AAA gaming. Harness the Intel 14th Gen CPU, built with the redefined hybrid core architecture, to unlock blisteringly fast performance and enhanced efficiency. In addition to this, take advantage of the NVIDIA RTX 4080 Super, to render all your favourite games in incredible hyper-realistic quality. Utilise NVIDIA’s suite of groundbreaking technology, including AI DLSS 3.0, to enjoy next-level immersive gaming.
This powerful hardware is kept cool and quiet thanks to the integrated water-cooling loop, designed utilising high-quality components from EK Water Blocks, complete with the acidic green liquid coolant. All of which you can show off with pride through the HYTE Y60’s panoramic glass panel.
- Inspired by 8Pack
- High-end water cooled PC
- Includes an Intel i7 14700K CPU and NVIDIA RTX 4080 Super
- Up to 64GB DDR5 RAM
- Sleek HYTE Y60 case
Refract Gaming Ultraviolet Pre Built PC
Level up your gaming potential with the Refract Gaming Ultraviolet PC. Armed with an AMD Ryzen 9 7950X3D CPU, unlock ultra-fast processing speeds in all your single- and multi-threaded tasks. Plus, with up to 32GB of DDR5 EXPO RAM, wave goodbye to pesky slow in-game loading times and input lag breaking up your immersion. Plus, AMD EXPO allows for simple high-speed overclocking, that is perfect for both beginners and veteran overclockers. What’s more, utilise the NVIDIA RTX 4090 GPU, with built-in support for cutting-edge Ray Tracing and AI DLSS 3.0, to unlock silky-smooth frames along with realistic lighting and shadows.
- Pre built gaming PC
- Includes an AMD Ryzen 9 7950X3D and NVIDIA RTX 4090
- Up to 32GB AMD EXPO DDR5 RAM
- 2 x 1TB M.2 SSD
Will You Be Using DLSS 3.0?
Have you used DLSS 3.0? Which games have you played? Be sure to let us know down below.
*Prices correct at time of writing and PC specs are subject to change.
