AMD Radeon Uncovered is back!
This time we’re shining the light on AMD FreeSync and how this intelligent technology can notably help to enhance your gaming performance and immersion.
What is AMD FreeSync?
FreeSync is AMD’s intelligent adaptive sync technology which enables your GPU or APU to fully control your monitor’s refresh rate. There are three versions available, each one expanding on the features included in the previous model.
AMD FreeSync
FreeSync delivers an immersive tear-free experience, facilitating smooth gameplay and video playback. Especially when paired with an AMD Radeon graphics card and HDMI/DisplayPort.
AMD FreeSync Premium
FreeSync Premium expands on the basics of FreeSync to unlock responsive, smooth, and stutter-free visuals which are sure to prove advantageous in the heat of battle.
AMD FreeSync Premium Pro
Premium Pro takes things to the next level by heightening image quality for HDR to facilitate ultra-realistic graphics and silky-smooth playback. Everything you need to immerse yourself in the latest blockbuster hit or AAA exclusive.
What Hardware Do You Need for AMD FreeSync?
You can utilise AMD FreeSync with a monitor, laptop, and even a TV. To do this, you’ll need to ensure that your device is compatible with the following requirements.
What’s more, you’ll also need a compatible FreeSync GPU or APU. This includes all the Radeon RX 2000 Series or above and NVIDIA GeForce 10 Series or higher (DisplayPort connectivity only).
If you’re unsure whether your NVIDIA GPU is compatible with AMD FreeSync, we’ve covered everything you need to know in our blog post.
How Does AMD FreeSync Improve Your Gaming?
By harnessing HDMI Variable Refresh Rate or DisplayPort Adaptive-Sync, AMD FreeSync delivers dynamic refresh rates to reduce screen tearing, display stutter, and input latency. As a result, you can enjoy incredible lifelike visuals with virtually no interruptions to your immersion.
In synchronising your refresh rate with your GPU’s FPS, you also won’t need to worry about any unexpected drops in frames. AMD FreeSync intelligently monitors your FPS to make sure it doesn’t dip below your refresh rate. If it does, FreeSync automatically stops working to ensure you continue to enjoy an optimised performance.
In Need of a PC Upgrade to Run AMD FreeSync?
Is your set-up not quite up to the task of running AMD FreeSync? At Overclockers UK, you can find a premium range of gaming PCs that utilise a compatible AMD graphics card and plenty more of the latest hardware.
We’ve rounded up a selection of our faves below, but if our top picks don’t quite suit your individual needs or aesthetic, you can explore all our AMD gaming PCs with the click of a button.
OcUK Gaming Kestrel Configurable PC
- Configurable gaming PC
- Adjustable base hardware specification
- AMD Ryzen 5 5500 and Radeon RX 7600
- 16GB DDR4 RAM
- 1TB M.2 SSD
OcUK Gaming Kite Configurable PC
- Customisable hardware spec to suit you
- AMD Ryzen 7 7700 and Radeon RX 7600
- Up to 16GB DDR5 RAM
- Optional M.2 and 2.5’’ SATA SSDs to choose from
OcUK Gaming Falcon Configurable PC
- As standard includes an AMD Ryzen 7 7700 and Radeon RX 7800 XT
- 32GB DDR5 RAM
- Windows 11 Home included
- 1TB M.2 SSD
OcUK Gaming Harrier Configurable PC
- Configurable base hardware specification
- AMD Ryzen 7 7700X CPU
- Compatible with AMD FreeSync
- Radeon RX 7700 XT GPU
- Up to 32GB DDR5 RAM
OcUK Gaming Condor Configurable PC
- Adjustable hardware to suit your needs
- AMD Ryzen 7 7800X3D and Radeon RX 7900 XTX
- 32GB DDR5 RAM
- Optional secondary storage drive
Learn More About AMD Graphics Cards
Do You Utilise AMD FreeSync?
Do you use AMD FreeSync? How has it enhanced your gaming performance? Let us know in the comments below.
*Prices correct at time of writing and PC specs are subject to change.
