We’re back with another article in our ‘AMD Radeon Uncovered’ series, designed to give you a deeper insight into all the cutting-edge tech available with AMD GPUs.
In this blog post, we’re covering AMD FSR, showcasing what it is and why you want it for gaming.
What is AMD FSR?
FSR, or FidelityFX Super Resolution, is AMD’s upscaling and frame generation technology which can notably help to enhance your frame rates and gaming experience. There are three versions of FSR currently available – FSR 2.0, 3.0, and 3.1
FSR 2.0
FSR 2.0 harnesses temporal upscaling to boost image quality, realistic visuals, and your frame rates to deliver a competitive edge over your in-game enemies.
FSR 3.0
FSR 3.0 utilises cutting-edge super-resolution temporal upscaling, advanced frame rate generation, and a built-in latency reduction to unlock incredible performance and render your games in glorious detail.
FSR 3.1
FSR 3.1, is equipped with powerful frame generation tech that delivers a notable boost to frame rates. In addition to this, there is a brand-new ‘native AAA’ mode to unlock stunning visuals and more realistic image quality. All with improved stability for more reliable performance and minimal display stutter or screen tearing.
What Games Support AMD FSR?
The supported games differ based on which version of FSR you are using. We’ve rounded up a selection of our faves for 2.0, 3.0 and 3.1.
FSR 2.0
  • Lies of P
  • Baldur’s Gate 3
  • The Invincible
  • Homeworld 3
  • Unknown 9: The Awakening
FSR 3.0
  • S.T.A.L.K.E.R. 2: Heart of Chornobyl
  • Frostpunk 2
  • Manor Lords
  • Starfield
  • The Last of Us Part 1
  • Ghost of Tsushima
FSR 3.1
  • Final Fantasy XVI
  • Call of Duty: Black Ops 6
  • God of War: Ragnarök
  • Spider-Man Remastered
  • Ratchet & Clank: Rift Apart
If you want to see the full list of supported games, you can click the button below for more details.
What Hardware Do You Need for AMD FSR?
To fully utilise AMD FSR, you’ll need to ensure you have a compatible graphics card.
RecommendedSupported
FSR 2.0AMD Radeon RX 5000 Series or above
NVIDIA GeForce RTX 20 Series or above
AMD Radeon RX 500 Series or above
NVIDIA GeForce GTX 10 Series or above
FSR 3.0
(With Upscaling and Advanced Frame Generation)
AMD Radeon RX 6000 Series or above
NVIDIA GeForce RTX 30 Series or above
FSR 3.0
(With Upscaling Only)
FSR 3.1AMD Radeon RX 6000 Series or above
NVIDIA RTX 30 Series or above
NVIDIA RTX 20 Series or above
How Does AMD FSR Improve Gaming?
Thanks to AMD FSR, you can enjoy notable improvements to both your in-game performance and visual quality. Powerful temporal upscaling and ray tracing facilitates realistic and high-definition images and videos, while intelligent frame generation delivers fast, smooth frame rates. Everything you need to immerse yourself in your gaming adventures or dominate all those pesky enemies!
In Need of a PC Upgrade for AMD FSR?
Are you looking to utilise AMD FSR but don’t quite have the required PC specs? At Overclockers UK, you can find a range of AMD gaming PCs that come packed with all the hardware you need to harness AMD FSR.
We’ve rounded up our faves below but if these don’t have your name on them, you can explore the full selection by clicking the button below.
OcUK Gaming Harrier Configurable PC
  • Configurable gaming PC
  • Customisable base hardware specification to suit your needs
  • AMD Ryzen 7 7700X CPU and Radeon RX 7700 XT
  • 32GB DDR5 RAM
  • Selection of M.2 and 2.5’’ SSDs to choose from
OcUK Gaming Harrier - AMD Ryzen 7 7700X, Radeon RX 7700 XT Gaming PC
OcUK Gaming Falcon - AMD Ryzen 7 7700, Radeon RX 7800 XT Gaming PC
OcUK Gaming Falcon Configurable PC
  • Adjustable base hardware specification
  • AMD Ryzen 7 7700 CPU and Radeon RX 7800 XT
  • 32GB DDR5 RAM
  • 1TB M.2 SSD
OcUK Gaming Condor Configurable PC
  • As standard includes an AMD Ryzen 7 7800X3D CPU and Radeon RX 7900 XTX
  • Optional secondary SSD
  • Windows 11 Home included
Learn More in AMD Uncovered
Do You Use AMD FSR?
Do you use AMD FSR? How has it helped to improve your gaming performance? Let us know in the comments below.
*Prices correct at time of writing and PC specs are subject to change.
5 1 vote
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
