Looking to expand your knowledge of your PC hardware? If so, you’re certainly in the right place for our AMD Radeon Uncovered series showcases all the incredible tech that comes with an AMD Radeon GPU.
In this blog post, we’re taking a deep dive into AMD Software: Adrenalin Edition, highlighting what it is, what hardware you need, and how this tech can notably help to boost your gaming performance.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/10/AMD-Uncovered-AMD-Software-1024x1024.png)
What is AMD Software: Adrenalin Edition?
AMD Software: Adrenalin Edition is an all-in-one graphics card software platform that optimises performance and grants users access to a plethora of must-have features designed to enhance gaming. These include AMD Anti-Lag, Fluid Motion Frames, Radeon Chill, Performance Tuning, and much more.
AMD Anti-Lag
AMD Anti-Lag intelligently controls your CPU workloads to prioritise them before your GPU in DirectX 9-12 to reduce any unwanted in-game lag and ensure minimal latency.
AMD Fluid Motion Frames
AMD Fluid Motion Frames (AFMF) is designed to increase your frame rates to deliver silky-smooth gameplay and optimised performance. Compatible with a wide range of popular titles including Baldur’s Gate III and Forza Horizon 5.
AMD Radeon Chill
Keep your PC or laptop cool and quiet thanks to AMD Radeon Chill. Adaptive power settings intelligently manage your frame rates based on your in-game movements to facilitate optimum temperatures and near-silent operation.
AMD Performance Tuning
AMD Performance Tuning offers easy-to-do GPU overclocking, ensuring you get the most out of your GPU. With support for both overclocking and undervolting, freely configure fan speeds, clock speeds, and more to boost your performance even further.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/08/4K-Gaming-Blank-Overclockers-UK-Blog-Feature-Image-Bottom-Text-Blog-1600x900Light-TextTwitter--1024x576.png)
What Hardware Do You Need for AMD Software: Adrenalin Edition?
To fully utilise AMD Software: Adrenalin Edition, you’ll need to ensure your gaming PC meets the minimum requirements. We’ve highlighted these below.
Minimum |
Windows 10 |
AMD Radeon RX 7000, 6000, 5000, 500 Series, RX Vega Series, Radeon VII, Radeon R9 Fury Series, or Radeon R9 Nano Series |
8GB of RAM or higher |
4GB or more available space |
1080p resolution or higher |
How Does AMD Software: Adrenalin Edition Improve Gaming?
AMD Software: Adrenalin Edition comes equipped with a plethora of must-have features that are sure to revolutionise the way you game. With this innovative software, you can easily fine-tune how you want your GPU to perform, whether this is through overclocking, undervolting, or enhancing your FPS, to get the most of out your graphics card. All through one easy-to-use platform.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/How-to-Choose-a-Gaming-PC-Blank-Overclockers-UK-Blog-Feature-Image-Bottom-Text-Blog-1600x900Light-TextTwitter--1024x576.jpg)
What’s more, rendering your favourite games at incredible resolutions doesn’t mean you have to compromise. AMD Software: Adrenalin Edition elevates this by offering integrated temperature management controls and features designed to minimise lag. This means you can concentrate on dominating your in-game enemies instead of any high temps or unwanted display stutter.
Looking to Utilise AMD Software: Adrenalin Edition?
Are you looking to take advantage of AMD Software: Adrenalin Edition? In need of a compatible PC to harness this incredible tech? We’ve rounded up a selection of our top PCs available at Overclockers UK that come equipped with all the hardware you need to utilise AMD Software: Adrenalin Edition.
However, if our top picks don’t suit your aesthetic or in-game demands, you can also explore all our AMD gaming PCs by clicking the button below.
OcUK Gaming Harrier Configurable PC
- Configurable gaming PC
- Adjustable base hardware to suit your needs
- AMD Ryzen 7 7700X CPU and Radeon RX 7700 XT
- 32GB DDR5 RAM
- 1TB M.2 SSD
- Optional M.2 and 2.5’’ secondary SSDs
![OcUK Gaming Harrier - AMD Ryzen 7 7700X, Radeon RX 7700 XT Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/03/ocuk-gaming-harrier-2024-configurable-pc-300x300.jpg)
![OcUK Gaming Falcon - AMD Ryzen 7 7700, Radeon RX 7800 XT Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/ocuk-gaming-falcon-2024-pc-300x300.jpg)
OcUK Gaming Falcon Configurable PC
- Customise to suit your in-game demands and individual preferences
- AMD Ryzen 7 7700 CPU and Radeon RX 7800 XT
- 32GB DDR5 RAM
- Windows 11 Home included
OcUK Gaming Condor Configurable PC
- As standard includes an AMD Ryzen 7 7800X3D CPU and Radeon RX 7900 XTX
- 32GB DDR5 RAM
- 1TB M.2 SSD
- Optional secondary storage drive
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/OcUKGaming-Condor-283x300.png)
Learn More About Your AMD GPU
Do You Use AMD Software: Adrenalin Edition?
Do you use AMD Software: Adrenalin Edition? How has it helped to boost your gaming performance? Tell us in the comments below.
*Prices correct at time of writing and PC specs are subject to change.
