After the release of AMD’s flagship CPU, the Ryzen 7 5800X 3D, Overclockers UK is here to tell you everything there is to know about this brand-new processor and AMD’s innovative 3D V-Cache technology.
A Gaming Flagship CPU:
The all-new AMD Ryzen 7 5800X 3D CPU is the latest innovation in gaming and PC hardware.
Considered the latest gaming flagship, the 5800X 3D expands on the 5800X by introducing 3D V-Cache technology, along with Zen 3 architecture.
Key Features of the AMD Ryzen 7 5800X3D:
- Built with Zen 3 architecture
- 105W TDP
- Eight Cores / 16 Threads
- Capable of handling single and multi-threaded tasks
- Base clock of 3.4GHz
- Precision Boost 2 can increase this to 4.5GHz
- Compatible with PCIe Gen 4 and DDR4 RAM
- Large cache memory (100MB), thanks to the 3D V-Cache
What is AMD’s 3D V-Cache Technology?
AMD’s 3D V-Cache is an innovative 3D vertical cache design that redefines both the capacity and speed of your PC.
To keep it short and sweet, the cache serves as a small, integrated amount of memory on the CPU itself. Its purpose is similar to that of RAM, as it will perform and remember certain tasks. However, as the cache is built into the CPU, there is a notable lack of loading times or input lag between different tasks being completed.
There are also different ‘levels’ of cache, ranging from level 1 to 3. In terms of the impact this has your PC’s performance, the higher this level is, the less capacity of memory you have but the faster the data transfer speeds are.
AMD’s 3D V-Cache technology enhances this one step further.
By stacking cache on the processor vertically, the capacity of the CPU memory is increased, without having to adjust the size of the CPU itself. Stacking allows for more cache to be built into one area, and by utilising only level 3, you can be ensured of ultra-fast data transfer speeds.
How does AMD’s 3D V-Cache Work?
In order to store additional cache on the CPU, the structure of the chips has had to be adjusted. This is achieved through Hybrid Bond 3D and Die Thinning.
Hybrid Bond 3D:
Hybrid Bond 3D serves as a multi-chip bonding algorithm and increases the overall bandwidth of data transfer speeds.
Along with this, hybrid bond 3D serves as an additional layer of thermal protection to ensure your CPU doesn’t overheat due to the stacked memory chips.
Die Thinning:
In order to ensure heat is effectively spread across the CPU without having to adjust its size, the CPU’s die has been thinned down.
How does this affect gaming?
The increase in data transfer speeds and L3 capacity means when gaming, your PC can notably process image and video rendering and frames a lot quicker, giving you the upper hand against your enemies. Especially in fast-paced FPS titles where every second counts.
This new 3D cache design, fast performance, and same reliable Zen 3 architecture can result in up to nearly a 15% increase in performance whilst gaming!
Upgrade Now to Next-Generation Gaming and 3D V-Cache:
AMD Ryzen 7 5800X 3D Cache Processor (CP-3D0-AM):
- 8 Cores / 16 Threads
- Zen 3 architecture
- 3D V-Cache technology
- 4.50GHz clock speed
