Anatomy of an E-ATX Gaming PC – Here’s What You Need
Want to build the E-ATX gaming PC of your dreams? Look no further as the Overclockers UK PC experts have compiled this ultimate guide on what goes into an E-ATX PC.
As part of our ‘Anatomy Of’ series, we’ll be focusing specifically on E-ATX gaming PCs, highlighting what components make up an E-ATX system, the pros and cons, along with our top hardware recommendations.
What is an E-ATX Gaming PC?
E-ATX stands for ‘Extended ATX’ and is the largest consumer form factor of PC. E-ATX gaming PCs typically utilise a motherboard that boasts an E-ATX form factor. However, these compatible cases can also accommodate boards in a range of different sizes, including Mini-ITX, Micro-ATX, and ATX.
Advantages and Disadvantages of an E-ATX Gaming PC?
Pros:
  • Space for more complex configurations, such as water-cooling loops and multiple GPU layouts.
  • Increased airflow – the additional space within the interior of the case allows for better natural airflow to help with cooling.
Cons:
  • Often more expensive than any other form factor.
  • Large form factor – not ideal for smaller office set-ups.
  • Hard to transport – the large size of the case makes them heavy and difficult to move around.
What Hardware is Compatible with an E-ATX PC Case?
If you are considering upgrading to an E-ATX gaming PC, you’ll need to ensure you have the correct size of hardware. We’ve searched high and low through the Overclockers UK website to give you our top hardware recommendations that are compatible with an E-ATX PC.
However, sizing does differ depending on the manufacturer and model. Therefore, you should always check the case specifications or manufacturer’s website to ensure all your chosen hardware is compatible.
The E-ATX Essentials
Case
All your gaming hardware needs a home. Our top full tower PC cases come equipped with everything you need to store your components along with boasting plenty of must-have aesthetics.
Lian Li V3000 Plus Black Full Tower PC Case
  • Full tower PC case
  • Supports three different modes – Standard, Rotated, and Dual systems
  • Compatible with up to E-ATX and EEB motherboards
  • GPU clearance of up to 589mm
  • Tempered glass panelling
Phanteks NV7 D-RGB White Full Tower PC Case
  • Supports up to E-ATX motherboards
  • GPU clearance of up to 450mm
  • Front and side tempered glass side panels
  • Integrated RGB lighting
Motherboard
At the centre of your PC, your motherboard is responsible for connecting all your hardware together. Whether you are on team AMD or Intel, we’ve picked out two E-ATX motherboards that are perfect for your next upgrade.
Asrock TRX50 WS (sTR5) Quad-Channel DDR5 E-ATX Motherboard
  • E-ATX form factor
  • sTR5 socket
  • Compatible with AMD Ryzen Threadripper PRO 7000 and 7000 Series
  • TRX50 chipset
  • PCIe 5.0
  • DDR5 RAM
ASUS ROG Maximus XIII Extreme (LGA 1700) DDR5 E-ATX Motherboard
  • E-ATX form factor
  • LGA 1700 socket
  • Z590 chipset
  • Compatible with DDR5 RAM
  • PCIe 5.0 support
Power Supply
No gaming PC is complete without a reliable PSU delivering a steady and consistent flow of power to your hardware. Our top selections are all equipped with a high 80 PLUS Rating to ensure maximum performance and efficiency.
Phanteks AMP GH 1000W 80 Plus Platinum Modular Power Supply
  • 1000W capacity
  • 80 PLUS Platinum rating
  • Modular form factor
Phanteks AMP GH 750W 80PLUS Gold ATX Power Supply Modular - Black
Kolink Regulator 850W 80 Plus Gold Modular Power Supply
  • 850W
  • 80 Plus Gold rating
The Must-Have Finishing Touches
RAM
Equipped with one of our high-quality RAM kits, your gaming PC will be able to handle all your demanding workloads with near-zero latency or input lag interrupting those critical boss battles.
Kingston FURY Beast 32GB (2x16GB) DDR5 Dual-Channel RAM Kit
  • 32GB (2x16GB) RAM capacity
  • DDR5 standard
  • Dual-channel configuration
  • 6000MHz
  • AMD EXPO compatible
Corsair Dominator 32GB (2x16GB) EXPO RGB DDR5 Dual-Channel RAM Kit
  • DDR5 standard
  • Compatible with AMD EXPO
  • 5600MHz
Graphics Card
Whether you opt for AMD or NVIDIA, these GPUs harness the latest generation of tech to render your gaming worlds in stunning quality, complete with smooth gameplay for an immersive gaming experience.
ASUS Radeon RX 7900 XT 20GB GDDR6 Graphics Card
  • AMD Radeon RX 7000 Series
  • RNDA 3 architecture
  • 2175MHz core clock speed
  • 2535MHz boosted clock speed
  • 20GB GDDR6 video memory
  • AMD RDNA 3 architecture
Gigabyte GeForce RTX 4070 Super 12GB GDDR6X Graphics Card
  • NVIDIA RTX 40 Series Super
  • Ada Lovelace architecture
  • 12GB GDDR6X video memory
  • 7168 CUDA cores
Storage
Ensure you’ve got plenty of storage space for your favourite games, creative projects, and more, with these high-quality M.2 SSDs. Powered by intelligent integrated memory chips, these storage solutions boast fast read and write speeds for minimal wait times.
WD Black SN850X 1TB M.2 NVMe PCIe 4.0 SSD
  • 1TB storage capacity
  • M.2 SSD
  • 2280 form factor
  • 7000MB/s read speed
  • 6300MB/s write speed
WD Black SN850X 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive with Heatsink (WDS200T2XHE)
Seagate FireCuda 540 1TB SSD PCIe Gen5 NVMe M.2 Solid State Drive
Seagate FireCuda 540 1TB PCIe 5.0 NVMe  M.2 SSD
  • M.2
  • 2280 form factor
  • 9500MB/s read speed
  • 8500MB/s write speed
Overclockers UK Ultimate PC Building Guide
Building your own gaming PC can be a daunting task. That’s why we’ve put together the Overclockers UK Ultimate PC Building Guide.
Read More in ‘Anatomy Of’
Does an E-ATX PC not suit your vibes? If so, take a look at all our other gaming PCs in our ‘Anatomy Of’ series to help you create your dream PC. We’ve covered all the way from Mini-ITX to ATX computers.
Anatomy of a Mini-ITX Gaming PC
Anatomy of a Micro-ATX Gamnig PC
Anatomy of an ATX Gaming PC – Here's What You Need!
4.5 2 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
