So far, Glorious PC Gaming Race has their Model O and Model D gaming mice, available in wired and wireless versions. Joining the line-up, they now have the Glorious Model I – complete with accessories. Balancing comfort and versatility, this gaming mouse features innovative technology as well as the iconic Glorious honeycomb aesthetic. If you’re in the market for a new gaming mouse, then this might just be the one for you.
Ascended Gaming
The Glorious Model I has everything you’d want in a gaming mouse. Lightweight structure, pinpoint accurate sensor, and stylish looks to boot. Equipped with Glorious’ own BAMF sensor, this gaming mouse has up to 19,000DPI which can be adjusted on-the-fly using the dedicated switch. There’s even an LED indicator embedded in the scroll wheel, so you can keep track of the sensitivity settings with a mere glance. With tracking speeds up to 400IPS and a 1ms response time, the Model I expertly tracks your hand movements across your gaming monitor.
At just 69g, you can pull off high-speed manoeuvres and quick flicks without the worry of fatigue. This mouse connects to your PC via USB 2.0 with a polling rate of 1000Hz, utilising a Glorious Ascended Cord. What’s more, the low friction sleeving reduces cable drag, keeping your movements free. Plus, this mouse is equipped with Glorious G-Skates, manufactured from premium PTFE for the smoothest glide across any gaming surface. The ultra-lightweight Model I is sure to give you a competitive gaming edge.
Versatility and Comfort
Overall, the Glorious Model I was designed to perfectly balance comfort and versatility, whilst still offering a highly competitive gaming mouse. It is a dextrous mouse, for the right hand, and has an ergonomically shaped shell with a thumb lip to support your hand. Even though it only weighs 69g, this mouse will fit most comfortably under medium to large hands.
That’s the comfort. For versatility, the Glorious Model I can be adapted to suit any type of game or play style. FPS, MOBA, MMO – you can play it with this mouse. This is thanks to the innovative, swappable side buttons. The third side button and large, separate pad are both held in place magnetically, allowing for their easy removal and replacement. Each Model I comes with six caps that will fit over these two buttons, three for each. They are sculpted and shaped to suit different play styles. As such, you can configure your Model I to perfectly match you way you play.
Make it Yours
To further the versatility of the Model I, this mouse can be configured with software. Adjust the DPI switch settings or remap every one of the nine available buttons. Between the swappable buttons and re-mapping, you can tailor the Model I to suit your exact needs, game type, and play style.
Finally, this gaming mouse is adorned with RGB lighting, shining through the iconic honeycomb design synonymous with Glorious gaming mice. There are eight pre-set effects that you can toggle through manually without software. Illuminate your mouse with a rainbow of 16.8 million colours.
Accessories Galore!
Alongside the Glorious Model I Gaming Mouse, there are three accessories available too. These are:
The Glorious Model I Mouse Grip Tape.
Specially designed and contoured to fit the Model I, this premium grip tape has been pre-cut and backed with 3M adhesive for ease of application. The slip-resistant textured material has sweat-wicking properties and a low profile. Both grip and comfort are maximised!
The Glorious Model I G-Skates.
Smoothly curved at the edges to prevent snagging, these skates are manufactured with 100% virgin PTFE. At 0.81mm thick, they have been optimised for comfort and longevity. Simply glide across your mouse pad.
The Glorious Model I Replacement Button Kit.
Should any of your hot-swappable buttons go walk-about, this replacement kit will have you covered. Featuring the same six magnetic buttons as the Model I, you can keep on tailoring your mouse. Specialise in FPS, modify for MOBA, or even mix and match to create a unique feel!
Time to Upgrade
The Glorious Model I Gaming Mouse is now available to pre-order from Overclockers UK. Drop us a comment below if this looks like your sort of mouse!
- Wired gaming mouse with swappable buttons
- BAMF sensor with up to 19,000DPI
- RGB lighting and iconic honeycomb shell
- Ultra-lightweight at just 69g
- Available in black or white
- Eight pieces
- Pre-cut with 3M adhesive backing
- Sweat-wicking properties
- Low profile 0.5mm thick
- slip-resistant texture
- Six pieces
- 100% virgin PTFE
- 0.81mm thick
- Highly durable
- Curved edges to prevent snagging
- Six magnetic buttons
- Hot-swapping technology
- Designed to suit different game styles
- Three pairs
- Glossy black
