Have you signed up for Secret Santa but have suddenly found yourself stuck on what to buy? If so- our Secret Santa gift guide is for you!
Suitable for any budget, we’ve put together a selection of some incredible gifts that are perfect for treating your friends, family, or colleagues.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/2212-xmas-secret-santa-feature-1024x1024.png.webp)
Gifts Under £5
Overclockers UK PBT Double-Shot Escape Keycap:
Treat your Secret Santa to an elite tier OcUK branded Escape keycap. This durable PBT double-shot keycap has been built with only the finest quality materials to deliver a smooth typing experience. The perfect addition to any fan of OcUK’s set-up, this keycap is available in either black or white.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/OcUK-branded-keycap-300x286.jpg)
- OcUK branded keycap
- Escape key
- Made from durable PBT
- Compatible with Cherry MX switches
- £1.09*
Glorious Lube Brush for Mechanical Switches:
Brush up on your Secret Santa gift giving with a Glorious Lube Brush. Perfect for if your Secret Santa is an avid DIYer and enjoys customising their mechanical keyboards! This lube brush has been designed for superior accuracy and comfort when applying lubricant to key switches and other keyboard components.
- For applying lubricant to key switches
- Ergonomic handle
- Anti-shed nylon brush tip
- £4.99*
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glorious-Lube-Brush-300x293.jpg)
Gifts Under £10
Overclockers UK Extreme XL Gaming Mug
The Overclockers UK Extreme XL Gaming Mug is the perfect desk companion. Capable of holding up to 450ml, it is perfect for storing all your much-needed beverages. It’s non-slip matte finish reduces the chance of any accidental spills, meaning you can concentrate on dominating your in-game enemies and workloads.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/OcUK-GamingMug-300x281.jpg)
- 450ml capacity
- Overclockers UK logo on both sides
- Non-slip matte finish
- £9.95*
OcUK Medium Mega Mat:
Keep your all-important gaming or work set-up well protected with the OcUK Mega Mat. Made from high-quality woven fibre, this mouse mat has been optimised for superior precision and control when used with an optical gaming mouse. There will be plenty of space for all your flicks and glides, as it measures 352mm x 255mm. No matter how aggressive your mouse movements are, the OcUK Mega Mat will remain firmly in place on your desk, thanks to the rubberised base.
- Tactical gaming surface
- 352mm x 255mm
- Made from woven fibre
- Optimised for optical gaming mice
- High-quality stitched edges
- £9.95*
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/03/ocuk-mega-mouse-mat-300x300.jpg)
Glorious Model O Gaming Mouse Grip Tape
Enhance your gaming performance with Glorious Model O Gaming Mouse Grip Tape. Compatible with only Glorious Model O Mice, this grip tape has been fine-tuned to help improve your grip for superior control over your mouse movements. The tape is pre-cut with adhesive backing to make installation a breeze.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/GloriousModelO-MouseTape-296x300.jpg)
- Compatible with Glorious Model O Gaming Mice
- 0.5mm thick
- Pre-cut tape
- Distinct texture for improved grip
- Adhesive backing
Gifts Under £15
CableMod Addressable 30cm RGB LED Strip:
Brighten up your Secret Santa with a CableMod aRGB 30cm LED Strip. Perfect for splashing some colour into a gaming or work set up, this LED strip features 15 individual aRGB LEDs and is compatible with any motherboard sporting a 3-pin RGB header. You can customise the colour and lighting effects through ASUS Aura Sync or Gigabyte RGB Fusion.
- aRGB 30cm RGB LED strip
- Compatible with ASUS Aura Sync or Gigabyte RGB Fusion
- £13.99*
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/CableMod-RGBLEDStrip-300x263.jpg)
Glorious Panda Toy Figure:
Put a smile on your Secret Santa’s face with the Glorious Panda Figure. At 3’’ tall, this vinyl toy figure features a key switch stem for decoration. It is the perfect companion to help get you through the work day or those crucial boss battles.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glorious-Panda-1-289x300.jpg)
- Vinyl panda toy
- 3” tall
- Key switch steam for decoration
- £13.00*
Glorious Black Mouse Bungee:
Free your Secret Santa from getting tangled or snagged with a Glorious Mouse Bungee. Designed to keep the wire firmly in place without slowing down all your critical flicks and glides during those intense boss battles.
- Mouse Bungee
- A must have accessory for cable management
- All black
- Rubber clamp
- £13.00*
![Glorious Mouse Bungee - Black (G-MB-BLACK)](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/glorious-mouse-bungee-300x300.jpg)
Gifts Under £20
OcUK Online £20 Gift Card:
If you’re lost for choice and just don’t know what to get your Secret Santa, why not treat them to one of our online gift cards? With these, your Secret Santa can select their perfect gift – whether it be premium PC hardware or high-quality accessories.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Gift-Card-300x240.jpg)
- Online gift card
- Worth up to £20
- £20.00*
Glorious Stealth Keyboard Wrist Rest:
The Glorious Stealth Keyboard Wrist Rest is perfect for keeping you supported and comfortable during your long gaming marathons or work days. Built with a plush soft foam interior and a smooth cloth exterior, this wrist rest has been designed to combat any wrist or arm ache. Measuring 36 x 10 x 1.3cm, this rest is compatible even with full-sized mechanical keyboards.
- Durable wrist rest
- Keeps you protected from wrist and arm aches
- Compatible with full-sized keyboards
- Soft plush interior
- Cloth exterior
- £19.99*
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glorious-Stealth-Wristrest-300x214.jpg)
Streamplify 10’’ Ring Light:
Spoil your Secret Santa with a 10’’ Streamplify Ring Light. With ten different brightness levels and three colour temperatures, you can guarantee they will always look their best. Perfect for streaming or working from home. To enhance any set-up one step further, this ring light comes with a smartphone holder, camera mount, and foldable tripod.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Streamplify-10Ring-270x300.jpg)
- 10” ring light
- Ten different brightness levels
- Choose between three colour temperatures
- Includes a smartphone holder, camera mount, and foldable tripod
- £16.99*
Important Christmas Cut Off Dates
![Postman Pack](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/postman-pack-square-300x300.png)
Christmas Delivery Cut Off Dates
Please note that the Christmas cut-off date for custom gaming PCs is December 1st 2024. Any systems ordered after this date aren’t guaranteed to arrive before December 25th 2024.
For more details and further delivery dates, please read our dedicated post.
*Prices correct at time of writing and are subject to change.
