With this summer already seeing record-breaking temperatures, it’s important that we keep both our PCs and ourselves cool. The last thing you need during extreme heat is your precious PC running hot too! To help you feel (and look!) cool, here at Overclockers UK we have scoured our website for the products best suited for the job. So, grab an ice lolly from the freezer, some deliciously chilled water, and come with us as we look at the coolest products.
![Ice creams, watermelons, and ice lollies](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/07/ice-cream-3148033_1280.jpg.webp)
Cooling Your PC
Obvious first step: cooling. We have an extensive range of air and water cooling products, from high-pressure fans to DIY cooling kits. Today I’m going to be highlighting the Lian Li Galahad II Trinity SL AiO Series. Available as 240mm and 360mm models, in both black and white, these all-in-one CPU coolers effortlessly blend style and thermal performance.
They feature high static pressure fans adorned with vibrant ARGB LEDs and flexible, braided tubing. Lian Li’s improved design has increased heat transfer efficiency and reduced dead zones on the radiator. This combines wider pipes, innovated fin stack design, and straighter tubing to significantly reducing friction from the coolant flow. In addition to this, the Lian Li Galahad II Trinity SL AiOs also feature high performance fans, engineered to work best with radiators.
All of this in a snazzy package – the Lian Li Galahad AiO Series looks as cool as it performs.
![Lian Li Galahad II Trinity SL AIO 240mm ARGB CPU Water Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/Lian-Li-Galahad-II-SL-INF.png)
Lian Li Galahad II Trinity SL 240 AiO CPU Cooler
- 240mm radiator
- ARGB lighting
- Compatible with Intel and AMD
- Improved design
- Flexible tubing
Airflow For You
Of course, we don’t expect you to feel jealous of your PC’s cooling system. We have some airflow for you, too! The Kolink Aero Dark Blue USB Desktop Fan is a compact thing, with ABS and polypropylene blades. These rotor blades efficiently whip up your own mini storm, to keep air flowing and temperatures down. It utilises a USB interface, allowing you to plug it into your PC or USB wall socket. Plus, this dinky fan is very portable thanks to its small size. If you switch between the office and working from home, you can easily take it with you.
- Compact table fan
- USB interface
- Brushless motor with three speeds
- On/Off switch
- Stylish blue finish
![Kolink Aero Dark Blue USB Desktop Fan](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/kolink-aero-dark-blue-fan-300x300.jpg)
Feeling Stormy with ThunderX3
Nothing breaks the hot weather like a cracking thunderstorm. Whilst we don’t possess the power to summon storms, we can provide you with the next best thing. A gaming chair from ThunderX3. Each model is equipped with their innovative AIR Tech, a pinhole design with premium foam and nonwoven materials to boost air circulation and breathability. As a result, you stay cool and fresh regardless of how long your gaming session is or how hot it is outside.
Plus, ThunderX3 gaming chairs come armed with a variety of ergonomic features such as reclining up to 180-degrees (angle, not centigrade, phew!) and adjustable armrests. Their range includes the XTC, TC3 and TC3 Max, BC1, EAZE, CORE, and TC5 and TC5 Max. Whilst budget-friendly overall, the TC3 and TC5 models are ThunderX3’s premium models, with the Max versions serving as XL gaming chairs. The newer EAZE and CORE series feature improved ergonomics and stylish designs. There is a ThunderX3 to keep you cool for everyone. Plus, they are available in a beautiful range of subtle colours!
![ThunderX3 TC5 MAX Gaming Chair White](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/thunderx3-tc5-max-white-300x300.jpg)
ThunderX3 Gaming Chairs
- Pictured: ThunderX3 TC5 All White
- Innovative AIR Tech feature for great comfort
- TC3 and TC5 available in XL Max models
- Models in black, red, white, and blue
- Adjustable ergonomics
Monitors
A legit tip for staying cool is to look at something cold. Why not take this psychological approach to the extreme with crystal clear graphics? With any of the gaming monitors available at Overclockers UK, you’re sure to be instantly transported somewhere cool every time you boot up your PC. To keep things simple, we’re highlighting a model with NVIDIA’s G-Sync and another with AMD’s FreeSync, so all graphics cards are covered.
First of all, the ASUS ROG Swift 27” PG27AQN Gaming Monitor. With its IPS panel, 1ms response time, and 360Hz refresh rate, you can enjoy fresh and clear displays. This monitor is equipped with HDR technology, creating a wider colour range and higher contrast than monitors without. Enjoy the frosty world of Monster Hunter World: Iceborne in stunning detail – that’s sure to make you feel a chill. Plus, with NVIDIA’s G-Sync you can say goodbye to screen tearing and hello to smooth gameplay.
ASUS ROG Swift 27″ PG27AQN Gaming Monitor
- 2560 x 1440 resolution
- 360Hz refresh rate
- 1ms response time
- IPS panel
- NVIDIA G-Sync
![ASUS ROG Swift Gaming Monitor](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/07/asus-rob-swift-pg259qn-monitor-300x300.jpg)
Alternatively, for those on Team Red there is the BenQ MOBIUZ EX2710Q 27” Gaming Monitor. Another IPS panel monitor, this is equipped with AMD’s FreeSync to prevent screen tearing and create smooth gameplay. Additionally, this monitor is armed with many gaming-primed features, such as Superior Sound by treVolo. Fully immerse yourself into the sub-zero soundscape of SnowRunner. Plus, with its flicker free feature, eye strain is reduced considerably.
![BenQ MOBIUZ EX2710Q 27" QHD 165Hz 1ms, FreeSync Premium Pro, HDRi IPS Gaming Monitor](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/benq-mobiuz-ex2710q-monitor-300x300.jpg)
BenQ MOBIUZ EX2710Q Gaming Monitor
- 165Hz refresh rate
- 1ms response time
- IPS panel
- AMD FreeSync Premium Pro
Refract
Moving on to looking the part, we come to Refract Gaming Pre-Built PCs. Perhaps you are already “summer ready” and have one of these expertly crafted PCs in your gaming set-up. If not, then our range of Refract Gaming PCs has been designed and built by the Overclockers UK tech team. There are six models in the line-up, each facilitating the various tiers of gameplay, from casual beginner to 4K pro.
The two to really push that cool aesthetic are the Jade and Celeste. The Jade features a fresh blend of green lighting whilst the Celeste is a crisp, light blue. Both perfect for creating cool ambiences that look incredible, and help you think you’re somewhere colder.
Each model has been crafted for 1080p and 1440p gaming, with the Jade featuring an NVIDIA GeForce RTX 3060 and the Celeste the 3060 Ti. Games such as Grand Theft Auto V and PlayerUnknown’s Battlegrounds are a breeze for these machines. Leave behind our summer in favour of Los Santos’ glamours or the chaos of battle royales.
Refract Jade Pre-Built Gaming PC
- Designed for 1080p/1440p gaming
- Fresh green lighting
- NVIDIA GeForce RTX 4060 Ti GPU
- AMD Ryzen 7 7700 processor
- Three years parts and labour warranty
![Refract Gaming Jade 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-jade-hero-300x300.jpg)
![Refract Gaming Celeste 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-celeste-hero-300x300.jpg)
Refract Celeste Pre-Built Gaming PC
- Crisp blue lighting
- NVIDIA GeForce RTX 4070 GPU
- AMD Ryzen 7 7700X processor
Keep Cool with the Summer Sale
The Overclockers UK Summer Sale will return in 2024.
![Summer Sale banner](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/06/2206-ocuk-summer-sale-Category-1024x222.jpg.webp)
PC specs are subject to change.
