![Jonsbo ITX Chassis A4 Banner](https://img.overclockers.co.uk/media/image/Jonsbo-A4-ITX-Chassis-PC-Case.png)
JONSBO might not be a company you’re familiar with but they have already established a strong reputation for producing high-quality PC cases and accessories within the Asian market. Thanks to over 10 years of manufacturing experience each Jonsbo case is designed to be innovative, attractive and affordable while maintaining excellent performance. The existing range is large with over 30 cases already available on the OCUK website HERE.
There are many different form factors available which are suitable for both epic show systems and simple home setups. The new A4 ITX case is the latest addition to the impressive line-up and is available in three sleek colour variants grey, silver and black. The small form factor and attractive chassis are sure to look outstanding in any PC setup.
![JONSBO A4 ITX side image with tempered glass](https://img.overclockers.co.uk/media/image/jonsbo_a4_side.png)
Amazing build quality and aesthetics
The A4 case has been cleverly designed to offer excellent hardware compatibility in a quality and compact form factor. There is a pleasant balance between form and functionality thanks to the dual chamber design which leaves enough space for a powerful and attractive PC system. The chassis’s neutral colour palette will complement any hardware displayed within the two tinted tempered glass side panels creating a show-stopping look.
The main material used to construct the chassis is an aluminium alloy, which is a premium material that further enhances the aesthetics and ensures the case is lightweight if it ever needs to be moved or transported. The internal black frame is constructed using 1.5mm steel which ensures stability and strength and the glass panels can easily be removed thanks to the screwless design.
![JONSBO A4 ITX side open view](https://img.overclockers.co.uk/media/image/jonsbo_a4_open.png)
Compact yet practical
Despite the small ITX size the A4 case has sufficient room and cooling properties to house a powerful PC build. The dual-chamber allows for a large dual-slot graphics card to be mounted on one side and other powerful hardware on the other including AIO CPU coolers. Airflow is managed by the ventilation holes found on the top panel which also have an eye-catching design.
The A4 can support up to a total of four 120mm fans and there is clearance for a 240mm radiator at the top of the case which means components are kept cool via vertical thermal convection. To prevent dust build-up within the case both the top and the bottom have removable high airflow filters which can easily be washed clean.
Additionally, you will find space for an SFX or SFX-L power supply, two 2.5” SSD’s, one 3.5“ drive and Mini ITX motherboard. The connectivity is kept simple with an IO interface consisting of just a power button and a USB 3.1 gen2 port with 10Gbps capability. Included with the case are a manual to aid installation of components, Magnetic removable feet and a durable ADT PCIe riser cable.
