Looking to level up your PC’s thermal performance in time for the RTX 50 Series? Check out our best coolers and fans for the NVIDIA RTX 50 Series that are sure to keep your gaming PC cool and whisper quiet.
The NVIDIA RTX 50 Series
The foundation of the NVIDIA RTX 50 Series is the all-new Blackwell architecture designed with powerful AI enhancements to deliver a serious uplift in performance. Whether you are gaming or creating, an RTX 50 Series GPU will render your images and videos at a rapid speed in cinematic quality, complete with stunning true-to-life detail. As you work or play, the onboard GDDR7 VRAM will have your back, facilitating quick transfer speeds, peak efficiency, and near-zero lag for an uninterrupted performance every time.
On the fence about whether a NVIDIA RTX 50 Series graphics card is for you? We’ve rounded up everything you need to know, including detailed break downs of each GPU over in our ultimate hub. Be sure to check it out!
NVIDIA RTX 50 Series Hub
What Cooling Do You Need for the NVIDIA RTX 50 Series
Your NVIDIA RTX 50 Series GPU will feature its own on-board cooling whether this is a dual- or triple-slot solution. However, this doesn’t mean that your PC and other components couldn’t do with a little extra thermal performance to ensure temperatures stay to a minimum and your computer performs whisper quiet. This can range from extra fans, air coolers, or even AiOs for your processor.
When you are selecting your GPU and cooling method, you’ll want to ensure your PC case has enough room for all your hardware. Your chassis will need to have a big enough GPU clearance to accommodate your chosen RTX 50 Series along with the room for all your fans and even multiple radiators, if that’s your thing. That’s why we recommend that you always consult with the specification of your case through either the manufacturer’s web page or product manual.
PC Modding with OcUK: Custom Water-Cooling
What’s more, you also need to consider the layout of your fans. Do you want to just use standard fans or perhaps even a combination of normal and reverse? It’s all down to personal choice but if you aren’t sure what these terms mean, we’re here to explain.
A reserve fan inverts the direction of air, pushing it the opposite direction of a standard fan. Reverse fans are especially helpful if you want to circulate air more evenly throughout your case and show off that RGB lighting since there’ll be no fan cage blocking your view. Alternatively, a standard fan does exactly what it says on the box. They blow air in one direction and utilise powerful static pressure to facilitate optimum temperatures.
Whatever cooling solution you choose, you’ll want to ensure it facilitates lots of natural air throughout your case, along with providing additional thermal support to the components that need it most. Any extra aesthetic touches are all down to personal preferences, but you can truly make your PC your own with customisable RGB lighting or adjustable LED screens which can display your favourite GIFs and more.
RTX 5090
Phanteks M25 Gen2 140mm DRGB High-Airflow PWM Triple Fan Pack - Black
Phanteks M25 Gen2 140mm DRGB High-Airflow PWM Triple Fan Pack – Black
COO-PHK-03096
★★★★★ (5)
£25.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
RTX 5080
Phanteks M25 Gen2 140mm DRGB Reverse Airflow PWM Triple Fan Pack- White
COO-PHK-03101
★★★★★ (5)
£25.99
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
Lian Li Galahad II LCD Performance AIO 280mm CPU Water Cooler - White
Lian Li Galahad II LCD Performance AIO 280mm CPU Water Cooler – White
COO-LIA-00530
★★★★★ (5)
£209.99 £ 144.95
-30.97%
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
RTX 5070 Ti
Phanteks M25 Gen2 120mm High-Airflow DRGB PWM Triple Fan Pack - White
Phanteks M25 Gen2 120mm High-Airflow DRGB PWM Triple Fan Pack – White
COO-PHK-02758
★★★★★ (5)
£25.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
ASUS ROG Ryujin III 240 ARGB Performance AIO CPU Liquid Cooler With OLED Display White - 240mm
ASUS ROG Ryujin III 240 ARGB Performance AIO CPU Liquid Cooler With OLED Display White – 240mm
COO-ASU-00535
★★★★★ (5)
£349.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
RTX 5070
Phanteks M25 Gen2 120mm Reversed Airflow DRGB PWM Triple Fan Pack - Black
Phanteks M25 Gen2 120mm Reversed Airflow DRGB PWM Triple Fan Pack – Black
COO-PHK-02761
★★★★★ (5)
£25.99
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
Noctua NH-D15 Chromax Pure Black CPU Cooler With Dual 140m Fans
HS-03M-NC
★★★★★ (5)
£109.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Looking to Upgrade in Time for the RTX 50 Series?
Best PC Cases for the NVIDIA RTX 50 Series
Best Motherboards for the NVIDIA RTX 50 Series
Learn More About Your PC Cooling
Air vs Water Cooling – What’s the Difference?
This is why you need water cooling in your PC
How Will You Be Keeping Your 50 Series GPU Cool?
How are you planning on keeping your RTX 50 Series GPU cool and quiet? Let us know in the comments below.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
