In the market for a tasty new gaming keyboard upgrade? If so, you’re in luck for we’ve rounded up our best gaming keyboards available right now at Overclockers UK.
We won’t keep you waiting any longer, and instead let’s jump straight to it!
Glorious GMMK 3 Pro 75% Pre-Built Gaming Keyboard
Enjoy unparalleled gaming performance with the Glorious GMMK 3 Pro Gaming Keyboard. Designed utilising premium build materials and a plethora of unique customisation, you can perfectly tailor your GMMK 3 Pro to suit your needs. Support for hot-swappable switches means you can freely swap between different models of key switches to find the set that matches your in-game demands and playstyle. As standard, this keyboard features Glorious Fox switches, fine-tuned to deliver smooth linear feedback with a super light 45g actuation force. What’s more, the Glorious GMMK 3 Pro includes durable Glorious GPBT keycaps arranged in a UK ISO layout.
Compatibility with Glorious CORE software means you can easily customise this keyboard to suit you, whether this is adjusting the three-zone RGB lighting for a synchronised light show or assigning individual key functions for on-the-fly control.
- Mechanical gaming keyboard
- Wired connectivity
- 75% form factor
- Hot-swappable
- Glorious Fox key switches
- Glorious GPBT keycaps
Ducky Zero 6108 White Wireless Gaming Keyboard
Harness the Ducky Zero 6108 Wireless Gaming Keyboard to enjoy an elevated typing experience. This keyboard boasts intelligent tri-mode connectivity, meaning you can utilise 2.4Hz, Bluetooth, or even USB wired – whichever suits the demands of your set-up more. If you opt for wireless, the 2500mAh rechargeable battery features a long battery life, allowing you to game on with no interruptions. What’s more, premium Cherry MX2A switches and double-shot PBT keycaps facilitate smooth and responsive typing, along with enhanced durability.
All your keypresses will be illuminated in stunning RGB lighting which you can configure to meet your chosen aesthetic. Plus, the three-stage stand boosts your ergonomics, ensuring you stay comfortable during your gaming marathons.
- Tri-mode connectivity – 2.4GHz, Bluetooth, and USB
- Full-sized form factor
- Hot-swappable
- Cherry MX2A Speed Silver key switches
- Double-shot PBT keycaps
Endgame Gear KB65HE Hall Effect Gaming Keyboard
Unlock gaming excellence with the Endgame Gear KB65HE Hall Effect Gaming Keyboard. This Hall Effect keyboard has been designed with esports and competitive gamers in mind, equipped with durable Gateron KS-37B key switches and intelligent Rapid Trigger technology. All of which work in sync to deliver ultra-fast response times and superior precision, everything you need to dominate the virtual battlefields.
What’s more, thanks to its compatibility with Endgame Configuration Software, you can further fine-tune the KB65HE to match your needs. This includes adjusting the actuation force, mapping key bindings, customising RGB lighting, and much more.
- Hall effect gaming keyboard
- USB wired connectivity
- 65% form factor
- Gateron KS-37B key switches
- UK ISO layout
Ducky One 3 Pro Nazca 60% Gaming Keyboard
The Ducky One 3 Pro Nazca Gaming Keyboard will revolutionise your typing experience. Harness all-new redefined Quack mechanics and powerful 8,000Hz polling rate to unlock next-level performance and blisteringly fast smooth typing. Capable of registering your keypresses up to eight times faster than the current standard, you can enjoy incredible responsiveness, near-zero input lag, and notably fewer missed keystrokes. No more missed critical hits during your boss battles!
Intelligent features, such as the integrated Webby Mat, facilitate whisper-quiet typing for improved acoustics, while the triple-shot PBT keycaps sport outstanding durability to withstand general wear and tear. Plus, their textured grip improves your grip, optimising your gaming experience even further. All of these are available with glorious RGB courtesy of the integrated backlight and intelligent south-facing PCB.
- 60% form factor
- USB connectivity
- 8K polling rate
- Cherry MX2A key switches
- Triple-shot PBT keycaps
Ducky Project D Tinker 75% USB Gaming Keyboard
The Ducky Project D Tinker 75% Gaming Keyboard comes equipped with everything you need to explore your favourite gaming worlds and dominate your in-game enemies. Constructed utilising only the highest-quality materials, such as ABS plastic, this keyboard sports an incredibly robust and durable design. The integrated Poron foam provides noise dampening to reduce any excess unwanted typing noise.
While the Ducky Project D Tinker is hot-swappable, this model comes equipped with Cherry MX Red switches and PBT double-shot keycaps as standard. These key switches are perfect for gaming and typing alike, delivering smooth linear feedback and light actuation of only 45g.
- Pre-built mechanical keyboard
- 75% form factor
- Hot-swappable
- Cherry MX switches as standard
- PBT double-shot keycaps
- Integrated per-key RGB backlighting
Shop All Keyboards
Do none of these keyboards suit your in-game demands? That’s no biggie! This is only a selection of the great gaming keyboards available at Overclockers UK. You can explore the full range by clicking the button below.
Still Searching for The Best Keyboard?
Share Your Keyboard Recs!
Did we include your favourite gaming keyboard on our list? Or perhaps we just missed it? Share your top keyboard recs in the comments below.
