Did you know you can get a great gaming PC for under £800?
![Best Gaming PCs for Under £800](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/800-pcs-mach-1-square-1024x1024.png)
While we’d all love to be able to sink unlimited funds into our gaming PC spec, sometimes other responsibilities take priority. Adulting, who signed us up for this?! That said, you can still achieve great gaming performance and stick to your budget. We’re taking a closer look at three PCs you can get from Overclockers UK for under £800. Spicy.
OcUK Gaming Jigsaw R1 Limited Edition Configurable PC
First up, we have the OcUK Gaming Jigsaw R1. It is important to note that this is a limited edition PC, so once it’s gone, it’s gone. This is not one to sleep on!
The OcUK Gaming Jigsaw R1 features an AMD Ryzen 5 5500 CPU, harnessing Zen 3 architecture, six cores, and twelve threads to deliver optimised gaming performance. This is paired with 16GB DDR4 RAM to keep processes efficient and smooth. The NVIDIA RTX 3060 GPU is more than capable of running mainstream and esports titles, rendering all your faves in photo-realistic quality thanks to AI-enhanced upscaling.
![OcUK Gaming Jigsaw R1 - AMD Ryzen 5500, RTX 3060 Limited Edition Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/ocuk-gaming-jigsaw-r1-pc-300x300.jpg)
The Jigsaw R1 Breakdown
Component | Specification |
Case | Kolink Observatory MX Mesh ARGB Midi Tower Case – Black/White |
Power Supply | 600W 80Plus Bronze Rated PSU |
CPU | AMD Ryzen 5 5500 Processor with 3.6GHz base clock, 4.2GHz boost |
Motherboard | AMD A520 DDR4 Motherboard |
Cooler | AMD Wraith Stealth Cooler |
Memory | 16GB DDR4 3600MHz Dual Channel Kit |
Graphics | NVIDIA GeForce RTX 3060 12GB GDDR6 Graphics Card |
Storage | 960GB 2.5″ SATA Solid State Drive |
Audio | 7.1 High Definition Audio |
Operating System | Microsoft Windows 11 64 Bit |
The Option to Configure
The OcUK Gaming Jigsaw R1 can be configured, which means you can adjust the spec to better suit your needs. The Jigsaw R1 offers different SSDs, operating systems, and optional add-on WiFi. Adjusting these can increase the £749.99 price tag up to £1,059.94, depending on what you select. However, this is maxing out the options and smaller changes can be made to still keep you within the under £800 budget.
OcUK Gaming Quartz Pre-Built PC
The OcUK Gaming Quartz is one of our pre-built PCs based on our best-selling specifications. Harnessing the first generation of hybrid core architecture, this PC utilises an Intel Core i5-12400F CPU with six cores, twelve threads, and boost speeds up to 4.4GHz. This is paired with 16GB DDR4 RAM to ensure low latency and smooth operations. Once again, the NVIDIA GeForce RTX 3060 GPU handles your gaming, expertly rendering a wide range of popular titles with Ampere architecture. Plus, the 1TB NVMe SSD will keep loading times down thanks to its impressive read and write speeds. Not to mention providing ample space for your gaming library!
![OcUK Gaming Quartz - Intel Core i5 12400F, RTX 3060 Pre-Built Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/04/ocuk-gaming-quartz-pc-300x300.jpg)
The Quartz Breakdown
Motherboard | Intel H610M DDR4 Micro ATX Motherboard |
Processor | Intel i5-12400F Processor Six Cores, Twelve Threads 4.4GHz Boost |
Case | Kolink Observatory MX Mesh ARGB Midi Tower Case – White |
Cooler | Intel Approved Cooler |
Graphics | White NVIDIA RTX 3060 8GB |
Memory | 2x8GB DDR4 3200MHz Dual-Channel Kit |
Power Supply | 600W 80 Plus Certified PSU |
Storage | 1TB 2.5″ Solid State Drive |
Operating System | Windows 11 Home 64-bit |
OcUK Gaming Mach 1 Pre-Built PC
The OcUK Gaming Mach 1 is another pre-built gaming PC, engineered to balance performance and affordability. Crafted for 1080p gaming, this PC sports an AMD Ryzen 5 5600 CPU, harnessing Zen 3 architecture, six cores, and twelve threads to expertly manage all your workflows. Once again, this is paired with 16GB DDR4 RAM, facilitating great efficiency while keeping that price tag low. To really give your gaming a boost, the Mach 1 features an NVIDIA GeForce RTX 4060 GPU, powered by third-generation RT cores and fourth-gen Tensor cores. With all the latest NVIDIA innovations under its built, this graphics card will render popular titles like Rocket League and Counter-Strike 2 with 440+ FPS* and 170+ FPS*, respectively.
![OcUK Gaming Mach 1 - Ryzen 5600, RTX 4060 Pre-Built Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/Overclockers_Mach_1_hero_blue-300x300.jpg)
The Mach 1 Breakdown
Motherboard | Gigabyte B450M DS3H WIFI Motherboard |
Processor | AMD Ryzen 5 5600 Processor Six Cores, Twelve Threads 4.4GHz Boost |
Case | Kolink Observatory HF Mesh ARGB Midi Tower Case – Black |
Graphics | NVIDIA GeForce RTX 4060 8GB GDDR6 GPU |
Storage | 1TB M.2 PCIe Solid State Drive |
*FPS benchmarks are provided as an intended guide and your results may differ.
Pre-Built Perks
Both the Quartz and Mach 1 are pre-built gaming PCs. This means they are built to an exact specification, with no variables on offer. The benefit of this is that they are fully assembled, tested, and ready to ship! Without having to wait for build time, these PCs can go from your shopping basket to your gaming desk in no time at all! Well, some time. Instantaneous travel is not a thing yet. However, if purchased before the cut-off point, they both qualify for next working day delivery. So, booyah.
Explore Our Full Range
If none of these gaming PCs fit your spec requirements, aesthetics, or general vibes, there are plenty more waiting to be discovered. We have an extensive range of gaming PCs – both configurable and pre-built – at a variety of price points. Your dream PC is amongst them.
Plenty More PC Inspo
Working to a different budget? We have plenty of gaming PC guides to help!
What’s Your Dream Spec?
If budget wasn’t an issue, what is your dream spec? Let us know in the comments below!
PC specs are subject to change. Prices were correct at the time of writing.
