When it comes to buying our gaming PCs, we’d love it if budget wasn’t an issue. Sadly, we have “grown up” responsibilities that eat our funds. Thankfully, Overclockers UK has an extensive range of gaming PCs to suit any budget. Today, we’re looking at gaming PCs that fall under the £2000 price point.
![Best Gaming PCs for Under £2000](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/2k-pcs-square-1024x1024.png)
Each is from our range of configurable gaming PCs, so there is some wiggle room on cost and spec for each of them. We have three gaming PCs under £2000 to showcase today, equipped with premium hardware that has been crafted for A-grade gaming.
OcUK Gaming Harrier Configurable PC
With a £2,000 budget, you can afford to spring for some of the latest gaming hardware. The OcUK Gaming Harrier has an AMD Ryzen 7 7700X CPU, from the AMD Ryzen 7000 Series. This utilises Zen 4 architecture, built on a five-star platform optimised for gaming and streaming. For its GPU, this gaming PC has an AMD Radeon RX 7700 XT GPU, wielding 12GB of GDDR6 video memory and RDNA 3 architecture to smoothly render all your favourite AAA titles with high frame rates.
![OcUK Gaming Harrier - AMD Ryzen 7 7700X, Radeon RX 7700 XT Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/03/ocuk-gaming-harrier-2024-configurable-pc-300x300.jpg)
The Harrier Breakdown
Component | Specification |
Motherboard | AMD B650 WIFI Micro-ATX Motherboard |
Processor | AMD Ryzen 7 7700X Processor with 8 Cores and Sixten Threads |
Graphics | AMD Radeon RX 7700 XT 12GB Graphics Card |
Case | Aerocool Dryft Mini v2 Micro-ATX Case |
Power Supply | 750W 80Plus Gold Rated PSU |
Storage | 1TB Gen 4 M.2 NVMe Solid State Drive M.2 and 2.5″ Solid State Drive Options |
RAM | 32GB DDR5 5200MHz Dual Channel Kit |
Audio | High Definition Audio |
Operating System | Microsoft Windows 11 64 Bit |
OcUK Gaming Rapier Configurable PC
Next, we have the OcUK Gaming Rapier which again harnesses Zen 4 architecture with an AMD Ryzen 5 7600 CPU. This processor boasts six cores, twelve threads, and boost speeds up to 5.1GHz, perfect for gaming, content creation, and streaming. Equipped with an NVIDIA RTX 4070 Super, the graphics card can bring your favourite games to life with real-time ray tracing that renders realistic lighting patterns. Plus, with high-speed DDR5 AMD EXPO RAM and an ultra-fast PCIe NVMe SSD, you can wave goodbye to input lag and slow loading times.
![OcUK Gaming Rapier - AMD Ryzen 5 7600, GeForce RTX 4070 Super Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/ocuk-gaming-rapier-kolink-case-configurable-pc-300x300.jpg)
The Rapier Breakdown
Motherboard | B650 ATX Motherboard |
Processor | AMD Ryzen 5 7600 3.8GHz (up to 5.1GHz Boost) Six Core Processor Other processors optional |
Graphics | NVIDIA GeForce RTX 4070 Super 12GB Graphics Card |
Case | Kolink Unity Meshbay ARGB Midi Tower Case |
Power Supply | 850W 80 Plus Bronze Power Supply |
Primary Storage | Your Choice of Gen 4 M.2 Solid State Drives Your Choice 2.5″ SATA Solid State |
RAM | 32GB DDR5 5600MHz Dual Channel Kit |
Audio | 7.1 High Definition Audio |
Networking | 2.5GB Gigabit LAN, WIFI6 |
OcUK Gaming Sabre Configurable PC
Pushing our budget to the limit, the OcUK Gaming Sabre utilises a 13th Gen Intel Core processor and DDR5 RAM. Harnessing advanced hybrid core architecture, the Intel Core i7-13700F CPU has sixteen cores (8P and 8E), twenty-four threads, and boost speeds up to 5.2GHz. Plus, Intel Thread Director will ensure the right core is assigned to the job, ensuring smooth operations in any workflow. This is paired with an NVIDIA GeForce RTX 4070 Super GPU, crafted to render your favourite AAA titles in high resolutions thanks to AI enhanced upscaling. What’s more, this gaming PC has a comprehensive storage solution to provide ample space for your entire gaming library, files, and music.
![OcUK Gaming Sabre Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/ocuk-gaming-sabre-pc-300x300.jpg)
The Sabre Breakdown
Motherboard | B760 WIFI DDR5 Motherboard |
Processor | Intel Core i7 13700F – Sixteen Core Processor with 5.2GHz Boost |
Graphics | NVIDIA GeForce RTX 4070 Super 12GB GDDR6 Graphics Card |
Case | Kolink Unity Lateral ARGB Midi Tower Case – Black |
Power Supply | 850W 80 Plus Gold Rated PSU |
Storage | 1TB M.2 Gen4 NVMe Sold State Drive Optional M.2 and 2.5″ Solid State Drives |
Cooler | 240mm ARGB AIO Liquid CPU Cooler |
Network | 2.5Gb LAN & WIFI 6 with Bluetooth v5 support |
Configure Them Your Way
The OcUK Gaming Harrier, Rapier, and Sabre are all part of our configurable gaming PC range, meaning you can adjust the base spec to better suit your budget and gaming needs. You can make changes to both the cosmetics and hardware, perhaps allocating more of your budget to the GPU or memory, whilst opting out of extra storage drives to keep the price down.
It should be noted that configuring the PC will affect the price, but all changes are shown in real-time so you can easily track how much everything costs. With the Harrier and Rarpier, you have a little more wiggle room when it comes to upgrading, as their price point starts with a couple hundred-pound margin from our £2000 limit. The Vulture, however, is priced at £1,825.00, so any configurations are likely to take you over.
Pre-Built Options Under £2000
The Overclockers UK gaming PC range includes pre-built computers with a fixed specification. They are engineered to provide outstanding gaming performance at a variety of price points. As such, we even have a few cheeky pre-built PCs that fit the “under £2000” bill.
Refract Gaming Jade
![Refract Gaming Jade 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-jade-hero-300x300.jpg)
OcUK Gaming Flourite
![OcUK Gaming Fluorite - Intel Core i5 14600KF, RTX 4070 Super Pre-Built Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/ocuk-gaming-flourite-pre-built-pc-300x300.jpg)
Refract Gaming Celeste
![Refract Gaming Celeste 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-celeste-hero-300x300.jpg)
Explore Our Full Range
Of course, this is just a snapshot of our gaming PC range. You can explore the full Overclockers UK selection across a range of budgets by clicking the button below.
Need More Help?
Budget smaller than £2,000? Not really sure how much a gaming PC should even cost? We could talk gaming PCs until the cows come home, so there are plenty more guides and showcases to help you with your decision. Here are a few blogs to get you started!
What’s Your Gaming PC Price Sweet Spot?
How much do you think is the right amount to spend on a gaming PC? Let us know in the comments below.
All PC specs are subject to change. All prices are correct at the time of writing.
