Next in our ‘Best Of’ week, we’re highlighting a selection of the best streaming hardware of 2022!
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/221228-Best-Streaming-Gear-of-2022-1024x1024.jpg.webp)
These must-have accessories have been designed to enhance your stream, and production level, along with wowing your audience.
Streamplify MIC:
Be heard loud and crystal clear with the Streamplify MIC Microphone. As a cardioid microphone, it is sensitive at the front whilst the sides and back have near-zero sensitivity. This ensures no unwanted background noise is picked up. Along with this, the Streamplify MIC features two different audio modes – full playback podcast and one-way playback gaming.
The full playback podcast mode will play your audio back, which will allow you to fine-tune your content to perfectly suit your needs. Whilst one-way playback gaming will remove any unwanted distractions, freeing you to concentrate on your audience and those crucial boss battles.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/Streamplify-MIC.jpg.webp)
- Cardioid microphone
- Two different audio modes – full playback podcast and one-way playback gaming
- Quick mute function
- aRGB lighting
- Mounting tripod and pop filter
Streamplify CAM:
You will always look your best with the Streamplify CAM Webcam. This 2.0-megapixel webcam records and captures images in full HD at 1080p with 60FPS. Equipped with a versatile clip, you can easily attach this webcam to your monitor, laptop, and even your desk – whichever angle works best for you!
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/Streamplify-CAM.jpg.webp)
- 2.0-megapixel webcam
- Records and captures in full HD at 1080p at 60FPS
- Privacy lenses
- Auto-focus and light enhancements
- Can be clipped onto monitors, laptops, and even desks
Streamplify LIGHT 14’’ Ring Light:
The Streamplify 14’’ LIGHT features ten different brightness levels and four colour temperatures for you to choose from. With a Colour Rendering Index (CRI) of ≧ 90, this 14’’ ring light boasts stunning natural and vivid lighting that will illuminate your stream beautifully. Equipped with a smartphone holder, two camera mounts, and a two-in-one tripod selfie stick, this 14” ring light is extremely versatile, and can even be used on the go.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/Streamplify-Ringlight.jpg.webp)
- 14” ring light
- Ten different brightness levels
- Four colour temperatures
- Includes two camera mounts, two-in-one tripod, and smartphone holder
Endgame Gear XSTRM USB Microphone:
Achieve perfect audio with the Endgame Gear XSTRM USB Microphone. This cardioid microphone includes a 20mm gold-plated electret condenser to provide a 192kMHz sampling rate for superior broadcast quality and crystal-clear audio. What’s more, the included pop filter, shock mount, and intelligent AI technology eliminates any unwanted knocks, bumps, or unwanted background chatter disrupting your audio.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/EndgameGear-XSTRM.jpg.webp)
- 20mm gold-plated electret condenser
- 192kMHz sampling rate
- Includes a pop filter and shock mount
Endgame Gear MICARM:
The Endgame Gear MICARM is the perfect companion to the XSTRM Microphone. Built from high-quality materials, it can bear up to 900g. This mic arm features three pivoting joints and a spring-loaded mechanism, both of which allow you to freely move and adjust the height or angle of your microphone. Whilst it has been designed for the XSTRM, the 5/8’’ and 3/8’’ threads ensure full compatibility with a vast range of microphones.
The Endgame Gear MICARM will clamp directly onto your desk, thanks to a durable grommet, which has a rubberised base to ensure it remains firmly in place, no matter how aggressive your gameplay gets.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/EndgameGear-Micarm.jpg.webp)
- Adjustable mic arm
- Designed for the Endgame Gear XSTRM microphone
- Bear up to 900g
- 5/8” and 3/8” threads ensure compatibility with a vast range of microphones
- Grommet clamp
Streamplify Bundles:
Streamplify STARTER Bundle:
The Streamplify STARTER Bundle features all the necessary equipment you need to start streaming. This includes a cardioid microphone, a 2.0-megapixel webcam, and a 10’’ ring light.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/Streamplify-STARTER.jpg.webp)
- Starter streaming bundle
- Includes a cardioid microphone, 2.0-megapixel webcam, and 10” ring light
Streamplify PRO Bundle:
Level up your stream with the Streamplify PRO Bundle. This bundle includes a cardioid microphone, a 2.0-megapixel webcam, and two ring lights. Along with this, the cardioid microphone features an adjustable mic arm that you can clamp onto your desk.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/Streamplify-PRO.jpg.webp)
- Pro streaming bundle
- Includes a cardioid microphone with adjustable mic arm, 2.0-megapixel webcam, and two ring lights
Streamplify COMPLETE Bundle:
Create the ultimate streaming experience for you and your audience with the Streamplify COMPLETE Bundle. Equipped with a cardioid microphone, 2.0-megapixel webcam, two ring lights, a green screen, and a USB hub.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/Streamplify-COMPLETE.jpg.webp)
- Complete streaming bundle
- Includes a cardioid microphone, 2.0-megapixel webcam, two ring lights, a green screen, and USB hub
![Overclockers UK's Ultimate Collection of Streaming Guides](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/04/ocuk-streaming-guides-150x150.png)
Looking for the best streaming tips and tricks? We’ve compiled the Overclockers UK Ultimate Collection of Streaming Guides. Be sure to check it out!
