If you’re looking to kickstart your gaming or upgrade your tired and old set up – then look no further! We’ve compiled everything you need to create the ultimate gaming battle station, all for under £3000.
Refract Gaming Celeste Pre-built PC:
Tailored for mid-range gaming and streaming, the Refract Gaming Celeste comes packed with everything you need to enjoy playing all of the latest AAA titles. This includes an AMD Ryzen 7 7700X CPU and an NVIDIA RTX 4070 GPU. Sit back and unlock seamless performance along with ultra-fast processing speeds, that is perfect for both gaming and streaming alike. Plus, with support for cutting-edge features such as Real-Time Ray Tracing, achieve photo-realistic visuals silky-smooth frame rates for an immersive gaming experience.
In addition to all of this, each PC in the Refract Gaming range comes armed with a three-year warranty, which covers parts and labour, for extra peace of mind.
Available for £1,729.99*
- Pre-built gaming PC
- Designed for mid-range gaming and streaming
- Includes an AMD Ryzen 57 7700X and NVIDIA RTX 4070 GPU
- Up to 32GB DDR5 RAM
Ducky One 3 Classic Full-sized USB Mechanical Gaming Keyboard:
Built with all-new QUACK mechanics, the Ducky One 3 Mechanical Gaming Keyboard features a durable dual-layer hot-swappable PCB, allowing you to effortlessly flick between different key switches to find the type that perfectly suits your gameplay style. Plus, with PBT double-shot keycaps, enjoy a smooth typing experience that will last session after session, no matter how intense the gameplay gets.
The finishing touches to this mechanical keyboard are the sleek all-white design, braided USB cable, and integrated RGB lighting, for that extra stylish touch to your set up.
Available for £160.00*
- Mechanical keyboard
- Full-sized
- Wired connectivity
- Hot-swappable PCB
- This model comes with Cherry MX Speed Silver switches
- PBT double-shot keycaps
Glorious Model D- Wireless Gaming Mouse:
Stand strong in battle and achieve success after success with the Glorious Model D- Wireless Gaming Mouse. Equipped with a high-quality Glorious BAMF optical sensor and DPI of up to 19,000, you can unlock superior tracking, precision, and control over all of your mouse movements. Plus, thanks to the premium G-skate feet, this mouse will glide across any surface.
Completely wireless, you won’t have to worry about unnecessary cables cluttering up your desk or impacting your gameplay. The Glorious Model D- features 2.4GHz lag-free connectivity with a battery life of up to 71 hours, perfect for those gaming marathons with the squad!
Available for £79.99*
- Optical gaming mouse
- Glorious BAMF sensor
- DPI of up to 19,000
- Wireless
- 2.4GHz connectivity
- Premium G-skate feet
- 71 hours battery life
OcUK Mega Mat 3XL Tactical Gaming Surface:
Our favourite choice by far is the OcUK Mega Mat 3XL. This ultra-large mouse mat, not only sports our classic OcUK logo and a stylish geometric print, but measures at hefty 1180 x 600mm! Covering your entire desk or table, you’ll have plenty of space for all your ultra-fast mouse movements and will never need to worry about running out of room again!
Optimised for optical gaming mice, this gaming mousepad has been crafted utilising woven fibre, to create a smooth, soft cloth surface for your mouse to glide across. Plus, with enhanced stitched edges, the OcUK Mega Mat is well protected from any unwanted fraying and will stand the test of time.
Available for £9.98*
- 3XL gaming mousepad
- 1180 x 600mm
- Made from woven fibre
- Optimised for optical gaming mice
- Geometric print
If you want some of our expert tips to keep your OcUK Mega Mat looking factory fresh and sparkling for longer, check out our dedicated blog article.
ASUS ROG Delta S Lightweight Gaming Headset:
Become immersed in all your favourite gaming soundscapes with the ASUS ROG Delta S Gaming Headset. Built with 7.1 surround sound and powerful ASUS Essence drivers, enjoy crystal clear audio that is sure to prove advantageous on the battlefield. With an ASUS AI Noise-Cancelling microphone, your teammates will be able to hear you loud and clear, with no unwanted background chatter distracting your fellow players.
What’s more, to keep you comfortable during long extended hours of gameplay, this headset features a lightweight, adjustable headband, along with ergonomic ear pads.
Available for £189.95*
- Wireless gaming headset
- ASUS Essence drivers
- 7.1 surround sound
- Lightweight design
- Ergonomic earpads
ASUS TUF Gaming VG27WQ 2560 x 1440 Gaming Monitor:
Take advantage of the ASUS TUF Gaming VG27WQ Gaming Monitor and unlock crisp, high-resolution visuals with ultra-fast refresh rates of up to 165Hz. This 27’’ display has been designed for gamers, and features an array of cutting-edge technology, designed to enhance performance. This includes ASUS Extreme Low Motion Blur (ELMB), for tear-free gaming and zero ghosting.
Available for £239.00*
- Widescreen gaming monitor
- 27” IPS display
- 2560 x 1440
- 165Hz refresh rates
- FreeSync compatible
noblechairs LEGEND Black Gaming Chair:
Enjoy legendary comfort with the noblechairs Black LEGEND Gaming Chair. Featuring a brand-new re-defined design, this gaming chair has been crafted utilising durable PU leather with cold foam upholstery. Keeping you well supported are the integrated ergonomics and adjustability, such as built-in lumbar support and 4D armrests. All of which combined, help to keep you cool and comfortable session after session.
This gaming chair is sure to effortlessly fit into any gaming aesthetic, thanks to the sleek all-black, winged design, with silver harness hole.
Available for £419.99*
- New re-defined LEGEND design
- Built from PU leather with cold foam upholstery
- Integrated lumbar support
- 4D adjustable armrests
- All black with a silver harness hole
There is even money in the budget for an additional memory foam pillow set! With so many options ranging from iconic gaming franchises to Marvel characters, you are truly spoilt for choice!
noblechairs Boba Fett Special Edition Pillow Set:
Available for £55.99*
- Special edition pillow set
- Officially licensed Boba Fett design
- Memory foam
- Head and lumbar support
- Machine washable
noblechairs Fallout Nuka-Cola Special Edition Pillow Set:
- Fallout Nuka-Cola design
- Memory foam
- Machine washable
noblechairs Black Panther Special Edition Pillow Set:
- Black Panther
- Memory foam
- Machine washable
Nitro Concepts D12 Gaming Desk:
The Nitro Concepts D12 Gaming Desk is the perfect foundation for your battle station. Built from a combination of solid steel and durable MDF, this desk can accommodate up to two monitors, along with all of your additional accessories. The tabletop has been finished with a durable coating that has been optimised for mouse tracking, allowing your gaming mouse to effortlessly glide across this surface. No additional mouse mat required! However, nothing beats the OcUK Mega Mat for keeping our desks well protected and tidy.
What’s more, this gaming desk is complete with some must-have quality of life enhancements. This includes two integrated grommets for easy cable management, along with a headset and drinks holder.
Available for £114.95*
- Solid steel construction
- Durable MDF tabletop
- Space for up to two monitors
- Integrated cable management grommets
- Cup and headset holders
So… What’s the Damage to Your Wallet?
The total price for the PC and hardware comes to £2,999.84* (including a pillow set).
Designed to Suit Any Budget!
No matter your budget, we’ve got a great line of gaming hardware and accessories, along with dedicated blog guides, to ensure you can build your dream gaming set up, without breaking the bank.
Did you like this article?
*Prices and PC specs are subject to change and were correct at the time of writing.
