Best PC Cases for AMD Radeon RX 6000 Series Graphics Cards!
If you want to harness the exceptional gaming power of the AMD Radeon RX 6000 Series but need a compatible and stylish PC case to house your GPU – look no further!
In this two part series, we’ve put together this list of our favourite PC cases that are compatible with the AMD Radeon RX 6000 Series.
The AMD Radeon RX 6000 Series
Unlock powerful gaming performance with the AMD Radeon RX 6000 Series graphics cards. AMD RDNA 2 architecture facilitates accelerated graphics and stunning visuals. Each GPU in the AMD Radeon RX 6000 Series comes fully equipped with a plethora of intelligent features, including FidelityFX Super Resolution or Real-Time Ray Tracing, for an immersive gaming experience.
For more information on the AMD Radeon RX 6000 Series, why not check out our dedicated blog post?
Will the Size of My GPU Affect What Case I Can Use?
In short, yes! GPU clearance determines the length and width of the graphics card. You can’t have a graphics card that is longer or wider than the case itself.
If you are planning on implementing features such as water cooling or drive cages, you need to make sure you have ample space inside your case. The size of the GPU can affect how much clearance you have for installing custom configurations.
What Size Case do I Need for an AMD Radeon RX 6000 Graphics Card?
We would recommend that your PC case has a GPU clearance of at least 380mm for an AMD Radeon RX 6000 GPU.  This will leave you with plenty of additional space if you wish to include water cooling, AiOs, and much more.
However, to ensure full compatibility with your chosen case, it’s recommended you check with the manufacturer of your GPU and case for its dimensions, expansion slots, and GPU clearance.
What are the Best PC Cases for AMD Radeon RX 6000 Graphics Cards?
To showcase some of the best PC cases that have ample space for an AMD Radeon RX 6000 GPU, here at Overclockers UK we’ve selected some of our favourites. Each of these PC cases can support various different GPU configurations and have a GPU clearance of up to 422mm.
Lian Li O11D EVO Black Mid Tower PC Case
Sleek and effortlessly stylish, the Lian Li O11D EVO features comprehensive support for either normal or reverse hardware configurations, along with three different GPU orientations. Thanks to the removable panels, your hardware can be arranged either on the right or left for a seamless unified look that best suits your desk.
What’s more, you can also house your graphics card either horizontally, vertically, or even upright. The required brackets and cables to do this are sold separately and not included with the Lian Li O11D EVO. Thanks to the GPU clearance of 420mm, you will still have ample space to install AiO coolers or even intricate custom loops. All of which you can show off through the tempered glass side panels.
  • Mid tower PC case
  • Modular
  • Two configuration modes: Normal and Reverse
  • Supports up to E-ATX motherboards
  • GPU clearance of up to 420mm
  • Supports either horizonal, vertical, or upright GPU mounting
To install your GPU vertically or upright, you will need the Lian Li O11D EVO Vertical/Mounting GPU Kit (sold separately).
Phanteks Eclipse G360A Matte White Mid Tower PC Case
The Phanteks Eclipse G360A boasts high airflow and cooling, along with complex custom hardware configurations. You can install a GPU up to 400mm in length and choose to arrange it either horizontally or vertically within this case. You will need an additional riser cable and bracket to do this (sold separately). To ensure your chosen AMD Radeon RX 6000 GPU stays cool and performs at its best, the Phanteks Eclipse G360A has been expertly crafted with exceptional cooling. You can arrange radiators to either be at the top or front panel of the case and still install up to seven 120mm or four 140mm fans in total!
Thanks to the included d-RGB controller, you can illuminate all your incredible hardware. Customise and choose from a plethora of different lighting effects, including rainbow wave, for a stylish aesthetic that will be the envy of your teammates.
  • Mid Tower PC case
  • GPU clearance of up to 400mm
  • Supports vertical GPU mounting
  • Includes a d-RGB controller
Kolink Observatory Y AMD Edition Mid Tower PC Case
Unlock exceptional hardware flexibility with the Kolink Observatory Y AMD Edition PC Case. This mid tower chassis features AMD branded tempered glass and steel panels, the perfect companion to your AMD Radeon RX 6000 Series GPU. You can install GPUs of up to 380mm in length, which can be arranged either horizontally or vertically. To do this, you will need a mounting kit which is not included with the case.
Keeping all your important gaming hardware cool are the four pre-installed Kolink ARGB PWM Umbra fans. With these PWM fans, you can control how fast the fans rotate and adjust the speeds to match your PC’s temperature. Plus, thanks to the integrated RGB lighting you can customise these fans to suit your chosen aesthetic or proudly show off the colours of Team Red.
  • Mid tower PC case
  • Limited AMD edition
  • Branded AMD tempered glass side panels
  • GPU clearance of up to 380mm
To install your GPU vertically, you will need the Kolink Vertical GPU Mounting Kit.
  • Vertical GPU mounting kit for Kolink Observatory Y/Z cases
  • Includes a PCIe 3.0 riser cable and steel mounting bracket
Phanteks Enthoo 719 DRGB Full Tower PC Case
The Phanteks Enthoo 719 has been expertly crafted to offer you endless customisation and configurations. Harness this incredible full tower case to unlock support for creating two systems in one. With the included brackets, you can have a primary and a secondary Mini-ITX system in this case. If you want to create an exceptional power PC instead, then there is space for a second PSU to supply all your important hardware with sufficient power.
This full tower chassis also includes two vertical triple-slot PCIe slots and can support GPUs of up to 503mm in length. Thanks to the included vertical GPU bracket, you can install your graphics card either horizontally or vertically. Which you can display with pride thanks to the tempered glass side panels.
It’s important to note, that a compatible riser cable is not included and will need to be purchased separately.
  • Full tower PC case
  • Can fit two systems in one case
  • GPU clearance of up to 503mm
Overclockers UK Ultimate PC Building Guide
Building your own gaming PC can be a daunting task. That’s why we’ve put together the Overclockers UK Ultimate PC Building Guide.
What Case Did You Buy for Your AMD Radeon RX 6000 Series?
Did you upgrade your case? Which one did you purchase and why? Tell us in the comments.
5 1 vote
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
