If you want to take advantage of a cutting-edge NVIDIA RTX 30 Series GPU but need an exceptional and reliable PC case to show it off – look no further!
In this two part series, we’ve put together this extensive list of our favourite PC cases that are compatible with the NVIDIA RTX 30 Series.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/04/PC-Cases-for-NVIDIA-RTX-30-Series-1024x1024.jpg)
The NVIDIA RTX 30 Series
Unlock breath-taking realistic visuals in all your favourite games with a powerful NVIDIA RTX 30 Series graphics card. Take advantage of the dedicated intelligent RT and Tensor cores, along with NVIDIA’s Ampere architecture, to enjoy smooth frame rates and immersive visuals. Each NVIDIA RTX 30 Series GPU comes fully equipped with support for an array of cutting-edge features, including Real-Time Ray Tracing.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/04/Is-it-Good-for-Gaming-NVIDIA-RTX-30-Series-300x300.jpg)
For more in-depth details on how an NVIDIA RTX 30 Series GPU can elevate your gaming performance, take a look at our dedicated blog post, ‘Is it Good for Gaming? NVIDIA GPUs’.
What Size Case Do I Need for an NVIDIA RTX 30 Series GPU?
To ensure your chosen case can fit even the biggest GPUs in the 30 series, we would recommend a PC case that has a GPU clearance of at least 380mm. This means you can utilise your powerful graphics card, along with a variety of custom configurations including intricate water-cooling loops.
However, to guarantee full compatibility, it’s important to also consult with the manufacturer of your GPU and case for their dimensions, expansion slots, and GPU clearance.
What are the Best PC Cases for the NVIDIA RTX 30 Series GPUs?
To showcase some of the best PC cases that are compatible with the NVIDIA RTX 30 Series, here at Overclockers UK, we’ve selected some of our favourite cases that are listed down below.
Phanteks Enthoo Evolv X Mid Tower PC Case
The Phanteks Enthoo Evolv X has been carefully designed to support an extensive list of hardware, custom configurations, and cooling. This includes up to E-ATX motherboards, dual systems, and vertical GPU mounting. With a GPU clearance of up to 435mm, the Phanteks Enthoo Evolv X is compatible with even the biggest NVIDIA RTX 30 Series GPUs available. Plus, the included anti-sag bracket offers additional support. If you want to vertically mount your GPU, this case includes three vertical expansion slots (riser cable sold separately). For an added dramatic touch, the Phanteks Enthoo Evolv X includes two d-RGB strips along the front panel and PSU shroud. This is fully customisable, allowing you to unlock 16.8 million different colours and a plethora of lighting effects. Show off your incredible hardware, custom configurations, and dramatic RGB light show through the tempered glass side panel.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/08/Phanteks-Enthoo-Evolv-X-277x300.png)
- Mid Tower PC Case
- Available in different colours, including matte white
- Supports up to E-ATX motherboards
- GPU clearance of 435mm
- Compatible with vertical GPU mounting
- Comes with 3 x 140mm dRGB fans pre-installed
- Two hinged, tempered glass side panels
Phanteks Eclipse P600S White Mid Tower PC Case
Perfect for those who want to achieve that sleek, all-white aesthetic, the Phanteks Eclipse P600S has been expertly crafted for premium airflow and performance. Pre-installed in this case are intelligent sound-dampening panels for a virtually silent operation. The front mesh panel promotes a consistent natural flow of air through this case, keeping all your important hardware cool. The Phanteks Eclipse P660S features support for an extensive list of hardware, including up to E-ATX motherboards, and even a dual system. In addition to all of this, this case will support GPUs of up to 435mm in length and includes seven expansion and three vertical slots. Take advantage of these, along with a riser cable (sold separately), and vertically mount your NVIDIA RTX 30 Series GPU for a unique-looking build.
All of which you can proudly display thanks to the clear tempered glass side panel.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/08/Phanteks-Eclipse-P600S-.png.webp)
- Mid Tower PC case
- All white
- Includes 3 x 140mm fans pre-installed
- Intelligent sound-dampening panels
- GPU clearance of up 435mm
- Supports vertical GPU mounting
Kolink Citadel Mesh ATX ARGB Mid Tower PC Case
A versatile and stylish case, the Kolink Citadel Mesh ATX, features support for a multitude of custom configurations whilst boasting phenomenal airflow and cooling. This case comes fully equipped with support for up to E-ATX motherboards and has a GPU clearance of 380mm. Along with all of this, the Citadel Mesh ATX also includes a number of expansion slots that you can utilise to mount your GPU either horizontally or vertically. In addition to this, this case features a vast array of cooling options, including the four pre-installed 120mm fans. There is ample space for a number of fans, radiators, and even custom water cooling.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/08/Kolink-Citadel-Mesh-ATX--292x300.png)
- Mid Tower PC case
- ATX form factor
- Support up to E-ATX motherboards
- Compatible with GPU vertical mounting
- GPU clearance of 380mm
- Includes 4 x 120mm pre-installed fans
- Includes a Kolink Umbra Core controller
To vertically mount your GPU in the Kolink Citadel Mesh ATX Case, you will need a vertical mounting GPU Kit
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/08/Kolink-Vertical-GPU-Kit--300x274.png)
Kolink Vertical GPU Kit:
- Vertical GPU mounting kit
- Includes a PCIe 230mm riser cable and steel bracket
Lian Li O11 Dynamic XL Full Tower PC Case
The Lian Li O11 Dynamic XL is a modular full tower chassis that comes fully equipped with support for a vast array of hardware and cooling. Constructed from a combination of steel and aluminium, this case can support motherboards up to E-ATX and has a GPU clearance of up to 446mm. You can freely arrange your GPU either horizontally or vertically with a GPU mounting kit (sold separately). In addition to this, the Lian Li O11 Dynamic XL boasts incredible cooling, with support for holding up to three 360mm radiators simultaneously! Unleash your creativity and ensure all your incredible hardware stays cool by installing fans, AiOs, or even intricate water-cooling loops in this case with ease.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/08/Lian-Li-O11-Dynamic-XL-269x300.png)
- Full Tower PC case
- GPU clearance of 446mm
- Fits up to ten 120mm fans or three 360mm radiators!
- Tempered glass side panels
If you wish to install your GPU vertically in the Lian Li O11 Dynamic XL Case, you will need a Lian Li O11DXL-1 expansion kit.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/08/Lian-Li-O11DXL-1-Riser-Cable--300x287.png)
Lian Li O11DXL-1 Expansion Kit
- Includes a PCIe 3.0 200mm riser cable and bracket
![Overclockers UK Ultimate PC Building Guide](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/04/pc-building-hub-150x150.png)
Building your own gaming PC can be a daunting task. That’s why we’ve put together the Overclockers UK Ultimate PC Building Guide.
Your Chosen PC Case?
What PC case did you pair with your NVIDIA RTX 30 Series GPU? Let us know in the comments.
