Best PC Cases for the NVIDIA RTX 50 Series
That shiny new 50 Series GPU needs a home and that’s why we’ve rounded up some of the best PC cases for the NVIDIA RTX 50 Series.
The NVIDIA RTX 50 Series
Built upon Blackwell architecture, the NVIDIA RTX 50 Series boasts plenty of CUDA, 5th-gen Tensor, and 4th-gen RT cores, along with all the latest AI enhancements to help you dominate the virtual battlefield and your creative workloads. On board GDDR7 video memory ensures maximum efficiency, minimal latency, and ultra-fast data transfer speeds for an uninterrupted experience every time.
Looking to learn more about the NVIDIA RTX 50 Series? Be sure to check out our ultimate guide for all the key details you need to know.
NVIDIA RTX 50 Series Hub
What PC Case Do You Need for the NVIDIA RTX 50 Series?
The NVIDIA RTX 50 Series doesn’t just have one set of dimensions that will fit in every PC case. The size of your GPU will depend on the model and the manufacturer of your chosen card, both of which will influence what PC case you can upgrade to.
NVIDIA has confirmed some basic dimensions for each of the four GPUs in the 50 Series. This includes:
  • RTX 5090 – 304 x 137mm. Features on-board dual slot cooling as standard but varies on manufacturer.
  • RTX 5080 – 304 x 137mm. Includes on-board dual slot cooling but this is dependent on manufacturer.
  • RTX 5070 Ti – 304 x 137mm. On-board dual slot cooling included but can vary on manufacturer.
  • RTX 5070 – 242 x 112mm. Integrated dual slot cooling solution as standard but differs depending on manufacturer.
The specs listed above are very basic and may not be completely accurate for your chosen GPU. If you want a definitive answer on the size of your graphics card, we recommend that you do consult with the manufacturer product page. However, we will be using the official dimensions to help give you an idea of what PC case you should pair with your shiny new RTX 50 Series GPU.
With a maximum length of 304mm or even 242mm, your first step should be ensuring you have enough GPU clearance to accommodate. 340mm to 380mm is plenty for housing your chosen graphics card, any additional cooling, and of course those must-have aesthetics. If your GPU does exceed these measurements or includes on-board triple slot cooling instead, you’ll want to think about a PC case with a GPU clearance of at least 400mm, if not higher.
Best PC Cases for the NVIDIA RTX 30 Series Graphics Cards!
The NVIDIA RTX 50 Series are powerful graphics cards and will require a lot of cooling to keep them performing at optimum temperatures. That’s why your PC case should support multiple fan configurations and even a radiator for those custom water-cooling fanatics.
That’s it for the absolute must-haves. The rest is down to your own personal requirements. Do you want a case with glass panels so you can show off that RTX 5090 with pride? Or maybe even some integrated RGB lighting to illuminate your GPU in vibrant colour? Will you be vertically mounting your 50 Series graphics card? There are plenty of options and case customisations to make your PC your own.
RTX 5090
HAVN HS420 VGPU Premium Mid Tower Case - Black
HAVN HS420 VGPU Premium Mid Tower Case – Black
CAS-HVN-02515
★★★★★ (5)
£269.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Phanteks NV7 D-RGB With Front And Side Glass Panels Full Tower Case - Black
Phanteks NV7 D-RGB With Front And Side Glass Panels Full Tower Case – Black
CA-0BQ-PT
★★★★★ (5)
£189.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
RTX 5080
HYTE Y70 Dual Chamber Mid-Tower ATX Case - White/Black
HYTE Y70 Dual Chamber Mid-Tower ATX Case – White/Black
CAS-HYT-01820
★★★★★ (5)
£219.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Phanteks XT View ATX Case Tempered Glass Windows, Black
CAS-PHK-01445
★★★★★ (5)
£84.95
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
RTX 5070 Ti
Kolink Unity Peak ARGB Midi Tower Showcase - Black
Kolink Unity Peak ARGB Midi Tower Showcase – Black
CA-07Z-KK
★★★★★ (5)
£84.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Lian Li O11 Dynamic Mini Snow Edition Midi-Tower Tempered Glass - White
Lian Li O11 Dynamic Mini Snow Edition Midi-Tower Tempered Glass – White
CA-78Z-LL
★★★★★ (5)
£99.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
RTX 5070
Kolink Observatory Midi Tower RGB Gaming Case - Black Tempered Glass Window
Kolink Observatory Midi Tower RGB Gaming Case – Black Tempered Glass Window
CA-037-KK
★★★★★ (5)
£79.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Phanteks Eclipse G400A Case Tempered Glass DRGB Matte White
CAS-PHK-03105
★★★★★ (5)
£84.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Looking to Upgrade in Time for the RTX 50 Series?
How to Order an NVIDIA GeForce RTX 50 Series GPU From Overclockers UK
Learn More About Your PC Case
PC Case Form Factors Explained - Everything You Need to Know!
Mid Tower vs Full Tower: Which PC Case is Best for a Gaming PC?
What PC Case Will You Be Pairing Your 50 Series GPU With?
Will you be upgrading your PC case for the NVIDIA RTX 50 Series? What GPU and PC case will you be picking and why? Let us know in the comments.
0 0 votes
Article Rating
Subscribe
Notify of
guest
2 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
Gordon Wishart
Gordon Wishart
1 month ago
Phanteks Evolv X. Plenty of room, and will cope with the cooling no problem.
Emily Haylock
Editor
1 month ago
Reply to  Gordon Wishart
That’s a great shout!
