In the market for a new RAM upgrade? If so, this is the blog post for you!
RAM is a vital aspect of any gaming PC, responsible for temporarily storing and processing data as and when your CPU needs it. Without a high-quality RAM kit, your performance will suffer from slow loading times and input lag. Everything you don’t need to defeat those pesky enemies.
That’s why we’ve searched high and low across the Overclockers UK website and put together this list of our top RAM modules.
Kingston Fury Beast EXPO 16GB (2X8GB) DDR5 Dual-Channel Kit
Achieve maximum efficiency while you game with the Kingston Fury Beast 16GB RAM Kit. Utilise 16GB of DDR5 RAM spread across two 8GB modules, capable of reaching speeds up to 6000MHz, to unlock fast load times in both single- and multi-threaded applications. Support for AMD EXPO and Intel XMP means you can utilise one-click overclocking profiles to boost your performance and productivity even further.
- 16GB capacity (2x8GB modules)
- DDR5 standard
- EXPO compatible
- Dual-channel configuration
- Up to 6000MHz
TeamGroup Xtreem 32GB (2x16GB) DDR5 Dual-Channel White Kit
The TeamGroup Xtreem 32GB RAM Kit is the perfect upgrade for gamers and streamers alike, promising fast speeds of up to 7600MHz and maximum efficiency. The onboard power management chip optimises performance and power delivery, along with ensuring minimal noise for a whisper-quiet operation. Plus, the sleek all-white design is sure to seamlessly blend into your aesthetic.
- 32GB capacity (2x16GB modules)
- DDR5 standard
- 36-45-45-84 CAS timings
- Up to 76000MHz
Corsair Vengeance EXPO 64GB (2x32GB) DDR5 Dual-Channel Kit
For creatives and professionals looking to level up their performance, we recommend the Corsair Vengeance EXPO 64GB RAM Kit. Arranged in a dual-channel configuration, all your workloads are evenly spread across the two 32GB RAM modules, capable of reaching up to 6000MHz, to facilitate rapid load times and near-zero latency. The integrated aluminium heat spreader has been optimised to dissipate excess heat and keep temperatures to a minimum, meaning you can create, stream, or game with ease. Plus, the RGB light strip with ten LEDs can be customised to match the rest of your set-up for a synchronised light show.
- 64GB capacity (2x32GB modules)
- DDR5 standard
- 30-36-36-76 CAS timings
- Compatible with AMD EXPO
- Integrated customisable RGB lighting
Kingston Fury Beast EXPO 32GB (2x16GB) DDR5 White Dual-Channel Kit
Unlock fast performance, loading times, and maximum efficiency with the Kingston Fury Beast 32GB RAM Kit. This RAM kit harnesses powerful DDR5 technology and with support for AMD EXPO to streamline your gaming and creative workloads, while offering easy-to-do overclocking.
- DDR5 standard
- Up to 5600MHz
TeamGroup Xtreem 32GB (2x16GB) DDR5 Dual-Channel Pink Kit
The TeamGroup Xtreem 32GB DDR5 RAM Kit features two 16GB modules, arranged in a dual-channel configuration, to unlock ultra-fast performance across your single- and multi-threaded tasks, along with rapid load times. All of which is enhanced further by the integrated On-Die ECC, designed to efficiently stabilise your PC under heavy loads while the onboard heatsink and fins dispel excess heat. Finally, the stylish all pink design is sure to look incredible within your set-up, especially if you’re looking to achieve a pastel aesthetic.
- DDR5 standard
- All-pink design
Shop All RAM Kits
Do none of these RAM kits suit your needs? We got you, boo! You can explore our full selection of RAM kits with the click of a button.
Want to Learn More About Your PCs RAM?
Share Your RAM Recs!
Did we mention your favourite RAM kit? Or perhaps we just missed it off our list? Whatever the case – share your top RAM recs in the comments below.
