Jonsbo has two fabulous SFF PC cases joining their line-up. Meet the Jonsbo N2 and C6 PC cases!
These two new series are compact, intelligently designed, and sport stylish aesthetics. Basically, everything you could want in a small form factor PC case. We’re going to take a closer look at all their features and get excited about all the things we can use them for! Read on to join the hype.
What’s Available?
There are a total of four cases, across two different series. These are the Jonsbo N2 Mini-ITX NAS and Jonsbo C6 Mesh Micro-ATX PC Cases, each available in black or white.
Jonsbo N2 Mini-ITX NAS PC Case
The Jonsbo N2 has been crafted to serve as a NAS PC case. With five hot-swappable drive bays and an additional 2.5” SSD tray in the motherboard chamber, it is well equipped for the job. The N2 is a cube case, with removable panels to allow for easy access within the chassis. Overall, the interior volume is 11L, but the N2 has an intelligent design that means it can be used for more than just a NAS server.
This PC case includes a half height PCI expansion slot, that can be used for a range of low-profile PCIe devices. This includes capture cards or even GPUs up to 197mm long, making the N2 ideal for light gaming or use as an HTPC.
To keep your hardware cool, the Jonsbo N2 NAS PC Case has a pre-installed 120mm fan with a slim profile. It has been optimised to provide outstanding cooling performance within this cubular chassis.
Component | Specification |
Motherboard | Mini-ITX |
Storage | 5 x .5″ HDD bays 1 x 2.5″ SSD tray |
GPU Clearance | Low profile 197mm long |
Power | SFX PSU |
Cooling | 1 x pre-installed fan |
I/O Panel | 1 x USB 3.2 Gen 2 Type-C 1 x USB 3.0 1 x audio |
The Jonsbo C6 Mesh is primed to be a gaming PC case. The four mesh panels provide outstanding airflow whilst the interior layout facilitates great flexibility for hardware, despite its small size. Once again, each of the panels can be easily removed, via the latch on the back of the case. As such, you have unfettered access to the interior and installation is much simpler.
There are two configurations for this case, as it can support both Mini-ITX and Micro-ATX motherboards. Which you choose will affect GPU clearance. With the Mini-ITX, you have the full 255mm clearance for graphics cards. If you opt for a Micro-ATX, then clearance will change depending on which slot you use. On the first slot, you have the full space, but there is 200mm clearance at 48mm thick when utilising the second slot. Whichever configuration you choose, there are four expansion slots to support the GPU and other PCIe devices.
For cooling, the Jonsbo C6 Mesh can support up to three fans. These can be mounted on the front, top, or bottom. The front can hold a 120mm fan, whilst the other two positions can support either 120mm or 140mm models. Alternatively, the front panel can be utilised for storage, with space for either one 3.5” HDD or two 2.5” SSDs in place of the fan.
Motherboard | Mini-ITX Micro-ATX |
GPU Clearance | Between 200mm and 255mm |
Storage | 1 x 3.5″ -or- 2 x 2.5″ |
Power | ATX PSU |
Cooling | Top/Bottom: 1 x 120/140mm Front: 1 x 120mm |
Sort Out Your Next SFF Build
If you need a PC case for a NAS server or SFF gaming PC, then you’re in luck. Both these series are available to pre-order right now from Overclockers UK. Let us know if you’ll be making the upgrade in the comments below.
- Aluminium cube case
- Five hot-swappable HDD bays
- Half height PCI expansion slot for low profile PCIe devices
- One 2.5″ SSD tray
- Removable panels
- Steel Micro-ATX PC case
- Four mesh panels
- Between 200mm and 255mm GPU clearance
- Supports Mini-ITX and Micro-ATX motherboards
- Removable panel
