With our hardware constantly being innovated, we need a power supply that can keep up. The Kolink REGULATOR Series is here to enhance your PSU game.
![Big Power with Kolink REGULATOR PSU Series: Enhance Your Gaming](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/blog-kolink-regulator-80-plus-gold-psus-1024x1024.png)
Featuring native 12VHPWR, PCIe 5.0, and premium components, this ATX 3.0 PSU is the perfect addition to your gaming PC, especially if you are looking to upgrade to an NVIDIA RTX 40 Series GPU. Plus, there are a range of compatible cables designed to work with these power supplies. Would you like to know more? Read on!
What is Available?
There are four modular PSUs in the Kolink REGULATOR Series: 750W, 850W, 1000W, and 1200W. Accompanying these are six cables: a 20+4-pin, 4+4 12V ATX, SATA, 4x 4-pin Molex, PCIe 6+2, and Gen 5 12VHPWR cable.
750W REGULATOR PSU
![Kolink REGULATOR PSU Series 750W](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-series-750w-300x300.jpg)
850W REGULATOR PSU
![Kolink REGULATOR PSU Series 850W](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-series-850w-300x300.jpg)
1000W REGULATOR PSU
![Kolink REGULATOR PSU Series 1000W](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-series-1000w-300x300.jpg)
1200W REGULATOR PSU
![Kolink REGULATOR PSU Series 1200W](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-series-1200w-300x300.jpg)
20+4-pin Cable
![Kolink REGULATOR Modular 20+4-pin Cable](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-20-4-pin-cable-300x300.jpg)
4+4 12V ATX Cable
![Kolink REGULATOR Modular 4+4 12V ATX Cable](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-4-4-12v-atx-cable-300x300.jpg)
SATA Cable
![Kolink REGULATOR Modular SATA Cable](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-sata-cable-300x300.jpg)
4x 4-pin Molex Cable
![Kolink REGULATOR Modular 4x 4pin Molex Cable](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-molex-cable-300x300.jpg)
PCIe 6+2 Cable
![Kolink REGULATOR Modular PCIe 6+2 Cable](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-pcie-6-2-cable-300x300.jpg)
Gen 5 12VHPWR Cable
![Kolink REGULATOR ModularGen 5 12VHPWR Cable](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-12vhpwr-cable-300x300.jpg)
![Kolink REGULATOR PSU Series 750W connectors](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-series-750w-connectors-300x300.jpg)
The Kolink REGULATOR Series power supplies are fully ATX 3.0 compliant, meaning they natively support PCIe 5.0 and 12VHPWR. In fact, a 12VHPWR 600W cable is included, so you don’t need to worry about bringing in any additional adapters. Gosh, we do like simplicity!
These PSUs feature a compact design, measuring only 140mm long. As a result, they are compatible with a wide range of PC cases. Whether you’re upgrading an SFF build or starting fresh with your dream powerhouse, this is a great power supply to include.
Reliable Power
Utilising an LLC DC/DC single rail design, the Kolink REGULATOR Series is highly efficient. In fact, it has earned an 80 PLUS Gold rating, which means it is 90% efficient at half loads. This is great as these power supplies are producing very little waste, which your energy bills will thank you for.
All of the components are of premium quality, such as 100% Japanese capacitors which facilitate high operating standards. As a result, you can enjoy a clean supply with tight voltage regulation. Even across the entire load range.
Semi-Fanless Mode
One thing we all want from our power supplies is whisper-quiet performance. The Kolink REGULATOR Series features a dedicated semi-fanless mode, which can be activated via the switch next to the power button. When triggered, the PSU will passively cool, thus keeping the noise levels down, while under 40% loads. At higher loads, the fan will speed up according to temperature.
Even without the semi-fanless mode on, the 120mm fan will operate at slower speeds when under lighter loads. This fan has an optimised blade curve and is spaced 8mm from the frame, to reduce turbulence yet still provide ample airflow. What’s more, it is equipped with a fluid dynamic bearing which promotes great longevity and durability.
![Kolink REGULATOR PSU Series 750W fan](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-series-750w-fan-300x300.jpg)
Safety For Days
One final note, each Kolink REGULATOR Power Supply Unit has seven-fold protection on its inner circuitry. They have been awarded the following safety certifications:
![Kolink REGULATOR PSU Series 750W box](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-series-750w-box-300x300.jpg)
- Overvoltage protection (OVP)
- Undervoltage protection (UVP)
- Overpower protection (OPP)
- Short-circuit protection (SCP)
- Overcurrent protection (OCP)
- Overtemperature protection (OTP)
- Surge / inrush current protection (SIP)
Kolink REGULATOR Cables
The Kolink REGULATOR Cables are available to buy separately, so you can add them to your gaming PC at your convenience. They are designed to operate as replacement cables for the REGULATOR Series, should the originals be damaged or lost. Their design has also been future-proofed to work with upcoming models.
Kolinnnk REGULATOR Replacement Cables
- 20+4-pin, 4+4 12V ATX, SATA, 4x 4-pin Molex, PCIe 6+2, and Gen 5 12VHPWR cables
- Available individually
- Designed for REGULATOR Series PSUs
![Kolink REGULATOR Modular 20+4-pin Cable headers](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/kolink-regulator-20-4-pin-cable-headers-300x300.jpg)
Powerful Stuff
Are you in need of an upgrade? The Kolink REGULATOR Series is available from Overclockers UK. Drop a comment below with the wattage you’ll be needing!
Kolink REGULATOR Fully Modular 80 PLUS Gold Power Supply Units
- Modular PSU series
- 80 PLUS Gold efficiency rating
- Semi-fanless mode
- Extensive safety certifications
- Four wattages available
