The BitFenix Alchemy 2.0 cables are a pre-sleeved cable kit that supports a wide variety of modular power supplies from different manufacturers.
These premium cables feature precision molded connectors and come in a variety of colours and cable types, enabling modders to transform normal PCs into objects of wonderment!
Aimed at high performance power supplies, Alchemy 2.0 is manufactured with high quality components to support up to 1600W. Use of High Current Alloy Terminals impreoves the connection and minimises the effciency drop in modular cable. Use of Pure Copper cables with thicknesses up to 16AWG reduces the resistance while increasing effciency.
Alchemy 2.0 cables are sleeved to perfection with high density sleeving in a heatshrinkless sleeving process. Using special cables, the flexibility has been improved to extend the durability of the cables.
The cables are designed to replace the standard modular cables of the modular power supplies from the major brands. Each kit contains a set of standard modular cables for the specific power supply and five rubber cable combs to improve the aeshetics of the build.
See the full list of BitFenix Alchemy 2.0 cables here.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
