The Enso from BitFenix is an especially stylish and spacious Midi-Tower in two colour variants and comes with integrated RGB lighting. This is compatible with ASUS’ Aura Sync Technology, however it can also be controlled by means of the installed controller using a button on the IO panel. The sleek case is compatible with motherboards up to E-ATX format and comes equipped with a Tempered Glass side panel, a tool-free removable dust filter as well as support for water cooling. Even the new Alchemy 3.0 LED strips are equipped with individually adressble RGB-LEDs and are fully compatible with Aura Sync, however they can also come with a controller and ensure spectacular RGB lighting effects in every case.
The Bitfenix Enso Midi-Tower at a Glance:
- Extremely stylish Midi-Tower for motherboards up to E-ATX
- ASUS Aura Sync compatible RGB lighting & RGB controller
- Large tempered glass side panel with sound dampening
- I/O panel with 2x USB 3.0 & HD Audio In/Out
- Support for two radiators in 280- and 120 mm formats
- 2x 3,5/2,5″ & 3x 2,5″ drive slots
- 2x 120 mm fans come pre-installed with a total of 5 possible
- Graphics cards up to 34 cm long & CPU coolers up to 16 cm
>>> To the Bitfenix Enso Cases at Overclockers!
Insulated Tempered Glass Window & Dynamic RGB Lighting
The Enso is available in black or white colour variants and offers impressive integrated RGB lighting with individually addressable LEDs in the front. Moreover the large transparent windows consists of 4 mm thick tempered glass which is then insulated with sound dampening foam rubber. The interior allows drive storage to be installed in a cage in the PSU shroud or behind the motherboard tray. This clever use of space ensures an incredibly clean aesthetic since the cables nearly completely disappear behind the motherboard tray and in the PSU shroud.
Dust filters are located on all the inlets and exhausts of the case and are able to be removed with a minimum of effort, without having to turn over the case. Excellent airflow is also guaranteed via two pre-installed 120 mm fans, one of which comes with static RGB lighting. A total of five fans can be installed. Water cooling enthusiasts can also install up to 280 mm radiators in the front and a 120 mm heat exchanger in the back.
Alchemy 3.0 Adressable RGB-LED Strips with Aura Sync Support
In addition to the Enso line of cases BitFenix is also presenting a new range of their Alchemy LED strips. These are available in 30 and 60 cm lengths and are now equipped with individually addressable TriBright RGB-LEDs. Thanks to compatibility with ASUS Aura Sync they can allow users to create some incredible lighting effects while also synchronising said effects with other components, if they are connected with the respective 3-pin header of an ASUS Aura Sync compatible motherboard.
Bitfenix is also offering Command Kits with RGB controllers to allow pre-programmed colour schemes and lighting modes to be set. LED strips, controllers and the remote control are held in place with the help of magnets or double-sided adhesive.
>>> To the Bitfenix Alchemy 3.0 LED strips at Overclockers! <<<
(click here)
