You read that right. 8Pack has only gone and smashed some world records on the Supernova MK3!
The Best There Ever Will Be
By popular demand, Ian “8Pack” Parry has put the Supernova MK3 to the test, to show off its gaming muscles. With a whopping seven RTX 4090 GPUs and an AMD Threadripper Pro CPU, there is nothing this beast can’t handle.
To fully demonstrate what the Supernova MK3 is capable of, 8Pack has benchmarked the CPU, GPU, and its gaming prowess using Cinebench, V-Ray, Corona 10, and Blender. You can check out the scores below.
Watch the Supernova MK3 in Action!
Why just take my word for it, when you can watch it for yourself!
Get Record-Breaking Performance in Your Own Home
The best bit about all this, you can bring record-breaking performance to your own set-up. That’s right, the 8Pack Supernova MK3 is available to buy from Overclockers UK.
8Pack Supernova MK3 Extreme PC
- Overclocked and water-cooled extreme PC
- AMD Ryzen Threadripper Pro 7995WX CPU
- 7 x NVIDIA GeForce RTX 4090 GPUs
- 512GB 5600MHz DDR5 quad-channel memory
- Custom water-cooling loop
PC specs are subject to change.
