Building a Gaming PC for Indie Game Development
We’re looking at the make-up of a gaming PC designed for indie game development.
Thanks to the likes of Unreal Engine 5 and crowd funding programs like Kickstarter, the dream of being an indie game developer is more accessible than ever. You don’t even need a Threadripper-powered PC with multiple RTX 5090s, either! In this article, we’re going to virtually build an indie game development PC, detailing why we’ve picked each component.
What Do You Need for an Indie Game Development PC?
An indie game development PC needs to be equipped with hardware that can handle game development software like GameMaker, Unity, and Unreal Engine (external links). These require high-speed components and lots of memory, to keep operations smooth while you work on your gaming masterpiece.
Using Unreal Engine 5 (external link) as our example, you need a quad-core 2.5GHz CPU, 32GB of RAM, a GPU with at least 8GB of VRAM and is DirectX 11 or 12 compatible, and Windows 10 64-bit version 1909 revision .1350 or higher. In terms of the processor and graphics card, this translates to an Intel Core i5 / Ultra 5 or AMD Ryzen 5 tier CPU and at least an NVIDIA RTX 3060 GPU.
On top of this, it’s recommended that with any intensive workflows you should be running the program from an SSD. Their lack of moving parts means they can work much faster than HDDs, so your game dev software will run with near-zero lag and latency. High-capacity HDDs are great for mass file storage, but opting for a 1TB NVMe SSD with ultra-fast read and write speeds is always going to be better for your applications.
Mach 3 Game Room
Our Indie Game Development PC
For this indie game development PC, we’ve balanced these recommended specs with future proofing so this computer can serve you well through a dev career. And because we like a challenge, it’s all-white too.
ComponentSpecification
MotherboardASRock Z890 Pro RS WiFi ATX Motherboard
CPUIntel Core Ultra 5 245K CPU
GraphicsASUS GeForce RTX 4070 Super Dual EVO OC 12GB GDDR6X GPU
MemoryTeamGroup Xtreem 32GB DDR5 7600MHz Dual-Channel RAM
StorageSamsung 990 Evo 1TB M.2 NVMe SSD
PSUSeasonic Focus GX-850 ATX 3.1 80 PLUS Gold Modular PSU
CoolingTRYX PANORAMA 280mm AIO
TRYX ROTA PRO 140mm PWM Fans
PC caseHAVN HS420 Mid-Tower PC Case
The Motherboard: ASRock Z890 Pro RS WiFi ATX Motherboard
The ASRock Z890 Pro RS WiFi ATX Motherboard is the perfect foundation for your indie game dev PC. Featuring an LGA 1851 socket, it is compatible with the latest Intel Core Ultra CPUs and has support for DDR5 RAM up to 8666MHz, PCIe 5.0, and Thunderbolt 4, for all the high-speed connections and data transfer you need. As an ATX motherboard, there are plenty of ports for storage and RAM, so you can upgrade or expand these solutions as needed.
Asrock Z890 Pro RS WIFI White (LGA 1851) DDR5 ATX Motherboard
Intel Core Ultra 5 245KF (Arrow Lake) Socket LGA 1851 Processor - Retail
The CPU: Intel Core Ultra 5 245K CPU
The Unreal Engine 5 specs call for a quad core 2.5GHz CPU, and the Intel Core Ultra 5 245K more than qualifies, with fourteen cores (6P + 8E), fourteen threads, and a base clock speed of 4.6GHz. The hybrid core architecture is intelligently managed by Intel Thread Director, ensuring the best core is always on the job. What’s more, this processor has a dedicated NPU which is designed to handle AI workloads, taking the strain off your CPU and GPU.
Graphics: ASUS GeForce RTX 4070 Super Dual EVO OC 12GB GDDR6X GPU
Once again, we have gone a little higher than the recommended 8GB VRAM graphics card, with the ASUS GeForce RTX 4070 Super Dual EVO OC GPU. This sports 12GB GDDR6X video memory, paired with all the innovations that came with Ada Lovelace architecture. As such, the RTX 4070 is more than capable of building your indie game (and playing the latest AAAs when you need some down time!).
Asus GeForce RTX 4070 SUPER Dual EVO OC 12GB GDDR6X PCI-Express Graphics Card -White
TeamGroup Xtreem 32GB (2X16GB) DDR5 PC5-60800C36 7600MHz Dual Channel Kit - White
Memory: TeamGroup Xtreem 32GB DDR5 7600MHz Dual-Channel RAM
For complex processes, you need high-capacity RAM to keep operations efficient, latency low, and everything running smoothly. We’ve opted for the recommended 32GB in a dual-channel configuration here, but there is nothing stopping you from going for 64GB or even higher and potentially even in quad-channel – the ASRock motherboard supports that. This TeamGroup Xtreem 32GB RAM kit utilises the DDR5 memory standard, for improved bandwidth and performance, at frequencies up to 76000MHz.
Storage: Samsung 990 Evo 1TB M.2 NVMe SSD
The Samsung 990 Evo SSD provides both ample storage and low latency. The 1TB capacity will be more than enough for your applications, files, and even a few cheeky games (for inspiration, naturally). Plus, with read and write speeds of 5000MB/s and 4200MB/s, respectively, your creative process won’t be hampered by slow loading screens and long data transfer times. Keep the productivity going!
Samsung 990 Evo 1TB M.2 2280 PCI-e 4.0 / 5.0 Hybrid NVMe Solid State Drive
With all those extra M.2 ports, you could always add more storage as and when you need it. Using a combination of drives for files, programs, and even your operating system can help keep everything running smoothly.
Seasonic Focus GX-850 ATX 3.1 850W 80 Gold Modular Power Supply - White
The PSU: Seasonic Focus GX-850 ATX 3.1 80 PLUS Gold Modular PSU
Making sure your PC is properly powered is imperative. You need to ensure you have the right wattage and that you’re using a power supply with a high-efficiency rating. 80 PLUS Gold is the efficiency rating, providing reliable performance while remaining accessibly priced. As for wattage, you can use a PSU calculator to help work out what you need. I already did the legwork for you, and our calculator recommended a PSU between 700W and 1000W.
As such, we’ve gone for the Seasonic Focus GX-850 Modular PSU here. The 850W will provide more than enough headroom while the ATX 3.1 standard means this PSU is ready to handle the demands of the RTX 4070 Super. Plus, as it’s modular, you only need to plug in the cables you need, to keep your indie development PC looking sleek and clutter free.
Cooling: TRYX PANORAMA 280mm AIO and ROTA PRO 140mm PWM Fans
While you and your PC work hard on creating the next viral indie game, you need a cooling system that will keep up. Using the TRYX PANORAMA 280mm AIO (pictured) and a collection of ROTA PRO 140mm PWM fans, you can create a thermal solution that is effective and looks stunning too. Take advantage of adjustable fan and pump speeds, creating high static pressure and efficient heat transfer. The all-white aesthetic goes perfectly with the rest of the hardware, too, but it’s the PANORAMA’s AMOLED screen that cinched this decision for us. This AIO features a first-of-its-kind 3D L-shaped AMOLED display which can be used to display pre-made 3D content or your own unique designs. Perhaps a showcase of your indie game?
TRYX PANORAMA 280mm AIO Liquid Cooler ARGB White
HAVN HS 420 VGPU PC Case
The Case: HAVN HS420 Mid-Tower PC Case
In truth, it was a toss-up between the HAVN HS420 base and VGPU (pictured) editions – and there are no wrong answers here really. Both are optimised for airflow, have extensive support for hardware, and can accommodate all the components we’ve picked out here. It’s just if you wanted that spicy vertical GPU mount or not. So heck it, we’re linking both and if you want a detailed review of this PC case, you can check that out here
Whichever one you choose, you’ll have a phenomenal view of the interior thanks to the UniSheet glass. This tempered glass panel has been curved with industry leading techniques, to create minimal distortion for a truly panoramic display.
Paired with Peripherals
To complete your indie game development set-up, you’ll need some peripherals! For your monitor, you want something with plenty of real estate, a crisp resolution, and accurate colour reproduction. A 27” 1440p IPS monitor hits the sweet spot, we reckon. As for your keyboard and mouse, you should be using something that will remain comfortable with extended use and suit your typing or grip style. For more specific recommendations, 60% keyboards are popular among programmers, for their compact size, and MMO mice provide plenty of buttons for mapping shortcuts to streamline your workflow. But whatever your preference, we have plenty of monitors, keyboards, and mice for you to choose from.
BenQ 27″ PD2705Q Design and Productivity Monitor
  • 27” IPS monitor optimised for design and productivity
  • 2560 x 1440 resolution with 60Hz refresh rate
  • SRGB 100% and HDR10
  • 1000:1 contrast ratio
  • Adjustable colour temperature
BenQ 27" PD2705Q 2560x1440 IPS 60Hz sRGB 100% HDR Design and Productivity Monitor
Ducky One 3 Pro Nazca Line 60% Cherry MX2A Red Switch Mechanical Gaming Keyboard
Ducky One 3 Pro Nazca Line 60% Gaming Keyboard
  • 60% mechanical gaming keyboard
  • Genuine Cherry MX2A Red Switches with linear feedback
  • 8000Hz polling rate
  • Quack Mechanics for optimised typing
  • Hot-swapping technology
Razer Naga V2 HyperSpeed Wireless Gaming Mouse
  • MMO gaming mouse with 19 programmable buttons
  • Razer HyperSpeed low latency wireless
  • Tactile cycling and free-spin modes on scroll wheel
  • Up to 250 hour battery life
  • 30K optical sensor
Razer Naga V2 HyperSpeed Wireless USB MMO Gaming Mouse (RZ01-03600100-R3G1)
Not Ready to DIY?
If building your own indie game development PC seems a little out of your skill set, we have plenty of pre-built and custom gaming PCs ready to fit the bill at Overclockers UK. Our pre-built PCs are fully assembled, tested, and ready to go, while our custom PCs offer the option to adjust the base spec to better fit your needs. Explore our ranges today!
OcUK Gaming Graphite - Intel Core I7 12700KF, RTX 4060Ti Pre-Built Gaming PC
OcUK Gaming Graphite – Intel Core I7 12700KF, RTX 4060Ti Pre-Built Gaming PC
FS-PB02-EP
★★★★★ (5)
£1199.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
OcUK Gaming Condor - AMD Ryzen 7 7800X3D, RX 7900 XTX Gaming PC
OcUK Gaming Condor – AMD Ryzen 7 7800X3D, RX 7900 XTX Gaming PC
SYS-OCG-00071
★★★★★ (5)
£2649.98 £ 2549.99
-3.77%
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
OcUK Gaming Khopesh - AMD Ryzen 7 7700X, RTX 5070 Ti Gaming PC
OcUK Gaming Khopesh – AMD Ryzen 7 7700X, RTX 5070 Ti Gaming PC
FS-124-OG
★★★★★ (5)
£2299.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Indie Game Inspiration
You have the tools, now get some inspiration! We spotlight a different indie game each month in our Indie Showcase. Here is a spicy cross-section of the series:
Indie Showcase January: ANTONBLAST
May Indie Showcase: Viewfinder
September Indie Showcase - Dave the Diver
What’s in Your Indie Game Development Build?
What specs are you rocking for your indie game development needs? Let us know in the comments below!
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
