For safety reasons, this product has been voluntarily recalled. To learn more, read CableMod’s full statement here. This includes instructions on how to remove the adapter from your system.
The NVIDIA GeForce RTX 40 Series has brought next generation gaming to our beloved PCs, but it has also brought a new connector. As well as some teething issues to boot. With the CableMod 12VHPWR Angled Adapters, things just got a whole lot easier.
![CableMod 12VHPWR Angled Adapter in use](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapetr-in-action-1024x576.webp)
What Does The CableMod 12VHPWR Angled Adapter Do?
The CableMod 12VHPWR Angled Adapters have been designed to simplify the connectivity to your NVIDIA GeForce RTX 40 Series graphics card. This latest generation of GPU is considerably wider than previous models, and is leaving a limited space between it and the side panel of your PC case. As such, routing and bending cables through this gap can be tricky. By implementing the CableMod 12VHPWR Angled Adapter, you are taking the routing away from this zone and into a much more accessible area.
The adapters are 16-pin female-to-male connectors, orientated either on a 90-degree or 180-degree angle. Which you opt for depends on your graphics card. Thanks to its intelligent multi-PCB design, there is full contact between the terminals, thus making connections incredibly secure. Cheeky bonus, there is a reduced risk of thermal issues caused by wire or terminal stress!
Available Models
As previously touched on, there are a number of CableMod 12VHPWR Angled Adapter models available. Firstly, you can choose between a 90-degree or 180-degree model. These are then also split into two variants, Variant A and Variant B. Their primary difference is how the 16-pin connector is orientated. Variant A has the 16-pin header above the side-band pins, whilst Variant B is the other way around.
In short, there are four models to choose from. Which you choose will depend on the graphics card you have. To help you select which adapter you need, here are all four models and the GPUs with confirmed compatibility:
CableMod 12VHPWR 90-Degree Angled Adapter Variant A
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant A](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/CableMod-12VHPWR-90-Degree-Angled-Adapter-Variant-A.webp)
- NVIDIA GeForce RTX 4090 Founder’s Edition (backplate side)
- ASUS ROG Strix GeForce RTX 4090 (cooler side)
- ASUS TUF Gaming GeForce RTX 4090 (cooler side)
- Gigabyte AORUS GeForce RTX 4090 MASTER (backplate side)
- Gigabyte GeForce RTX 4090 Gaming OC (backplate side)
- Gigabyte GeForce RTX 4090 WINDFORCE (backplate side)
- MSI GeForce RTX 4090 SUPRIM LIQUID X (backplate side)
- EK Quantum Vector2 Strix TUF RTX 4090 (cooler side)
- EK Quantum Vector2 RTX 4090 FE without active backplate (backplate side)
CableMod 12VHPWR 90-Degree Angled Adapter Variant B
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/CableMod-12VHPWR-90-Degree-Angled-Adapter-Variant-B-300x300.jpeg)
- NVIDIA GeForce RTX 4090 Founder’s Edition (cooler side)
- ASUS ROG Strix GeForce RTX 4090 (backplate side)
- ASUS TUF Gaming GeForce RTX 4090 (backplate side)
- Gigabyte RTX 4090 GAMING OC (cooler side)
- EK Quantum Vector2 RTX 4090 FE without active backplate (cooler side)
- EK Quantum Vector2 Strix TUF RTX 4090 (backplate side)
CableMod 12VHPWR 180-Degree Angled Adapter Variant A
![CableMod 12VHPWR 180 Degree Angled Adapter – Variant A](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/CableMod-12VHPWR-180-Degree-Angled-Adapter-Variant-A-300x300.webp)
CableMod 12VHPWR 180-Degree Angled Adapter Variant B
![CableMod 12VHPWR 180 Degree Angled Adapter – Variant B](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/CableMod-12VHPWR-180-Degree-Angled-Adapter-Variant-B-300x300.jpeg)
- Gigabyte GeForce RTX 4090 GAMING OC (backplate side)
Please note: “backplate side” and “cooler side” refers to which direction the cable will be once the adapter is installed. “Backplate side” means the cable will run along the GPU backplate, whilst “cooler side” means it will point towards the GPU cooler.
Still not sure which one you need? CableMod has thought of everything. They have 3D printing files for all four models available for you to download, for free! If you have a 3D printer, you can whip up a quick adapter and see if it fits before purchasing.
Eleven Colourways!
Think you’ve already got enough choices on your hands? Think again! Each model is available in eleven colourways! Check them out below and start picturing how they’ll look in your gaming PC!
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B Black](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-black.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B Light Blue](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-light-blue.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B Red](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-red.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B Blue](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-blue.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B orange](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-orange.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B Silver](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-silver.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B Gold](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-gold.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B Pink](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-pink.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B White](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-white.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B Green](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-green.webp)
![CableMod 12VHPWR 90 Degree Angled Adapter – Variant B purple](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/cablemod-adapter-purple.webp)
Grab One Today
Like the look of this cable solution? The CableMod 12VHPWR Angled Adapters are available to pre-order from Overclockers UK today!
- Angled adapters for the 12VHPWR port
- Either 90- or 180-degree adapters
- Each available in two variations
- Eleven exciting colourways
- Female-to-male port
![CableMod 12VHPWR 180 Degree Angled Adapter – Variant A](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/CableMod-12VHPWR-180-Degree-Angled-Adapter-Variant-A-light-blue-300x300.jpeg)
