We’ve put together this guide to help you answer that burning question – can my PC run it? Here you can double-check the specs of the most demanding games your system could encounter.
![Can My PC Run It?](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/2210-can-my-pc-run-it-blog-1024x1024.jpg.webp)
Cyberpunk 2077
![Cyberpunk Edgerunners screenshot](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/cyberpunk2077_edge_pc_v_gun_night_rgb_EN-1024x576.png.webp)
Component | Minimum Specs | Recommended Specs |
Operating System | Windows 10 64-bit | Windows 64-bit |
Processor | Intel Core i5-3570K AMD FX-8310 | Intel Core i7-4790 AMD Ryzen 3 |
Memory | 8 GB RAM | 12 GB RAM |
Graphics | NVIDIA GeForce 970 AMD Radeon RX 470 | NVIDIA GeForce GTX 1060/GTX 1660 Super AMD Radeon RX 590 |
DirectX | Version 12 | Version 12 |
Storage | 70 GB available space | 70 GB available space |
Having undergone a renaissance thanks to its Edgerunners 1.6 content update, more people than ever are looking to give Cyberpunk 2077 a go. If you want to explore Night City in all its dystopian glory, though, you’re going to need one powerful gaming PC. Minimum settings alone ask for 8GB of RAM and a GTX 780. If you want to look at 4K with 60 FPS, you’ll need a beast of a system. The Infin8 Venomous is a great choice if you want to bring out Cyberpunk 2077’s beauty. Plus, it’s a phenomenal aesthetic match!
Infin8 Venomous (FS-46K-OE)
![Infin8 Venomous](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/infin-venomous-main-300x300.png)
Available from £5,199.98*
Specification |
HYTE Y60 Dual-Chamber ATX Case |
Asus ROG Strix Z690-F LGA 1700 DDR5 ATX Motherboard |
Intel Core i7-14700K Socket LGA1700 Processor |
NVIDIA GeForce RTX 4080 Super GDDR6X PCI-Express Graphics Card |
Corsair Vengeance 32GB (2x16GB) DDR5 Dual Channel Kit |
God of War
![god of war pc combat](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/01/god-of-war-gameplay-combat-1024x576.jpg.webp)
Operating System | Windows 10 64-bit | Windows 10 64-bit |
Processor | Intel Core i5-2500K AMD Ryzen 3 1200 | Intel Core i5-6600K AMD Ryzen 5 2400G |
Memory | 8 GB RAM | 8 GB RAM |
Graphics | NVIDIA GeForce GTX 960 AMD Radeon R9 290X | NVIDIA GeForce GTX 1060 AMD Radeon RX 570 |
Storage | 70GB available space | 70GB available space |
One of the best games to come to PC from console this year is also one of the most demanding. Fitting for gruff old Kratos. God of War was a gorgeous game on the PS4 and looks even better on PC. To make sure you’re not worrying whether your system can run it, we recommend picking up the Refract Gaming Celeste. The whole Refract Gaming PC range is designed so you can plug and play the titles you want to rather than spend time wondering “can my PC run it?” You don’t want to keep Kratos waiting, boy.
Refract Gaming Celeste (FS-1DH-EP)
Specification |
Kolink Unity Lateral Mid Tower Case |
AMD DDR5 ATX Motherboard |
AMD Ryzen 7 7700X CPU |
NVIDIA GeForce RTX 4070 Graphics Card |
32GB DDR5 Dual Channel Kit |
![Refract Gaming Celeste 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-celeste-hero-300x300.jpg)
Available to order with next day delivery for £1,799.99*
Dying Light 2
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/dying-light-2-knife-combat-1024x576.jpg.webp)
Operating System | Windows 7 64-bit | Windows 10 64-bit |
Processor | Intel Core i3-9100 AMD Ryzen 3 2300X | Intel Core i5-8600K AMD Ryzen 5 3600X |
Memory | 8 GB RAM | 16 GB RAM |
Graphics | NVIDIA GeForce GTX 1050Ti AMD Radeon RX 560 | NVIDIA GeForce RTX 2060 AMD RX Vega 56 |
Storage | 60GB available space | 60GB available space |
It takes a lot to make running across rooftops and drop-kicking zombies look so good. Whether you’ve wanted to jump on Dyling Light 2 since it first came out or since we learned we were getting DLC for it, this game demands a lot from your PC. Even its recommended specs, needed to play the game at 1080p with 60 FPS, are brutal with an RTX 2060 needed. Seriously, the way this game uses ray-tracing is enough to make any PC sweat. Luckily for you, the OcUK Gaming Katana can handle it, and then some. Not only does it smash those recommended specs, it has an effortlessly cool all-white aesthetic you can build an epic gaming setup around.
OcUK Gaming Katana (FS-1EA-OG)
![OcUK Gaming Katana - Intel i7 14700KF, GeForce RTX 4070 Ti Super Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/ocuk-gaming-katana-kolink-case-pc-300x300.jpg)
Available from £2,299.99*
Specification |
Kolink Unity Peak ARGB Mid Tower PC Case |
B760 ATX DDR5 WiFi Motherboard |
Intel Core i7 14700KF Twenty Core Processor |
NVIDIA GeForce RTX 4070 Ti Super 16GB GDDR6X GPU |
32GB DDR5 Dual Channel RAM |
Far Cry 6
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/far-cry-6-dani-female-scaled-1-1024x653.jpg.webp)
Operating System | Windows 10 | Windows 10 |
Processor | Intel Core i5-4460 AMD Ryzen 3 1200 | Intel Core i7-7700 AMD Ryzen 5 |
Graphics | NVIDIA GeForce GTX 960 AMD Radeon RX 460 | NVIDIA GeForce GTX 1080 AMD Radeon RX Vega 64 |
While you will by no means be on a vacation in Far Cry 6, the island of Yara is a picturesque paradise nonetheless. This is a game so gorgeous that noblechairs made a gaming chair for you to comfortably topple governments from to go with it. But is your gaming PC able to bring this war-torn island to life? If it isn’t, the Refract Gaming Azure is ready to step in. Perfectly primed to give you a leg up on those recommended settings, this system is a great shout for a smooth experience.
Refract Gaming Azure (FS-1DP-EP)
Specification |
Kolink Observatory Z Mesh Mid Tower Case |
AMD AM5 DDR5 ATX Motherboard |
AMD Ryzen 7 7800X3D Processor |
NVIDIA GeForce RTX 4070 Ti Graphics Card |
32GB DDR5 Dual-Channel Kit |
![Refract Gaming Azure 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-azure-hero-300x300.jpg)
Available to order with next-day delivery for £2,199.95*
Halo Infinite
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/11/halo-infinite--1024x572.png.webp)
Processor | Intel Core i5-4440 AMD Ryzen 5 1600 | Intel Core i7-9700K AMD Ryzen 7 3700X |
Graphics | NVIDIA GeForce GTX 1050 Ti AMD Radeon RX 570 | NVIDIA GeForce RTX 2070 AMD Radeon RX 5700 XT |
Storage | 50GB available space | 50GB available space |
A new season starting in Halo Infinite is always a good time for new and returning players to boot up the game, provided their system can shoulder it. Halo Infinite demands a surprising amount which is why we suggest grabbing the Refract Gaming Indigo. It’s not only got the hardware to handle Halo’s hefty specs, but it’s a great choice if you’re interested in streaming your gameplay too.
Refract Gaming Indigo (FS-1DN-EP)
![Refract Gaming Indigo 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-indigo-hero-300x300.jpg)
Available to order with next-day delivery for £2,899.99*
Specification |
Kolink Citadel Mesh ATX Case |
AMD Ryzen 9 7900X3D Processor |
NVIDIA GeForce RTX 4080 Super Graphics Card |
Assassin’s Creed Valhalla
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/assassins-creed-valhalla-world-1024x576.jpg.webp)
Component | Minimum Specs | Recommended Specs | Ultra 4K |
Operating System | Windows 10 64-bit | Windows 10 64-bit | Windows 10 64-bit |
Processor | Intel Core i5-4460 AMD Ryzen 3 1200 | Intel Core i7-4790 AMD Ryzen 5 1600 | Intel Core i7-9700 AMD Ryzen 7 3700 |
Memory | 8 GB RAM | 8 GB RAM | 16 GB RAM |
Graphics | NVIDIA GeForce GTX 960 AMD R9 380 | NVIDIA GeForce GTX 960 AMD R9 380 | NVIDIA GeForce RTX 2080 AMD RX 5700XT |
DirectX | Version 12 | Version 12 | Version 12 |
Storage | 130GB available space | 130GB available space | 130GB available space |
Even with more Assassin’s Creed games on the horizon, Valhalla still has plenty to offer. A breathtaking world that’s absolutely filled with things to do, vistas to stop and stare at, it’s worth every second you play. But we know exactly what you’re thinking as you look at Assassin’s Creed Valhalla’s Ultra 4K requirements – can my PC run it? Well, if your gaming PC is the Germanium Z7 then the answer is yes! This beast of a system is stacked with next generation hardware, both a fourteenth generation Intel Core i7 CPU and an NVIDIA 4090 GPU.
OcUK Gaming Germanium Z7 (FS-1EC-OG)
Specification |
Phanteks Evolv X ATX Glass Mid Tower Case |
Gigabyte Z790 Aorus Elite AX Motherboard |
Intel Core i7 14700KF Sixteen Core Processor |
RTX 4090 24GB GDDR6X Graphics Card |
32GB DDR5 5200MHz Dual Channel Kit |
![OcUK Gaming Germanium Z7 PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/ocuk-gaming-germanium-z7-pc-300x300.jpg)
Available from £3,999.95*
![Can My PC Run It?](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/2210-can-my-pc-run-it-blog-300x300.jpg)
We’ve been over demanding games, but what about demanding software? Don’t worry, we got you! Head on over to part two of this series, where we look at the specs of some popular yet tricksy software.
What Else Does Your PC Need to Run?
Are there any other games pushing your hardware past its limits? Maybe there’s some software you need to get running smoothly? Comment below so we can help you answer the question – ‘can my PC run it?’
*Prices correct at time of writing and PC specs are subject to change.
