It is one of our favourite humble brags to say we stock award-winning products. APNX has joined the ranks after scoring iF Design Awards.
![Celebrating Outstanding Style: APNX Wins iF Design Awards](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/apnx-if-award-square-1024x1024.png)
APNX has been recognised for their stylish designs, earning the iF Design Awards in Gaming/VR/AR. Time to crack out the bubbly and cake to celebrate!
What is the iF Design Awards?
iF Design Awards are globally recognised as a hallmark of outstanding design achievement. Their mark is put on products that demonstrate exceptional ideas, function, form, impact, and uniqueness.
APNX
APNX, or Advanced Performance Nexus, is part of the Pro Gamersware alliance and debuted at CompuTex 2023. They officially hit our shelves back in October 2023, with a range of PC cases, fans, and AIO coolers to elevating our style and thermal performance.
![APNX Build Your Story](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/blog-apnx-brand-150x150.png)
For the full APNX breakdown, head over to our dedicated blog.
iF Design Award in Gaming/VR/AR
Back to the important stuff.
APNX won an iF Design Award in the Gaming/VR/AR category. Technically, they won three! The APNX C1 Case, AP1-V CPU Cooler, and FP2 Fans were each recognised as an outstanding design achievement. These products underscore the depth of expertise behind APNX and the Pro Gamers Group as a whole, showing the brand’s ascent to the PC hardware industry boundaries.
![iF Design Award 2024](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/if-design-award-2024.png)
Receiving these awards so early on in our brand’s journey is a tremendous honour and a testament to the strength and resourcefulness of all of the industry veterans within Pro Gamers Group that helped make this happen. We wanted to bring original aesthetics to our performance-driven products, and this means we’re doing something right.
Tony Lin, APNX CEO
Add Some Award-Winning Style to Your Set-Up
If your gaming set-up is begging for unique designs that perfectly marry form and function, you can pick up any of these award-winning products from Overclockers UK.
APNX C1 PC Cases
![APNX C1 PC Case ChromaFlair](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/apnx-c1-pc-case-cf-2-300x300.png)
Features |
Mid-tower PC case with rounded edges |
4 x pre-installed fans |
395mm GPU clearance |
Available in three colours |
APNX AP1-V CPU Coolers
![APNX AP1-V CPU Cooler white](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/apnx-ap1-v-cooler-white-1-300x300.png)
Features |
CPU air cooling tower |
RGB lighting |
5 x 6mm heat pipes |
Two colours available |
APNX FP2 Fans
![APNX FP2 120mm Fan Black](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/apnx-fp2-120-fan-black-2-300x300.png)
Features |
120mm ARGB PWM fans |
Reverse fan blades included |
83.87CFM airflow and 3.49mmH2O static pressure |
Congratulations APNX
Well done to APNX!
