![Streacom DB1 banner](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/04/Mobile-EN-Streacom-DB1.jpg)
You don’t need a large case to bring out the best in your gaming PC. Streacom is well-known for manufacturing small, fanless cases which excel at passive cooling with first-rate results. The Streacom DB1 Ultra-Compact Fanless Mini-ITX Case is their latest innovation. This case is designed to bring out the full potential of the current-gen APUs.
The Streacom DB1 comfortably handles 45W of cooling, making it ideal for power-efficient systems. Furthermore, it’s compatible with both Intel and AMD motherboards, making this case a great choice for a variety of gaming PCs.
At just 4.98 litres in volume, the DB1 Mini-ITX chassis is the most compact case to come out of Streacom yet. Combining Streacom’s approach to fanless cooling and the DB1’s sleek anodised finish, there’s no compromise on design or performance. Therefore, this PC case is an excellent space-saver for any gaming desk.
Features of the Streacom DB1 Ultra-Compact Fanless Mini-ITX Case at a Glance
- A space-saving, mini-ITX form factor – Streacom’s most compact case to gaming PC case to date
- A premium extruded aluminium design, complete with a sleek anodised finish
- Passive fanless cooling up to 45W via 6mm copper heat pipes
- Compatible with Intel and AMD motherboards
- Sizable air vents in the chassis further optimise natural airflow
- Versatile build, allowing it to perform perfectly in both horizontal and vertical positioning
- Motherboard and CPU installation is easier than ever thanks to its simple, modular design
Innovative Fanless Cooling
With the Streacom DB1, the case itself is the cooler. The left side panel of this aluminium chassis acts as the heatsink, absorbing heat transferred from the CPU via 6mm copper heat pipes. Soon after, the case’s large heat fins dissipate the heat into the ambient air, providing effective and quiet cooling.
![The DB1 heat sink](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/04/streacom-db1-heat-sink.png)
Operating in complete silence, the fanless and ultra-compact Streamcom DB1 Mini-ITX Case easily handles up to 45W of passive cooling. Without the noise of a fan, this PC gaming case gives you the opportunity for even deeper immersion in your gaming sessions.
The Streacom DB1’s large air vents additionally enable a natural airflow, further boosting the cooling of your PC’s components. Even when you’re playing the most power-hungry triple-A titles, this small yet functional PC chassis makes sure you’ll never have to worry about overheating.
Ultra-Compact, Versatile & Modular
4.98 litres in volume, the DB1 Mini-ITX Case is the most compact chassis by Streacom to date. Only slightly bigger than the mini-ITX motherboard it accommodates, this case is the ultimate space-saver. Why? The compatible Nano PSU (sold separately). Sporting an efficient and fanless design, this PSU takes up minimal room with no sacrifice on performance, like the rest of the case.
![streacom db1 2.5 drive nano psu](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/04/streacom-db1-2.5-drive-nano-psu.png)
The Streacom DB1 has been designed to operate flawlessly in both vertical and horizontal positions. Another fantastic feature is that the case is conveniently modular, allowing the USB 3.0 port to be moved to either side of the case. Finally, you can swap the Type-A 19PIN module with any Type-CPin 3.1 Gen 2 alternative to suit the task at hand.
![Streacom DB1 Ultra-Compact Fanless Mini-ITX Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/GESC_086_01-1024x1024.jpg)
All in all, the Streacom DB1 Mini-ITX Case is a stylish, well-performing wonder. Seamlessly, this case will fit into your setup and equip you with the versatility to fit your needs.
Premium Simplicity
Streacom gaming PC cases are built to last, all whilst looking refined and performing impeccably. The Ultra-Compact DB1 Mini-ITX case is no exception.
Streacom has combined these premium materials – 4mm thick extruded aluminium panels, a 21mm extruded heat sink, solid aluminium rods, made using CNC milling, and complete with a sandblasted, anodised finish – to present a competitively priced gaming PC case with a high-end aesthetic.
![Streacom DB1 Ultra-Compact Fanless Mini-ITX Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/GESC_085_10.jpg)
In the Streacom DB1’s inarguable elegance lies exquisite functionality. The entire case can be disassembled by simply undoing the eight screws on the side panels. Therefore, you’ll be able to install your motherboard and CPU cooler with ease you never thought possible.
Finally, as the DB1 case is symmetrical in design, the side panels can be rotated to perfectly fit whichever orientation is ideal for your mini-ITX gaming PC.
![Streacom DB1 Ultra-Compact Fanless Mini-ITX Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/GESC_086_04-1024x1024.jpg)
Make the most of the finest in fanless cooling by buying the Streacom DB1 Ultra-Compact Mini-ITX Gaming PC Case at Overclockers UK! Available in black and silver, your gaming desk is about to be met with the very definition of style and superb performance.
- 45W passive fanless cooling
- Ultra-compact 4.98 litre volume
- Fits horizontal & vertical orientations
- Manufactured from premium high-quality materials
![Streacom DB1 Ultra-Compact Fanless Mini-ITX Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/GESC_085_01-1024x1024.jpg)
