Shadow Warrior 3 from Flying Wild Hog released in 2022.
The third instalment of the franchise, this game has got it all. Blood, guts, and wall running – set to a jaunty soundtrack. Self-aware and delightfully tongue in cheek, this is a great game to turn off after a hard day’s work and blow off steam. Coming up, we have the game specs and a few PC recs to go with them.
What is Shadow Warrior 3 About?
The third instalment of the Shadow Warrior franchise, you play as Lo Wang, a wise-cracking, fallen corporate shogun. With his former boss Orochi Zilla, who was then his nemesis and is now his sidekick, Wang must complete his mission to recapture an ancient dragon. One that he absolutely accidentally freed from its eternal prison. Travelling to uncharted corners of the world and fighting yokai at every turn, it’s going to take some work to fend off the impending apocalypse.
Shadow Warrior 3 is a first-person shooter with a twist. As well as, an eclectic mix of firearms, Wang takes a katana into battle and can even wield some magic. New to this game, he is also equipped with a grappling hook which you can use to fling enemies into the many environmental traps. This nimble character can also air dash, wall run, and double jump across the battlefield and areas to explore.
Set in neo-feudal Japan, this game takes place in a beautiful Asian land that perfectly blends magic, ancient samurai technology, and excessive gore. Take down demonic yokai with killer finishing moves and enjoy the picturesque landscape. It’s an odd juxtaposition, but it works!
Shadow Warrior 3 Specifications
With such phenomenal graphics and fluid movement, you’d expect this game to demand a lot from your gaming PC. Instead, this game can be run at 60 FPS on 1080p resolutions on a GeForce GTX 1080! Here are the full minimum and recommended specifications for Shadow Warrior 3.
Component | Minimum Spec | Recommended Spec |
Operating System | Windows 7* 64-bit | Windows 10 64-bit |
Processor | AMD Phenom II X4 965 (4 core) Intel Core i5-3470 (4 core) | AMD Ryzen 7 2700 (8 core) Intel Core i7-6950X (10 core) |
Memory | 8GB RAM | 8GB RAM |
Graphics | NVIDIA GeForce GTX 760 AMD Radeon R7 260X | NVIDIA GeForce GTX 1080 AMD Radeon RX 5700 |
Storage | 31GB | 31GB |
Additional Notes | Spec for 1080p @ 30FPS on low settings | Spec for 1080p @ 60FPS on high settings |
Best PCs to Play Shadow Warrior 3
At Overclockers UK, we stock an exciting range of gaming PCs and laptops that are perfect for Shadow Warrior 3. We’ve picked out a few highlights from our collections, but should these not fit your vibe, you can explore the full offerings by clicking the buttons below.
Refract Gaming Indigo Pre-Built PC
Bring Shadow Warrior 3 to life in gory detail with the Refract Gaming Indigo. This pre-built PC is packed with premium, cherry-picked hardware that will provide phenomenal performance in all your favourite magical FPS games. The AMD Ryzen 9 7900X3D CPU is equipped with intelligent 3D V-Cache to optimise operations, whatever your workload. Plus, the NVIDIA GeForce RTX 4080 Super GPU brings the very best of Ada Lovelace architecture to the table, rendering your games in photo-realistic quality in 4K.
As part of our Refract Gaming range, the Indigo comes with our comprehensive three years parts and labour warranty, giving you that extra peace of mind should anything go wrong.
Medion Erazer Beast X40 Gaming Laptop
Play Shadow Warrior 3 on-the-go, with the Medion Erazer Beast X40. This gaming laptop features an Intel Core i7-13700HX CPU, powering your gaming with hybrid architecture. The blend of P- and E-cores are intelligently managed by Intel Thread Director, making sure the best core is always on the job. The 17.3” QHD+ display with 240Hz refresh rate expertly works with the NVIDIA GeForce RTX 4080 GPU to render every gory detail in crisp resolutions and high frame rates. Enjoy highly immersive gaming, wherever you are.
To keep this beast cool, the thermal solution has been optimised with liquid metal, to ensure there are no air gaps between vital components and their heat spreader. Plus, with Dynamic Boost 2.0 and Whisper Mode 2.0, you can configure the Medion Erazer Beast X40 to best suit your performance needs.
OcUK Gaming Eagle Configurable PC
Take your in-game parkour skills to new heights, with the OcUK Gaming Eagle. Equipped with an Intel Core i9-14900KF CPU, there is little this gaming PC cannot process thanks to its impressive twenty-four cores and thirty-two threads. This is paired with the AMD Radeon RX 7900 XTX GPU, a high-performance graphics card powered by RDNA 3 architecture. Enjoy the latest innovations from AMD to enhance your gaming.
The OcUK Gaming Eagle is one of our configurable gaming PCs. This means you can customise the specification from a pre-selected list of hardware to better suit your needs, budget, and gameplay style. Adjust the PC case, CPU, memory, GPU, cooler, braided cables, operating system, and choose up to three high-speed SSDs. Please note that any changes will affect the pricing.
Execute then Annihilate
Is Shadow Warrior 3 one of your go-to FPS games? Let us know your thoughts in the comments below.
PC specs are subject to change.
