Hear, what you can’t see. That’s what the Cherry Xtrfy H2 Pro Gaming Headset was designed for. It should support gamers and eSport professionals in the best possible way. With the H2, Cherry Xtrfy now offers a successor for the already very successful H1 Pro Gaming Headset. With the Cherry Xtrfy H2 no opponent remains hidden, because every acoustic detail can be heard in crystal clarity. Even conversations with other players are no longer drowned out in noise. Even lighter and more robust construction compared to its predecessor is complemented by extra-large memory foam earpieces for hours of exceptional comfort. The Cherry Xtrfy H2 Pro Gaming Headset is now available for pre-order at Caseking.
The H2 Pro Gaming Headset from Cherry Xtrfy was designed by professional gamers for the best gaming experience. Extra-large ear pads with memory foam and a stable aluminium headband ensure particularly long-lasting wearing comfort. The memory foam is coated with high quality PU leather to improve acoustics. With only 360 grams the whole headset remains extremely light.
![Xtrfy H2 Pro Gaming Headset - side image](https://img.overclockers.co.uk/media/image/Xtrfy_H2_Hero.png)
Overview the features of the Cherry Xtrfy H2 Pro Gaming Headset:
- Specially designed for gaming and eSports
- Low weight and high quality materials
- Memory foam for extra comfort
- High frequency response for a clear sound
- Removable microphone
- Comprehensive compatibility
Cherry Xtrfy has drawn on the experience of professional gamers to create a high-quality headset with selected components and features that help improve player performance. The two dynamic 53 mm drivers with a frequency response of 15 to 25,000 Hz and an impedance of 32 Ohm provide a rich sound. The detachable microphone and braided cable make the headset also suitable for everyday use. Since the Cherry Xtrfy H2 Pro Gaming Headset uses 3 or 4 pin jack connection it is compatible with virtually any device – not just PCs but consoles or smartphones .
