Landing at Overclockers UK today, we have four new products in the Kolink Range. The Stronghold Prime, two additions to the Observatory range with the Y aRGB and Y Mesh, plus a Vertical GPU Kit. There has never been a better time to be in the market for a new, premium mid-tower case. There’s something for everyone too – especially fans of the classic black, RGB lovers, and hardware enthusiasts.
Three Cases and a GPU Bracket
All three of the cases can accommodate some impressive hardware, with each of them supporting up to E-ATX motherboards, 380mm long GPUs, and vertical GPU mounting, thanks to the Vertical GPU Kit. Plus, all three cases have extensive cooling options which make them particularly suited for water-cooling hardware. This is what all three of these cases can accommodate:
- Front: 3 x 120 / 140mm fans or 1 x 240 / 280 / 360mm radiator
- Top: 3 x 120mm / 2 x 140mm fans or 1 x 240 / 280 / 360mm radiator
- Rear: 1 x 120 / 140mm fan or 1 x 120 / 140mm radiator
Naturally, they have individual features as well, tailoring them to suit the various needs of PC gamers and enthusiasts. Here’s a closer look at each of the cases and the GPU bracket.
Kolink Stronghold Prime
Specification |
All-black mid-tower chassis with metal and glass panelling |
Hinged tempered glass door held by magnetic tab |
E-ATX motherboard |
Triple-slot, 380mm long GPU |
2 x 3.5” HDDs and 3 x 2.5” SSDs |
Removable panels for ease of access when installing |
Extensive fan and radiator support |
Includes 2 x Kolink Classic PWM 120mm fans |
The Stronghold Prime cuts a classic shape, with its all-black panelling and tempered glass door. Thanks to its removable panels and hinged door, every nook and cranny is easy to access – making installation a breeze. Across the chassis are mesh areas to provide ample ventilation and airflow, all bolstered by the inclusion of two Kolink Classic PWM 120mm fans. What’s more, this case also has fan mounts on the PSU shroud cover, supporting two 120mm fans, to further improve airflow and cooling in the second chamber.
The Stronghold Prime is a great case for enthusiasts that like to keep aesthetics simple. Whilst its glass panel provides an excellent showcase, the quintessential black colouring does not need adorning with RGB lighting to look incredible. Unless that’s your thing, black is a brilliant backdrop. You do you.
Kolink Observatory Y aRGB
Specification |
Black mid-tower chassis with glass front panel |
4 x Kolink Classic PWM/aRGB 120mm fans |
Extensive fan and radiator support – ideal for custom water-cooling |
E-ATX motherboard |
Side ventilation and top mesh panel for impressive airflow |
aRGB lighting on fans |
For the Observatory Y aRGB, it is all about the colour. Three of the four Kolink Classic PWM/aRGB 120mm fans are showcased on the front panel behind tempered glass. Innovative side ventilation helps these fans to keep the air flowing within the chassis. Thanks to the spacious interior, this case lends itself to AiO or custom water-cooling systems. This case even allows for dual-radiator custom set-ups.
Kolink Observatory Y Mesh
Specification |
Black mid-tower chassis with mesh front panel |
Extensive fan and radiator support – ideal for dual-radiator systems |
E-ATX motherboard |
Very similar to the standard aRGB model, the Observatory Y Mesh aRGB features a mesh front panel for improved airflow. The RGB lighting still shines through, with vivid brilliance. Making this case a great contender for gaming and/or workstation PCs is the flexible and extensive storage solution. The PSU shroud holds a drive cage that supports two 3.5” HDDs whilst the rear of the motherboard backplate has mounts for three 2.5” SSDs. You can bulk up your bytes and save your games to faster drives.
Kolink Vertical GPU Kit
Specification |
Vertical mounting GPU kit |
230mm flat and malleable PCIe 3.0 riser cable |
Steel bracket to install on backplate |
Compatible with all triple-slot GPUs |
Compatible with select Kolink cases |
All-black aesthetic for blending in with chassis |
Easy to install |
Comprised of a PCIe riser cable and a steel bracket, the Kolink Vertical GPU Kit has everything you need to vertically mount your GPU. The cable utilises Gen 3 PCIe technology and is 230mm, perfectly tailored for extending the connection on your motherboard. Manufactured from steel, the bracket replaces the backplate and is very easy to install.
For compatibility, this kit can be used with any triple-slot GPU currently available. For cases, it was designed to be used with the cases mentioned today – the Observatory Y aRGB/Mesh and Stronghold Prime – as well as the Observatory Z aRGB/Mesh. It should be noted, that the steel bracket is not required when using this kit in the Observatory Z range.
Available Now!
Any of these cases tickle your fancy? Feel like upgrading your graphics card to a vertical mount? All of these are now available at Overclockers UK.
Kolink Stronghold Prime Mid-Tower Case
- Supports up to E-ATX case
- Includes 2 x Kolink Classic fans
- All-black aesthetic
- Hinged tempered glass door
- Compatible with Kolink Vertical GPU Kit
Kolink Observatory Y aRGB Mid-Tower Case
- Tempered glass front panel
- Mesh and side ventilation
- Includes 4 x Kolink Umbra fans
- Supports up to 380mm long GPU
- Dedicated PSU Shroud
Kolink Observatory Y Mesh aRGB Mid-Tower Case
- Mesh front panel
- RGB control button as part of I/O
- 2 x 3.5″ HDDs and 3 x 2.5″ SSDs
- Removable panels for easy access
- Black, steel bracket
- 230mm flat PCIe 3.0 cable
- Easy to install
- Supports all triple-slot GPUs
- Compatible with select Kolink Cases
