We all know that equipping your battle station with a noblechairs gaming chair is one of the best ergonomic moves you can make. Plus, with the likes of the Black and Java Series, you could make a bold statement with your aesthetics too. Go. Bolder. Introducing the noblechairs White Series, all models available. Whether you like the HERO, EPIC, or ICON, you can enjoy a sleek, all-white chair from the kings of comfort.
Hybrid Upholstery
Like its brethren, the noblechairs White Series uses a high-tech vinyl upholstery that was designed, developed, and produced in Germany. The manufacturing process results in a material with microfine pores, making this fabric highly breathable. Permeable to both air and water vapour, you will stay fresh as a daisy even during those long gaming sessions. Not only that, this material is incredibly hard-wearing and its overall durability contributes to the sustainability of this chair. (One for all the green gamers out there!)
As well as keeping you comfortable, this material repels dirt making it oh-so-easy to maintain and keep clean. Plus, with amazing lightfast properties, no amount of exposure to sunlight will make this material fade. Your noblechairs White Series gaming chair is going to stay as sleek as the day you assembled it.
![nobelchairs White Series with all three models](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/10/Blog-noblechairs-WhiteEd-blank-1024x1024.png.webp)
The Line-Up
EPIC
![noblechairs EPIC Gaming Chair White Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/10/EPIC-White-Edition_0000.png.webp)
Specification |
4D armrests |
Adjustable ergonomics |
White upholstery |
Dense cold foam padding |
60mm casters with Nylon core |
With its stylish wings and white fabric, the EPIC is going to look amazing in any gaming environment. The stainless-steel frame is highly durable and provides an excellent foundation. Further bolstering this is the powder-coated, aluminium base. Each of the five points ends in a 60mm, Nylon core caster which has been primed for use on both soft and hard flooring. Seamlessly glide over carpet and wooden flooring alike. It’s reasonable to take this chair to every table in the house, right? The hybrid upholstery is easy to clean, so it’s not like you have to worry about dinner stains.
HERO
![noblechairs HERO Gaming Chair White Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/10/HERO-White-Edition_0006.png.webp)
Specification |
Stainless steel frame |
Largest model in the range |
5-point base |
Highly breathable upholstery |
All-white aesthetic |
The HERO is the largest in the noblechairs range, sporting a wider seat base and backrest. Padded with a dense cold foam, the cushioning on this chair won’t depress over time thanks to its deform-resistant properties. With full ergonomic support, you can configure your HERO to suit your exact needs – adjusting the recline, tilt, and height with easy-to-use mechanisms. Plus, the DIN EN 1335 office certification means you show off your chair on Zoom calls and be the envy of the whole office. Alternatively, remain in glorious comfort throughout serious gaming marathons – it’s what this chair was designed for after all.
ICON
![noblechairs ICON White Edition Gaming Chair](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/10/ICON-White-Edition_0001.png.webp)
Specification |
Rounded headrest |
Innovative white fabric |
Comprehensive adjustments |
Safety Class 4 gas lift |
DIN EN 1335 certified for office use |
Featuring a rounded headrest, the ICON sports the same durability and adjustability as the other models. Its iconic 4D armrests feature PU leather padding which strikes an amazing balance between comfort and grip. These can be manoeuvred through four directions – height, depth, angle, and distance – allowing you to perfectly align yourself to your desk and maximise comfort. Plus, this chair is able to support up to 150kg in weight, with a Safety Class 4 gas lift that smoothly operates over 10cm of height adjustment. Juicy.
Bonus Feature
Each chair comes with its own matching pillow set, including a headrest and lumbar pillow. These plush, velour cushions are padded with a dense memory foam that will retain its shape regardless of how intensively you game. With their stretchy bands, they can be placed anywhere on the backrest of your chosen chair – maximising the comfort and support for your individual needs. Plus, they are machine washable at 40-degree. I can’t be the only one who constantly has half their mind on laundry…
![noblechairs White Series Vibrantly Flawless](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/10/Mobile-EN-noblechairs-WhiteEd-1024x341.jpg.webp)
Upgrade Now!
The noblechairs White Series is available for pre-order now at Overclockers UK. Whether you are refreshing your aesthetic or upgrading an old and tired chair, these gaming chairs are a great addition to your setup. Drop a comment below and tell us if you’re a HERO, EPIC, or ICON!
- Fully adjustable ergonomics
- Innovative hybrid fabric
- All-white design
- Includes noblechairs Pillow Set
- DIN EN 1335 certified
![noblechairs EPIC Gaming Chair White Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/10/EPIC-White-Edition_0013.png.webp)
![noblechairs HERO Gaming Chair White Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/10/HERO-White-Edition_0013.png.webp)
- Dense cold foam padding
- Hybrid white fabric upholstery
- Stainless-steel frame with aluminium base
- Full lumbar support
- Highly durable construction
noblechairs ICON Gaming Chair White Edition
- Rounded headrest
- German made hybrid fabric
- Deform resistant fabric
- Easy to clean and maintain
- 60mm casters designed for soft and hard flooring
![noblechairs ICON Gaming Chair White Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/10/ICON-White-Edition_0013.png.webp)
noblechairs LEGEND Series: November 2022
There’s another sleek all-white gaming chair ready for you to get your hands on! The noblechairs LEGEND White edition. A part of the brand-new LEGEND series, this chair has been built with high-tech PU leather, this gaming chair will remain strong battle after battle. Its crisp, ice-white design makes this chair the ideal choice for your sleek all-white gaming setup.
You can take a closer look at the noblechairs LEGEND White edition in our blog post.
![noblechairs LEGEND Series](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/noblechairs-LEGEND-1024x1024.png.webp)
