From May 30th to June 2nd, CompuTex Taipei 2023 will be taking place in Taiwan. Here at Overclockers UK, we’ll be covering every day of the event, bringing you all the incredible new products and computing innovations as they are revealed.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Computex2023-blog-1024x1024.jpg)
What is CompuTex?
Established in 1981, CompuTex Taipei is a global computer and technology expo.
The four-day event consists of hundreds of different product showcases and innovations from leading technology manufacturers, whether this is a brand-new line of cutting-edge graphics cards or efficient desktop processors.
Each year of CompuTex has a specific focus. In 2023, this is six different themes:
- High-Performance Computing
- Artificial Intelligence Applications
- Next-gen Connectivity
- Hyperreality
- Innovations and Startups
- Sustainability
CompuTex 2023
CompuTex 2023 promises just as many incredible exhibits as the years before it. Countless global manufacturers and technology retailers are in attendance, including Overclockers UK and the rest of the Pro Gamers Group!
This year’s event features over 3,000 booths from over 1,000 companies from nearly 26 different countries. Each one promising to unveil its latest tech and innovations.
Day 4 – June 2nd
CompuTex is over and we’ve loved seeing all the cutting-edge innovations and new tech that has been announced. Whilst today might have been the last day, the exciting announcements haven’t stopped, so here are our top highlights from day 4.
First up is the brand-new range of PC cases from Cooler Master and Fractal Design.
The Cooler Master Qube 500 is a flatpack case that comes deconstructed, allowing you to piece together all the parts of your case yourself. Completely modular, it’s extremely versatile yet capable of supporting up to E-ATX motherboards, GPU clearance of up to 365mm, and a 280mm radiator!
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Coolermaster-Qube500-1024x681.jpg)
What’s more, you can freely swap between different coloured panels to ensure your case perfectly matches your aesthetic. This includes yellow, mint, pink, and cream.
Leading PC case manufacturer Fractal Design has also showcased their brand-new Terra Mini-ITX PC case.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/FractalDesign-Terra.jpg)
At only 343 x 153 x 218mm this SSF PC case is the perfect choice for gamers with small minimalistic set ups. With folding gull-wing doors on both sides and a sliding top panel, installation becomes super easy.
Constructed from aluminium, it boasts enhanced durability, whilst the solid wooden slab on the front panel adds that extra stylish touch. Plus, all the panels are sand blasted and anodised, which gives them a bit of a sparkle up close! Available in silver, jade, and graphite, you can find a variant that is sure to effortlessly blend into your set up.
Making more innovations for graphics cards is MSI. Not only have they made improvements to the traditional 16-pin power connector, but also revealed their new NVIDIA RTX 4070 Ti X Gaming Slim GPU.
MSI’s simple change to the 16-pin GPU power cables makes it obvious whether or not it’s plugged in correctly.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MSI-GPUpowercables.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MSI-GPUpowercables1.jpg)
Adjusting the colour of the micro-fit connector allows you to easily see if your cable isn’t plugged in correctly, which should, hopefully, reduce the risk of poor power connections affecting your GPU.
The latest NVIDIA RTX 40 Series are known for their hefty size and requiring big PC cases with enough GPU clearance. However, to combat this, MSI revealed their NVIDIA RTX 4070 Ti Gaming X Slim graphics card.
This revamped GPU still packs in all the powerful gaming essentials but with a redefined shroud to make it slightly slimmer. Now with a 2.2-slot design, this GPU requires two slots on your case and motherboard.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/U5Pn7gHTFUhzsrabzKpxQL-970-80-1.png)
What’s more, to combat excess heat and temperatures, this GPU includes a brand-new cooling system. The trio Torx 5.0 cooling fans have been built at a 22-degree angle to ensure enhanced pressure even at slow fan speeds. This improves airflow by up to 23% compared to traditional axial cooling fans.
The NVIDIA RTX 4070Ti Gaming X Slim will still require a single 16-pin power connector and offer various display connectivity options such as HDMI and DisplayPort.
Next up, is the Gigabyte RTX 4090 Gaming Box. Designed to enhance your gaming laptop’s performance, this gaming box features a water-cooled external graphics card. You can connect this to your laptop via ultra-fast USB Thunderbolt 3 connectivity.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Gigabyte-RTX4090.jpg)
Surrounding the powerful RTX 4090 is an all-one-cooling system featuring a 240mm radiator, two 120mm fans, and a large copper plate. All of these work in tandem to effectively dissipate heat and ensure optimum temperatures, even under intense loads.
The RTX 4090 is capable of performing at up to 2,520 MHz and boasts all of the cutting-edge features of the latest NVIDIA RTX 40 Series. This includes enhanced Ray Tracing and AI capabilities.
If you’re streaming set up is in need of an upgrade, then Cooler Master also unveiled the MasterHUB.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/CoolerMaster-MasterHUB.jpg)
The MasterHUB has been designed to streamline your live streams and content creation. Completely modular, you can opt to add nine different separate modules to this hub, including touchscreens, sliders, and knobs, to ensure it perfectly suits your needs.
There will be three different sets available – the Video Editor kit, the Photo Editor kit, and the Gamer kit.
In addition to all of this, racing sim fans rejoice for EK has surprised us all and revealed their very first racing simulator – the EK Sim Racer.
This racing set-up features a 32:0 curved display, haptic feedback, a responsive wheel and gear sticks, timing belts, RGB lighting and so much more. All of which deliver ultra-fast immersive racing action.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/7FJkcyrE34o8USoz-1024x788.jpg)
Powering this racing sim is a pre-built EK liquid-cooled gaming PC. This is optional and you can instead choose to use your own system.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/oQNOGUlFiwB1Mjzi-1024x768.jpg)
Last but not least, we want to highlight some of the incredible custom builds and case mods that have been on display for the last four days. This ranges from PCs installed within pyramids, towers, Alien facehuggers, and even volcanos!
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/P1080856-769x1024.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/P1080860-769x1024.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/P1080866-769x1024.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/P1080869-1024x769.jpg)
Day 3 – June 1st
CompuTex is nearly drawing to a close but that doesn’t mean day 3 wasn’t filled with more incredible tech showcases and reveals. Here’s a complete rundown of all the highlights from today!
Kicking things off is the incredible liquid-cooled GPU from ASUS. The ROG Matrix 4090 on display at CompuTex is the very first GPU with liquid metal cooling.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/ASUSROGMatrix-4090.jpg)
Moving away from traditional thermal paste, the liquid metal has been directly applied to the GPU’s die, resulting in superior performance and enhanced cooling. This is boosted even further thanks to the included 360mm radiator, daisy-chained fans, pump, and cold plate, all of which combined notably reduce temperatures.
To complete the look, the ROG Matrix 4090 is stored within a unique casing finished with RGB lighting, for that extra splash of colour.
Also unveiled by ASUS is the ultra-wide ROG Swift OLED PG49WCD monitor.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/ASUSROGSwift-PG49WCD.jpg)
This huge 49” ultra-wide monitor boasts a QD-OLED panel and up to 5120 x 1440 display resolution. This monitor comes packed with everything you need to enjoy ultra-fast immersive gaming. This includes up to 144Hz refresh rates, 0.03GTG response time, and a sleek 1800R curvature.
Global manufacturer Montech is in attendance at CompuTex and has announced their latest range of PC hardware. This includes PC cases, power supplies, peripherals and much more!
First up is the Air 903 Max. This PC case supports up to E-ATX form factors and has been built with a focus on enhanced cooling. The front mesh panel features up to 51% ventilation rate, whilst the four pre-installed 140mm fans draw any excess heat away from your components.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Montech-Airo903Max.jpg)
In addition to this, Montech has also unveiled the Air 300 and 3000 MAX. Both of these cases are capable of supporting up to RTX 4090 GPUs and feature a detachable top bracket and patented quick-slide metal dust filter.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Montech-Air300Max.jpg)
The Air 300 Max is an ATX case with support for up to 230mm radiators and includes both 140mm and 120mm ARGB PWM fans.
Alternatively, the Air 3000 Max is a full tower chassis boasting support for top, front, and side 360mm radiators and up to four pre-installed ARGB PWM fans.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Air3000Max.jpg)
Designed for gaming royalty, there is the King 95.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Montech-King95.jpg)
This incredible PC case is capable of supporting numerous different customisation options and features a curved glass panel for an unrestricted panoramic view of all your powerful gaming hardware.
The King 95 can support up to 360mm radiators, has plenty of space for hefty GPUs such as the NVIDIA RTX 4090, and also includes a detachable top bracket for stress-free installation and maintenance.
The other PC cases announced by Montech include the Sky Two GD and GX.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Montech-SkyTwoGD.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Montech-SkyTwoGX.jpg)
In addition to all of this, Montech also announced their new series of power supplies – Titan PLA.
These ATX 3.0 compatible power supplies are capable of effectively handling the heavy power demands of the NVIDIA RTX 40 Series and have been built utilising high-quality materials, such as 100% Japanese 105°C capacitors.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Montech-TitanPSus.jpg)
For enhanced efficiency, these PSUs feature an 80 Plus Platinum rating and will be available in 750, 850, 1000, and 1200W variants.
Last but not least is the MKey Mini keyboard and MGrip Mouse.
The MKey Mini is a wireless small form factor mechanical keyboard. Equipped with pre-lubed Glorious Gateron G Pro 2.0 switches, a noise-dampening silicone pad, and PBT keycaps, enjoy a virtually silent and smooth typing experience.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Montech-MKey.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Montech-MGrip.jpg)
What’s more, the MGrip is Montech’s brand-new gaming mouse. Built with a PAW 3395 sensor, high-quality Ormon switches, and a DPI of up to 26,000, unlock superior precision and control, along with lightning-fast response times.
Plus, weighing only 57g, this mouse is incredibly lightweight for enhanced comfort during long hours of gameplay or work.
If you’re after some new peripherals and accessories, then Varmilo, Cooler Master, and Endgame Gear have answered your prayers.
Just look at these colourful and unique keyboards.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/VarmiloKeyboard-1.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/VarmiloKeyboard-2.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/VarmiloKeyboard-3.jpg)
Not only do these keyboards feature beautiful and unique designs, but they also come packed with loads of essential gaming features. As mechanical keyboards, you can find variants with multiple different types of key switches, ranging from Cherry, Kalih, and Gateron. Plus with durable PBT keycaps, you can enjoy that smooth fast typing experience.
Cooler Master also announced their range of peripherals and streaming accessories.
Designed to help level up your streaming set up there is the Stream Lucid Microphone.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Stream-Lucid.png)
This USB-C microphone allows for crystal clear audio whilst the built-in filter reduces any unwanted background popping or static. Perfect for creating high-quality audio for livestreams, voice recording, and content creation.
What’s more, the Stream Origins capture card will record and capture all your incredible gaming action at up to 4K resolutions at 60 FPS. Connect via USB, this capture card is plug-and-play ready.
Both the SH711 and MH731 headsets have been expertly crafted to deliver unmatched high-fidelity audio.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/SH711.png)
The SH711 is a wireless headset built with 40mm speakers, ANC, and a unique dual-chamber design to deliver crystal-clear immersive audio.
Alternatively, the MH731 headset features 50mm speakers and a closed-back audio design to offer high-fidelity realistic audio. Whilst the broadcast-quality boom microphone ensures your teammates will hear you loud and clear.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MH731.png)
In addition to all of this, Cooler Master also announced the MK700 Mechanical Gaming Keyboard.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MK770-MACARON.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MK770-MGFGOW.jpg)
These wireless mechanical keyboards have been designed for enthusiasts. As the first gasket-mounted keyboard, it comes equipped with Kalih Box V2 switches, hot-swappable switches, 3-way precision wheel, and PBT double-shot keycaps.
There are multiple different colour variants and aesthetics, meaning you are sure to find an MK770 that perfectly suits your style.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MK770-AOT.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MK770-CMG.jpg)
What’s more, if beautiful sakura patterns is your chosen aesthetic then, you’re in luck!
Cooler Master revealed their latest sakura limited-edition peripherals – the CK721 mechanical keyboard, MM712 gaming mouse, and the MP511 XL mouse pad.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MP511-Speed-Edition-XL-Sakura-Limited-Edition-1024x513.png)
Last but not least, Endgame Gear showcased their brand-new line of OP1 gaming mice.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/20230529081639_IMG_7060-1-1024x683.jpg)
The OP1 is a wired USB gaming mouse that has been designed with gaming enthusiasts and esports professionals in mind. Equipped with a combination of Kalih GX and GM 2.0 switches, a PixArt PAW 3395 optical sensor, and up to 26,000 DPI, enjoy superior control and ultra-fast response times. This is further boosted by the 650 IPS tracking speed and up to 50G acceleration.
The Endgame OP1 will be available in both black and white, with RGB and non-RGB variants available.
In addition to this, there is also the Endgame Gear OP1we. This wireless gaming mouse is equipped with both Kalih GO and GM 2.0 switches, a PixArt PAW 3370 optical sensor, and a DPI of up to 19,000.
Finally, if you’re looking for a way to make customising and synchronising your RGB lighting even easier, then take a look at Corsair iCUE Link.
With iCUE Link, you can daisy chain all your hardware, accessories, and RGB, into a unified system. This notably reduces the number of cables cluttering up your desk, for a cleaner build, but also makes installation a lot simpler.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Corsair-iCUElink-1024x576.png)
Every compatible iCUE Link component will feature a built-in microcontroller to communicate with the system hub, for seamless synchronisation. This hub will be able to support up to 14 different devices, ranging from fans, AiOs, water cooling blocks, LED strips, and much more.
Day 2 – May 31st
The second day of CompuTex is over and was once again jam packed full of innovative product reveals.
Our top highlight from day 2 has to be getting a glimpse at the upcoming noblechairs special edition gaming chair.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080820-769x1024.jpg)
The Shure gaming chair is the first special edition LEGEND model, utilising the brand-new redefined design to deliver exceptional comfort.
Built with premium quality materials with built-in adjustable ergonomics, tailor the noblechairs LEGEND Shure edition to suit your individual preferences. Whether this is the integrated lumbar support or 4D adjustable armrests.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080822-769x1024.jpg)
This chair is complete with its stylish black and grey design with green embroidery for that extra pop of colour.
Alongside these gaming chairs, we’ve also seen innovations being made in terms of RAM and graphics cards.
The brand-new Corsair Dominator RAM kits come equipped with everything you need, from high capacities, ultra-fast speeds, and integrated DHX cooling, but now also feature 3D-printed customisation.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Corsair-DominatorRAMKits.jpg)
These RAM kits include a fully replaceable top bar which you can freely customise with either Corsair’s own branded RGB top bars, or even 3D-print your own!
Alternatively, to help combat the hefty power demands and cable issues of the latest generation of graphics cards, ASUS revealed their prototype of an NVIDIA RTX 4070 running without any power cables.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/ASUS-RTX4070-withnocables.jpg)
This prototype is powered utilising a custom 600W slot on a motherboard instead of the traditional PSU power connectors.
This additional motherboard slot is similar in shape and size to a standard 1 x PCIe connection. It serves as a passthrough for the traditional 16-pin connection, which will still be running from the PSU. As such, these connectors will plug into the motherboard to then pass power to the GPU.
Overall, a cableless GPU offers multiple different benefits for PC builders looking to create the ultimate clean and cable-free system. However, if this model of GPU does enter the market, it’s expected to cost a lot more, considering you will need to also purchase a compatible custom motherboard to support it.
In addition to this, leading PC case and hardware manufacturer Hyte also showcased a few of their incredible PC cases, brand-new AiO CPU coolers, and keyboards.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Hyte-THICCQ60-AiO.jpg)
The THICC Q60 is Hyte’s answer to an AiO CPU cooler. Equipped with a combination of dual harmonic pumps, a hefty heat exchanger, and 32mm THICC FT12 fans, this powerful cooler will keep all your vital components cool and quiet. Plus, it also includes integrated qRGB lighting and an ultraslim IPS display, just for that extra unique touch to your system.
What’s more, also revealed at CompuTex is Hyte’s Keeb TKL keyboard.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Hyte-KeebTKL-keyboard.jpg)
This stunning, colourful TKL keyboard features Durock Creamy Yellow key switches and double-shot PBT shinethrough keycaps, to deliver an ultra-smooth typing experience. Whilst the gasket-mounted aluminium plate creates a distinctive ‘thonk’ with every keypress.
Designed to suit every kind of typist and gamer, this keyboard also includes detachable magnetic feet, which you can adjust between 4.7° and 7.6°, depending on your individual preferences.
All of which is housed within a translucent polycarbonate body, that is illuminated by the integrated RGB lighting, for an incredible light show.
Along with all these new products, Hyte also showcased their incredible PC cases. This included the Y60 and all-new Snow White Y40.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Hyte-Y60.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Hyte0Y40SnowWhite-798x1024.jpg)
be quiet! were another leading hardware manufacturer in attendance at CompuTex to reveal their upcoming line up of products, including PC cases, power supplies, and riser cables.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/be-quiet-logo-1024x333.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/bq_DarkBasePro901_1-1024x576.jpg)
First up is the Dark Base Pro 901. This all-new flagship PC case is capable of supporting up to E-ATX motherboards, and vertical GPU mounting, along with enhanced cooling and virtually silent operation. This is boosted by the removable noise-dampening panels and included Silent Wings PWM 140mm fans.
For those final finishing touches, the 901 features a tempered glass side panel, ARGB controller, and even a wireless smartphone charger!
Secondly, is the Dark Base 701, another brand-new PC case built from premium quality materials. The combination of mesh panels, support for up to 360mm radiators, and pre-installed Silent Wings 4 140mm PWM fans all result in improved airflow and cooling.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/bq_DarkBase701_Black_2-1024x576.jpg)
The Dark Base 701 is the perfect foundation for your next clean and tidy gaming PC, thanks to the integrated cable routing channels. Cable management will now become a breeze and you can enjoy your neat interior through the tempered glass side panel.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/bq_ShadowBase_Black_1-1024x576.jpg)
Thirdly, be quiet! also announced a brand-new case series – Shadow Base. This line of cases has been designed with a focus on airflow and maximum performance. The first set of cases in the series, Shadow Base 800 and 800 DX, will feature an intelligent open mesh design for enhanced cooling, support for up to E-ATX motherboards, and of course, integrated RGB lighting.
In addition to all of this, be quiet! is expanding on its incredible line of power supplies with the all-new Straight Power 12. This range of PSUs will be ATX 3.0 compatible, feature an 80 Plus Platinum rating, PCIe 5.0 compatibility, along with boasting a virtually inaudible operation.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/bq_StraightPower12-1-1024x576.jpg)
Lastly, to correspond with all of these incredible cases, be quiet! is also releasing a new riser cable in line with the Dark Base Pro 901. This riser cable will support vertical GPU alignments and will include a bracket to prevent any sagging.
Speaking of all things PC case related, Steamcom also announced their latest SG10 fanless PC case, F11 SFF PC case, and a brand-new hybrid SFX power supply.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Steamcom-SG10.jpg)
Redefining casing and cooling is the SG10. Built in collaboration with Calyos, the SG10 is a completely fanless PC case. Whilst it has no fans, this case is still capable of supporting high-performance GPUs and CPUs, thanks to powerful natural cooling, such as evaporation in the cooling loop.
Alongside the SG10, Steamcom also announced the FF1 SSF case.
Designed with horizontal and vertical placements and up to six different hardware configurations, the Steamcom FF1 boasts exceptional versatility. Whilst this case may have a small form factor, it is still capable of supporting up to ATX motherboards. Perfect for those looking to downgrade their hefty PC builds, without compromising on performance.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Steamcom-FF1.jpg)
Speaking of small form factor systems, Steamcom’s Z2800 is an all-new hybrid SFX power supply.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Steamcom-Z2800-PSU.jpg)
The Z2800 is an ATX 3.0 PSU that only features 6-pin ATX, instead of the traditional bulky 24-pin. What’s more, with the fully replaceable fans, the Z2800 is the first SFX PSU that allows you to customise the fan to perfectly suit your individual preferences.
Finally, if gaming laptops are more your thing, then Gigabyte announced that they will be adding three new laptops to their line up – the Aero 14, 16, and Aorus 17X.
Both the Aero 14 and 16 are OLED laptops that boast all the latest gaming hardware, including Intel 13th Gen processors and NVIDIA RTX 40 Series GPUs, along with plenty of support for high-speed connectivity options.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Aorus-15x-2023-Laptop-1024x683.jpg)
Alternatively, there is also the Aorus 17X. Designed to be Gigabyte’s latest flagship gaming laptop, it includes an NVIDIA RTX 4090 and i9 13980HX, for powerful next-gen gaming and content creation. This flagship laptop requires some serious cooling in order to perform at optimum temperatures. To combat this, the Aorus 17X features Gigabyte’s intelligent Vapour Chamber cooler design, to effectively dissipate heat away from vital components.
We can’t wait to see what gets unveiled on day 3, watch this space for more details and tech reveals tomorrow.
Day 1 – May 30th
The first day of CompuTex was packed full of incredible product reveals, tech innovations and much more.
Kicking the event off was the TAITRA opening press conference, in which the event’s key themes were highlighted once again. After this, the NVIDIA keynote, delivered by CEO Jensen Huang, showcased all the latest NVIDIA RTX 4060Ti graphics cards, advancements in AI, and an exclusive look at the brand-new NVIDIA Avatar Cloud Engine (ACE) technology.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/nvidia-ace-for-games.jpg)
Designed for gamers, ACE is a custom-made AI foundry service that has been developed to transform your favourite games. Thanks to AI-powered natural language interactions, game developers can now use ACE to create customised speech, conversation, and animation, for extra depth to their games.
Alongside this new AI-powered innovation, there were countless brand-new product announcements. This ranged from powerful gaming laptops, motherboards, monitors, and much more!
Kicking this off was the huge Pro Gamersware announcement.
Nine international gaming and tech brands have come together to form the ultimate collective group, known as ‘Pro Gamersware’, or PGW. This group of brands combined feature all the high-quality products you need to create the ultimate gaming, workstation, or home office set up. Whether this means you want PC hardware, peripherals, gaming and office furniture, or live-streaming equipment.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080809-1024x769.jpg)
Brands within the group include the likes of Ducky, noblechairs, Nitro Concepts, Streamplify, Endgame Gear, Kolink, ThunderX3, AeroCool, and Gamiac – who are all unveiling or showcasing new over the next four days at CompuTex.
Ducky:
Popular keyboard manufacturer, Ducky introduced their all-new line of mechanical gaming keyboards and mice. This included the Ducky ProjectD, One3 Pro, and Freedom keyboards, Feather and Secret M gaming mice, along with much more.
The highlights of which were the Ducky ProjectD Outlaw and One3 Pro Keyboards.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Ducky-ProjectD-Black-1024x576.png)
A completely custom keyboard, the Outlaw is the perfect choice for DIY and gaming enthusiasts. This mechanical keyboard boasts exceptional customisation thanks to its hot swappable switches, detachable USB cable, and much more. You can effortlessly swap between countless different types of key switches, whilst also personalising the QMK/VA software, to ensure your keyboard perfectly suits your individual preferences.
The ProjectD keyboards will be available in a variety of different options, meaning you’ll be able to find one that suits your desired aesthetic – whether this is an all-black modern look, or the crisp all-white.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Ducky-One3Pro-1024x683.jpg)
Ducky also introduced the Pro version of their popular One 3 series. This keyboard is still equipped with the exclusive QUACK mechanics and hot-swappable technology but has now been updated with an 8K polling rate.
Thanks to a plethora of different key switches and PBT triple-shot keycaps, unlock a smooth typing experience that perfectly suits your gameplay style and individual preferences.
AeroCool:
AeroCool revealed their new series of PC hardware, APNX or AeroCool Performance Nexus.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080753-1024x769.jpg)
APNX features product across all the different categories to ensure you’ll have everything you need to build the ultimate gaming PC. This includes a PC case boasting maximum cooling efficiency, both a AiO cooler and fan for exceptional airflow, and a high-quality PSU to deliver a consistent flow of power to all your components.
Streamplify:
Supplying you with all the equipment you need for your live-streaming, is Streamplify. Expanding on their line-up of dedicated streaming hardware, Streamplify have announced the all-new MIC Pro microphone and CAM Pro webcam.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080736-1024x769.jpg)
The MIC Pro is a second-gen condenser microphone designed to deliver high-res audio at the golden standard of 192kHZ/24-bit. With four different polar patterns, you’ll have complete control and customisation over your recordings. You can adjust and tailor the microphone to specifically suit what your task, whether this is interviews, live streaming, and much more.
What’s more, the CAM Pro is Streamplify’s very first 4K webcam. You can capture and record at up to 4K resolutions with smooth frame rates.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080735-1024x769.jpg)
Kolink:
Leading manufacturer of PC cases, Kolink also introduced a line of up brand-new products, including PC cases, water-cooling components, and power supplies.
The highlight of which were the PC cases and upcoming power supplies.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Unity-Lateral-ARGB.png)
The Unity Lateral ARGB is the latest mid-tower case, that has been optimised for gamers. This case comes equipped with support for all the latest hardware, including vertical GPU mounting support. To ensure exceptional airflow and cooling, the Lateral also features four Umbra PWM RGB fans with an included controller.
Secondly, the Unity Arena is a new high-quality mid tower that features sleek edge-to-edge front and side panels. Equipped with support for up to E-ATX motherboards, vertical GPU mounting, and up to 420mm radiators, this case is the perfect foundation for your next gaming set up.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Unity-Arena.png)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Unity-Peak-Case.png)
In addition to these PC cases, Kolink also revealed the Unity Peak. This PC case is compatible with a wide range of gaming hardware, including motherboards up to E-ATX, a GPU clearance of up to 420mm, and includes a PSU shroud. Plus, thanks to its edge-to-edge glass front and side panels, enjoy an unrestricted view of your entire system.
Lastly, Kolink announced the Observatory HF Glass and Mesh. Available in black or white, this PC case features a either a glass or full mesh front panel, for enhanced airflow and cooling. This is enhanced further thanks to the three included 140mm Umbra ARGB fans. This case comes equipped with everything you need to build your next system. This includes support for up to ATX motherboards, GPUs of up to 330mm, and 360mm radiators.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Observatory-HF-Glass-_-Mesh.png)
The final shining star in Kolink’s announcement was their upcoming PSU series – REGULATOR.
This line up of ATX 3.0 compatible power supplies will be available in four different wattages – 750W, 850W, 1000W, and 12000W, to meet the demands of every type of gamer. The key feature of the REGULATOR series is the virtually silent operation. These power supplies have been optimised to deliver a consistent and efficient flow of power, whilst minimising noise production.
Endgame Gear:
At CompuTex 2023, Endgame Gear will be highlighting all of their incredible gaming peripherals, ranging from gaming mice, mousepads, headsets, and microphones.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/EndgameGear-XM2We.jpg)
This inludes the latest XM2We Wireless Gaming Mouse. This high-quality gaming mouse features a PixArt PAW 3370 sensor, durable Kalih GO switches, and ultra-fast wireless connecitivity
Gamiac:
A brand-new gaming peripheral brand, Gamiac is being debuted at CompuTex 2023.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080720-1024x769.jpg)
This line up of peripherals have been designed with a focus on delivering affordable yet essential gaming features in every single product. This includes mechanical key switches, lightweight gaming mice, and 7.1 surround sound headsets.
ThunderX3:
Introduced by ThunderX3, is the flagship CORE gaming chair.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080661-1024x769.jpg)
The CORE chair has been built with a focus on premium ergonomics and high-quality comfort. This office chair features an updated tilt mechanism, six adjustable levels, lumbar support, memory foam cushion, and a retractable footrest.
NitroConcepts:
At CompuTex 2023, Nitro Concepts will be showcasing their latest line up of special edition gaming chairs.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080711-1024x769.jpg)
Made in partnership with Hasbro, the Nitro Concepts X1000 Transformer Chair has been built utilising premium quality materials for enhanced comfort, whilst emulating the look of three iconic Transformers.
noblechairs:
noblechairs is also in attendance, showcasing their incredible new LEGEND series of gaming chairs. The LEGEND gaming chairs feature a redefined shape, adjustable ergonomic functions, high-quality upholstery and materials, along with sleek aesthetics.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/P1080743-1024x769.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/noblechairs-Foot-Rest-v2-Black-Edition-0013-1024x1024.jpg)
Alongside the LEGEND series, noblechairs will also be highlighting the all-new V2.0 footrests. These footrests have been designed to deliver superior comfort and support. You can choose a footrest built from numerous different materials, including PU leather, real leather, breathable fabric, and much more.
Last, but definitely not least, noblechairs will also be teasing their upcoming special edition gaming chair made in collaboration with Shure.
Our other highlights from the day, include the reveal of the Glorious Model I 2 Wireless Gaming Mouse, plenty of exciting new MSI products, Phanteks PC cases, and all-new Lian Li cases and accessories.
Our top picks from MSI include their all-new gaming laptops, including the Prestige 16, Commercial 14, and exclusive Stealth 16 Mercedes-AMG Motorsport Laptop. Built in collaboration with Mercedes-AMG Motorsport, this laptop combines the modern style of Mercedes with premium powerful gaming hardware, perfect for fans of racing titles such as Forza Horizon 5 and F1 22.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/MSI-QDOLEDMonitors.png)
Alongside all of this, MSI also revealed their QD-OLED monitors. The 34” inch 342C monitor boasts stunning high-resolution images, rapid 0.03ms reponse times, HDMI 2.0 and USB Type-C connecitivity, along with support for next-gen consoles and PCs.
The highlight from Lian Li was their brand-new line up of four different PC cases. Each one boasts support for the latest gaming hardware and advanced cooling configurations with sleek modern-day aesthetics.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/LianLi-O11DEVOXL.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/LianLi-O11DEVORGB-removebg-preview.png)
Phanteks also unveiled a new line of up products, including two new PC cases, revolut power supplies, and a premium GPU bracket.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Phanteks-NV9.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/Phanteks-NV5.jpg)
The NV9 (pictured left) is a premium full tower featuing all the support for the latest gaming hardware along with exceptional airflow and cooling capabilities. This is especially thanks to support for up to 12 x 120mm or 11 x 140mm fans, and up to 480mm radiators!
What’s more, with the tempered glass side panel and integrated DRGB lighting control, it’s easy to set up and synchronise your RGB light show, which you can display with pride through those glass panels.
Alternatively, the NV5 is a brand-new mid tower equipped with support for all your cutting-edge gaming hardware. This includes compatiblity with up to 8 x 120mm fans and two 360mm radiators, to ensure steady airflow and enhanced cooling.
Plus, the included DRGB lighting is completely customisable, allowing you to synchronise this case with the rest of your battle station, for a unifed light show.
Our second top pick from Phantek’s announcement is their Revolut PSU collaboration with CableMod.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/PhanteksRevolut-CableMod.jpg)
You can now opt for a completely modular power supply without cables, which you can customise with cables from CableMod. All PSUs in the series feature either an 80 Plus Platinum or Titanium rating, and are ATX 3.0 compatible, meaning they can support the heavy-duty power demands of the NVIDIA RTX 40 Series.
Last but definitely not least, in case you missed the big reveal of 8Pack’s latest elite-tier workstation, the Domin8, here it is on display at CompuTex.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/computex-domin8.png)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/computex-domin8-ian.png)
You can read more about the 8Pack Domin8 in our dedicated blog article.
![8Pack Domin8](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/8Pack-Domin8-300x300.jpg)
Your Thoughts?
What do you think of all the incredible tech and innovations that have been revealed at CompuTex 2023 this year? Be sure to leave them below.
