The Lian Li Galahad II AIO CPU Cooler Series has just gotten even better, with the introduction of the phenomenal Lian Li Galahad II LCD AIO.
![Lian Li Galahad II LCD AIO cooler featured image](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/LianLi-Galahad-2-LCD-AIO-Square-1024x1024.jpg)
Lian Li Galahad II LCD AIO Launch Video
A First for Lian Li
What makes the Lian Li Galahad II LCD AIO stand out from its peers is the super sharp 2.88″ IPS display, Lian Li’s first CPU cooler to feature such a panel! This screen has a resolution of 480 x 480 pixels and is ideal for taking the aesthetics of your gaming PC to a new level.
So, what can you do with this extra display for your computer? Quite a lot really. For example, you can display system information, including CPU temperatures, GPU loads, and even act as a clock. What’s more, you can use it for displaying images. This could be a custom piece of artwork, maybe a selfie, or even your in-game screen captures. Show it off in style.
![280mm White Lian Li Galahad II LCD AIO cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/Lian-Li-LCD-280-AiO-300x300.png)
Alternatively, you could use the screen to add some animated magic to your gaming PC. This can be done in one of two ways, the first being using GIFs. Simply set a GIF instead of a static JPEG or PNG on the screen, and it will display perfectly. The second option is to use full video files such as MP4s. Maybe you have a favourite video of your pets, adventures, or some peak gaming content. All of these can be captured on this display. What’s more, up to three minutes of video can be stored in the internal memory of the Galahad II LCD AIO, allowing you to enjoy your favourite clips even when L-Connect 3 is not running.
If that wasn’t enough, you can customise the display even further as the Galahad II LCD comes with a range of special effects. These animations can be layered with your media to create unique finishes.
![Rain and Snow effects for the Galahad II LCD AIO](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/LCD-effects.png)
![Twist Hole and Mandala effects for the Galahad II LCD AIO](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/LCD-Backgrounds.png)
Controlling the Galahad II LCD AiO
Controlling the Galahad II LCD AIO is made simple. With Lian Li’s powerful L-Connect 3 software, you can adjust every aspect of the AIO cooler. This new version of L-Connect 3 now boasts options to control the display. Using the user-friendly controls, you can create a unique display for your screen. This software even has some editing options built in. Using L-Connect 3, you can crop the perfect section of an image to display, fine tune colours, rotate a picture, and even cut a video down to highlight the exact section you want to play.
![360mm Black Galahad II LCD SL-INF AIO](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/Galahad-II-SL-INF-360-300x300.png)
In addition to this, L-Connect 3 still retains its easy-to-use controls for lighting. This software allows you to adjust the integrated RGB LEDs on the pump block and fans. Additionally, you can control any Lian Li RGB product within your gaming PC with L-Connect 3, such as lighting kits or case fans. What’s more, you can sync all your lighting together to create mesmerising effects across your whole computer.
L-Connect 3 can also control the speeds of the vital cooling components, like the Galahad II LCD’s fans and pump. Creating a fan curve is made simple, allowing you to set your desired fan speeds for any loads. Maybe you’re not putting your PC under any strain, browsing the net, or writing a quick e-mail. When carrying out these light loads, you can set your cooling to whisper-quiet operation, where fans and pump speeds are reduced. Meanwhile, if you tax your gaming PC with a heavy load such as editing a video, then fan and pump speeds can be ramped up for maximum cooling.
![L-Connect 3 LCD controls](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/L-Connect-3-Options.png)
Cooling Performance
The Lian Li Galahad II LCD AIO is an amazing CPU cooler, coming in both 280mm and 360mm sizes, as well as being available in black or white finishes. You’re sure to find a model that will fit into your gaming PC. What’s more, there is the option to choose a 360mm model with outstanding Lian Li SL-INF UNI fans, for mind blowing RGB lighting.
Each model is equipped with an 8th Gen Asetek pump that delivers a 100W, which equates to about 2 degrees improvement in cooling performance over previous generations. To achieve this result, Asetek has refined the design of their pumps, such as including a precision engineered 3-phase motor, capable of delivering an increased flow rate whilst being quieter. Additionally, the tubes of the pump have been increased in diameter, allowing for more coolant to flow through them. The surface area of the cooling plate has been expanded, for better heat dissipation.
![360mm black radiator](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/Galahad-II-Rad-300x300.png)
To remove the heat from the coolant, Lian Li utilises 30mm thick radiators. Each radiator boasts 20 fins per inch, in a single wave configuration. Not only does this design offer excellent surface area, but also minimises air resistance, making it the perfect choice to pair with lower static air pressure fans.
Creating the Airflow
Now that I’ve mentioned the fans, how do the models packaged with the Galahad II LCD AIO perform? There are three of options for fans: the 280mm model comes with a pair of 140mm fans and the 360mm model is packaged with three 120mm fans. Meanwhile, the Galahad II LCD SL-INF AiO is equipped with three of the gorgeous 120mm SL-INF UNI fans. To see how each compare, check out the following table.
120mm ARGB | 140mm ARGB | 120mm SL-INF | |
Max Fan Speed (RPM) | 2450 | 1550 | 2100 |
Airflow (CFM) | 79.9 | 89.7 | 61.3 |
Static Air Pressure (mmH2O) | 3.26 | 2.99 | 2.66 |
Acoustic Noise (dB(A)) | 30 | 26.7 | 29 |
What CPUs Does This Cooler Work With?
The Galahad II LCD AIO is compatible with most modern CPUs available on the market, from both Intel and AMD. This includes Intel LGA 1700, 1200, and 115x sockets, alongside AMD AM4 and AM5.
Make your Gaming PC a Show
Are you after a CPU cooler that not only provides exceptional cooling for your processor, but also looks great? Then the Galahad II LCD AIO is the perfect choice. Get your order in for one at Overclockers UK today.
![280mm Black Galahad II LCD AIO](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/280_lcd_b-300x300.png)
Lian Li Galahad II LCD 280mm AiO
- 280mm radiator
- 2.88″ IPS LCD Display
- Compatible with both Intel and AMD CPUs
- 45-degree fittings for easy installation
- Two 140mm ARGB performance fans included
Lian Li Galahad II LCD 360mm AiO
- 360mm radiator
- Three 120mm ARGB performance fans included
![360mm White Galahad II LCD AIO](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/DSC6435-300x300.png)
![360mm White Galahad II LCD SL-INF AIO](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/360_lcd_inf_w-300x300.png)
Lian Li Galahad II LCD SL-INF 360mm AiO
- 360mm radiator
- Three 120mm SL-INF UNI fans included
